Go Back   Team-BHP > Buckle Up > 4x4 & Off-Roading > 4x4 Excursions
Old 11th February 2010, 10:56   #16
Gypsy-Boy's Avatar
This is a very novel idea.
Charity starts at home so - Lets all start by planting atleast one tree in front of our own house first, and then go ahead and attempt to paint our neighborhood green.
This will lead to some green patches in an otherwise concrete jungle.
GB
Gypsy-Boy is offline   Reply With Quote
Old 11th February 2010, 13:26   #17
Thanked: 226 Times
Great ! Let's start rolling the talk.
As for water retaining techniques, we can use cowdung/ saw dust / dry leaves/ bio-degradable sponges/ waste paper/ card board, etc. Any more suggestions?
Next OTR in Bangalore for sure is green OTR. Offroaders please be ready with required tools and 20 ltr water per vehicle.
Dwarak
Dwarak
dwaraka is offline   Reply With Quote
Old 11th February 2010, 13:35   #18
Thanked: 388 Times
Very good idea.
For watering the sapling for initial period there is a very easy method.
This was tried out in Rajasthan and known as "Ghat Sinchai" or pitcher irrigation.
All you need to do is to get an terracotta water pitcher ( Ghara / Ghat) and a lid for it , This pitcher is filled with water and buried next to the sapling.
If there is a need for re-irrigation as in an orchid or farm a small plastic hose is attached and other end is left out of the ground to re-fill later on.
But usually pitcher once filled will be sufficient for the inital period required for plant roots to develop.
amitk26 is offline   Reply With Quote
Old 11th February 2010, 14:18   #19
Thanked: 226 Times
amit,
That's wonderful solution.
Old 11th February 2010, 15:06   #20
Thanked: 190 Times
Bit off topic but still but intent is same.
Bangalore once a Garden city now a concrete jungle now, it’s quite strange that how greedy & selfish people are, just to grab some land full grown trees are mercilessly chopped down in the name of development.
What for this development which is not sustainable. Government agencies are hand in glove with such people who are systematically robbing the greens.
Looks like govt agencies like the forest departments don’t have enough teeth to fend off such evil deeds.
There should be a massive nation wide campaign to for tree plantation.
There should be mandatory legislation, which forces builders to leave some land for tree plantation, within apartment complexes, multi plex’s , SEZ ‘s etc.
tj123 is offline   Reply With Quote
Old 11th February 2010, 15:27   #21
Rotorhead's Avatar
Thanked: 21 Times
indeed a very noble thought. I will try to do the same whenever I make my trips .
Rotorhead is offline   Reply With Quote
Old 11th February 2010, 16:42   #22
Thanked: 235 Times
Good idea.
Make sure it doesn't become an obstacle in the next OTR!
Torqy is online now   Reply With Quote
Old 11th February 2010, 16:51   #23
Ym-enjn's Avatar
Thanked: 54 Times
Very good idea.
Excellent!! That is exactly what we needed.
Source- Clay Pot Irrigation
Overview
Clay pitcher irrigation is a simple, low-cost solution for dryland farming. Unglazed clay pots with a capacity of seven to ten liters, a conical body and narrow neck, are buried approximately one meter apart with the mouth of the pot exposed. Crops are planted around each pot which are filled with water every four to seven days. Water loss from the pot is regulated by soil moisture content. As water is used by the plant, hydrostatic pressure in the soil decreases and water is transmitted out of the pot. When the surrounding soil reaches field capacity, water loss from the pot decreases. This natural, self-regulating mechanism is what makes clay pitcher irrigation extremely efficient.
Ym-enjn is offline   Reply With Quote
Old 11th February 2010, 18:50   #24
Thanked: 388 Times
Originally Posted by Ym-enjn View Post
Yes the pictures explain it very well only one simple modification which I wrote earlier . If there is a lid on the pitcher and it is fully buried and a plastic hose is attached the water loss will be even less.
Old 11th February 2010, 18:58   #25
Rough Square's Avatar
This is such a noble cause and I so want to be a part of it.
Why restrict this to 4X4 owners / excursion?
Rough Square is offline   Reply With Quote
Old 12th February 2010, 15:25   #26
Spinnerr's Avatar
Thanked: 142 Times
Now that is a real green thought. +1 to that.
OTRs just before the onset of the monsoons seems to be the right time to see a good success rate.
Spinnerr is offline   Reply With Quote
Old 17th February 2010, 09:26   #27
Thanked: 20 Times
Default Green & Clean offroading
This is a noble thought,. Hats off for the suggestion.
The sapplings can be got from the forest department.
Need to identify the sappling that grows at the particular OTR location
Each Jeep/Gypsy/Vehicle can carry an earthen pot
Before the start of OTR, identify a planting area and,...
Wow,. nice guys, thats a cool way to start an OTR
Once again hats off for the suggestion.
GrayBerry is offline   Reply With Quote
Old 17th February 2010, 10:27   #28
Gypsy-Boy's Avatar
This is not restricted to 4X4 owners / excursion.
As I had said earlier, we should all plant atleast one tree in front of our own house / Office
Old 21st February 2010, 17:02   #29
hgnishanth's Avatar
Great idea and a very noble cause. I am all in for it. Next OTR we shall carry some saplings and plant them at a suitable location.
Nishanth
hgnishanth is offline   Reply With Quote
Badami and Hampi - Where every stone, every boulder has a tale to tell TheDrivingBug Travelogues 14 8th December 2014 16:47
Short One Day Excursion from Pune to Bhuleshwar siddheshb Travelogues 5 25th October 2010 12:05
Every car story book is special, because every child in us is..special! sidindica Shifting gears 1 8th March 2010 00:34
The Beaches and the Ghats - Excursion on the year end... Musaafir Travelogues 10 23rd January 2010 22:51
Bombay to Himachal & back - a long excursion 4wdrifter Travelogues 31 26th October 2009 00:23
