Go Back   Team-BHP > Buckle Up > 4x4 & Off-Roading > 4x4 Excursions
Old 7th October 2009, 15:42   #121
aqualeo2040's Avatar
Thanked: 248 Times
Default Omg
Excellent pics, even better reports.
I cant help but whip myself for having spent 4 years in CBPur (those best days of our lives) and not been to that location.
I would give an arm, a leg, an eye etc etc etc to join the next one.
However, unfortunately, I am not blessed with a 4WD steed.
Will I be still eligible for the next OTR?
aqualeo2040 is offline   Reply With Quote
Old 7th October 2009, 16:25   #122
Thanked: 226 Times
Originally Posted by ex670c View Post
Hi Guys,
Seems like you all had a blast. A bit more planning would have helped.
A few suggestions
1) When attempting to pull a vehicle in soft (Sand/Slush/Mud) surface always use 2 vehicle in a V-Pull (tied down at 2 different points on the Chassis). It saves time and quickly bears maximum effort in the recovery.
2) Cable Damper/Mats/Canvas Sheets. - Will dampen the cable if it get cut and prevent injuries to bystanders; the chances of accidents increase.
Didn't notice any in the pics.
3) A diagonal pull helps, in bearing the weight of both the vehicles of the rear axle, and the stuck vehicle get some traction, also if the vehicle is bottomed out, this is the easiest solution. This was amply demonstrated in TPC09, when Sean Hameed in a MG413W pulled out Baskar Keshavalu's MM540.
4) Carry adequate food and water per head.
What happened to full-length trousers and sport shoes? are they not a mandatory part of the ensemble?
Arka
PS - The 4WD Scorpio, keeps burning up his clutch with or with-out 4WD-Lo, since MGE48 in Munnar.
Arka,
V pull and diagonal pull was tried initially when single vehicle pull could not. Because of the slush on all sides, the wheels were spinning of pulling vehicles and hence, we tried the two vehicle one towing other as we got hard ground ahead. It worked out in the end. What we were pulling was safari which was struck in clayish mud till half its tyre height.
As for dampening the tow rope, You would notice, we used nylon ropes not regular wire ropes. Do we need to dampen the nylon rope too.
As for the snack and water, every one is responsible for their well being. We only advice the group to carry sufficient food, snacks and water.
Long time since, we had you on Bangalore OTR buddy. Plan one trip and back hand we will organise an OTR nearby.
dwaraka is offline   Reply With Quote
Old 7th October 2009, 16:48   #123
Thanked: 146 Times
Originally Posted by aqualeo2040 View Post
... I would give an arm, a leg, an eye etc etc etc to join the next one.
I do not think anyone would appreciate the body parts as remuneration!
But, with the ever increasing OTR tribe here, I am sure you will find a seat in one of the vehicles.
HappyWheels is offline   Reply With Quote
Old 7th October 2009, 17:25   #124
tsk1979's Avatar
Thanked: 16,420 Times
@dwarka, though I am not an expert, but from what I heave heard from NIOC and Jeepthrills guys, all tow cables., whether wire or nylon etc., need to be damped, as a break can lead to serious damage and injury without damping.
I guess arka will elaborate.
Regarding SUVs in OTR, I think in such terrains, SUVs delay the whole group. Its not about who is better in slush etc., but overhangs and long wheelbase.
In India I have seen that terrains favour smaller vehicles. Nothing to do with Jeep/SUV here.
Since most of us have Long Wheelbase SUVs, probably flat sands and non rocky terrains are best.
Coming to scorpio bit, I thought scorpio had 4WD low ratio. Was it busted in this particular vehicle? I have attented couple of OTRs where scorpio was there, and it was easier for the scorpio due to shorter overhangs, and better turning circle.
Old 7th October 2009, 18:06   #125
Thanked: 226 Times
Tanveer,
Thank you for your thoughts.
Rehaan's Scorpio was having problem in 4L before OTR. He had done the OTR on 4 H and could do because of his foot - Maxxis Mudzilla and traction he could build. He has advantageous position with around 3 inches nylon bushes for body lift.
Old 7th October 2009, 21:06   #126
svsantosh's Avatar
Thanked: 1,443 Times
Thumbs up
Would a winched vehicle like Suresh's or swastik's (thippagond?) have speed'nd the Hrishi and Rehaan's recovery?
***** to the writeup skills
***** to the location and pics
***** to the team spirit
5* to the Thread.
--I am sad to have missed a challenging OTR after my 1st one @ Thippa Since I went on a different OTR of my own... Read - Indigo thru Andhra Floods.
svsantosh is offline   Reply With Quote
Old 7th October 2009, 21:22   #127
beejay's Avatar
Thanked: 109 Times
Guys this is seriously going OT. Nice thread, lets keep it that way.
beejay is offline   Reply With Quote
Old 7th October 2009, 22:35   #128
Thanked: 2,469 Times
All of us need to applaud the way these guys toiled hard on these treacherous trial, starving, getting soaked in rains, loosing sleep and lots more.
Wonderful narration and a great OTR, Congratulations to all you guys who were present there.
Last edited by khan_sultan : 9th October 2009 at 14:54. Reason: a bit of cleanup..
Old 8th October 2009, 02:25   #129
MM440's Avatar
Thanked: 37 Times
I suspect he used momentum rather than torque, can someone confirm how he did it?
1> I am more inclined to think that the first vehicle on the trail also benefits from maximum resistance from the terrain.
2> Have seen it on more occasions than one.
3>The driver's skill of course would have to be creditable.
4> So no taking away from Siddu on this one.
Jammy
MM440 is offline   Reply With Quote
Old 8th October 2009, 08:00   #130
Samurai's Avatar
Thanked: 15,757 Times
Jammy, nobody is taking away credit from Siddu. We all know he is an excellent offroad driver who takes the maximum performance out of his MG410. I raised the question because it was implied that he used torque to easily climb that tricky hill while Shahnawaz struggled using the same technique. Dwarak/Vinay who were there have already confirmed he used momentum. So it is resolved.
Old 8th October 2009, 10:19   #131
ex670c's Avatar
Thanked: 1,820 Times
Originally Posted by dwaraka View Post
Arka,
Hi Dwarka,
I'll answer in points.
1) If the V-Pull/Diagonal pull didn't work efficiently Its an Indication -- WINCH!!!!!!
2) If the Nylon Cables have Clevis Hooks or D-Shackles then a Damper is absolutely necessary
3) If everyone is responsible for their own well-being, what the use of having experience and sharing it.
4) Lets do a joint OTR in November-December.
Arka
Old 8th October 2009, 10:22   #132
khan_sultan's Avatar
Thanked: 3,872 Times
That would be great. Hey, but not in Jawadu hills PLEASEEEEEE..
khan_sultan is offline   Reply With Quote
Old 8th October 2009, 10:27   #133
Jaggu's Avatar
Thanked: 8,670 Times
Arka: Unfortunately no winch was available and at that situation this was the only option according to my understanding.
Point 2) i agree, coz i have seen cables snap, not winch cables, BUT they do get into Tandav mode when they snap, saw it rip through concrete in a construction site.
Old 8th October 2009, 10:35   #134
ex670c's Avatar
Default To Jawadhu or not to Jawadhu
Hi Shahnawaz,
I was hoping you wanted to see Asia's largest telescope.
FYI the Jawadhu Hills Range has some superb OTR spots, but will take some time (Years) to recce.
The plan is for Salem (5000 acre Mine) or Yercaud.
Arka
Old 8th October 2009, 10:38   #135
beejay's Avatar
Thanked: 109 Times
A joint OTR.
This is going to be something, and I wouldn't miss it for anything.
Bangalore - Kolar - Chintamani - Chikkaballapur : Route Queries drhoneycake Route / Travel Queries 10 13th May 2018 00:36
Bangalore OTR - chikkaballapur 14-15 Nov report. mjothi 4x4 Excursions 126 6th January 2010 10:32
We are Rockin GOA !!! 02 Oct 09 - 05 Oct 2009 swiftnfurious Travelogues 14 19th November 2009 16:28
I will be in Jaipur EDIT: 11th Oct to 22nd Oct 2009.. Like to meet TBHPians there. dushmish The Team-BHP Meet Section 8 8th October 2009 10:49
Bangalore Vahan Yatra 2005 from 7th Oct to 16th Oct protege Shifting gears 10 21st September 2005 02:00
