Go Back   Team-BHP > Buckle Up > 4x4 & Off-Roading > 4x4 Excursions
Old 19th March 2011, 16:05   #16
tsk1979's Avatar
Thanked: 15,683 Times
Default Re: Article : Offroad GPS navigation, concepts and software
Originally Posted by mercedised View Post
@tsk: Nice information there.
BTW, could you please elaborate on 'How to project points using GPS?'.
For e.g. I mark my current location in GPS, and noe from this location I want to mark another point 40-50meters ahead at an angle of 120 degrees? How will I do that? I have Garmin Etrex-H and so far have not been able to use this feature due to lack of knoweldge.
Look at this
Garmin Gpsr Tips And Tricks - Groundspeak Forums
There are many other geocaching software which support projection.
Old 19th March 2011, 17:06   #17
mercedised's Avatar
Thanked: 161 Times
Look at this
I am new to dedicated GPS devices, so could you please explain me the concept behind GEOCACHING? I have read wiki but it says it is a game??
And how do I know if my GPS device has compatibility with the particular software?
Old 19th March 2011, 17:11   #18
tsk1979's Avatar
mercedised, most handhelds cannot run other software.
The GPS thread in shifting gears(gadgets section) has a lot of information about various GPS devices.
You can post your device details there and get info.
Old 19th March 2011, 17:15   #19
Thanked: 28 Times
I used Garmin 62s & 78s during car rallies, I found them quite useful for offroading in desert as well hilly terrain. The best combination for offroading is to have Garmin Birdseye subscription along with these unit.
In bird's eye you can download the high resolution satellite imagery of any area and send it to Garmin device with just a click of a mouse.
Cheers!
Alok
Crazy4Power is offline   Reply With Quote
Old 22nd March 2011, 18:44   #20
Thanked: 21 Times
TSK1979
Firstly thank you for this informative log, just like all your travel logs very informative and readable. I have purchased a MMI device and its not even accurate on state highways, recently i was on SH from Chickmagalur to Kadur and the display showed me moving on a green background with no sign of any road, I did appear to intersect and then move away from the road I was on as per the GPS, was very disconcerting and my trust in the maps loaded on the device was badly dented. Looked like the road was not tracked properly on the MMI maps. Can anyone tell me, is there any way I can load tracks on this device that are not available with the service provider?
Manmohan.
manmohanmaan is offline   Reply With Quote
Old 22nd March 2011, 19:52   #21
tsk1979's Avatar
manmohanman, I do not think MMI devices and software support reading gpx tracks. If you can go to your device software, and click on "about me" or similar button, it will tell you which software its using. Based on that I can let you know whether the ability to show a GPX track is possible in the software or not.
If its not, then the second best option for you is to unlock your device, and use MMI software for normal driving, and when you go to areas without maps, you can use some other software for showing tracks.
Old 24th March 2011, 08:59   #22
headers's Avatar
Thanked: 457 Times
The best topic on this forum - TSK
I was just about deciding on what to use on my Android..
Thanx
Vikram
Old 24th March 2011, 15:02   #23
tsk1979's Avatar
I suggest you check out the oruxmaps latest beta. They have added a "Backtrack" option in tracks, so with a single click you can backtrack your route.
Really beneficial in OTRs when you are doing hit and trial to reach a destination.
Old 24th March 2011, 21:29   #24
RGK
RGK's Avatar
Thanked: 212 Times
Very good informative thread tsk. But bit technical to understand. Need to go through again and understand.
But heard when friends saying that you can mark your place in your GPS device.
RGK is offline   Reply With Quote
Old 25th March 2011, 17:55   #25
sumathindra's Avatar
Thanked: 192 Times
Very descriptive and informative info provided on GPS. Yes it is a must have for almost any one.
sumathindra is offline   Reply With Quote
Old 26th March 2011, 12:20   #26
007
007's Avatar
My Nokia 5235 map is self learning type.
On a new unknown road if you travel with the GPS positioning On, next time the map will show this as a road.
I remember many such routes ( now showing as roads in map) during my vehicle performance trials.
007 is offline   Reply With Quote
Old 26th March 2011, 20:32   #27
Thanked: 2,130 Times
Hi Tsk,
This is/ will become the definitive thread on GPS use on TBhp. As such, I think a more elaborate explanation on vector vs raster maps, moving maps, positional awareness/ navigating/ routing would be in order. Also a bit on how GPS works, esp. on how weak the signals are, the need for the ephemeral table and its relationship with A-GPS, would also be useful.
Great thread.
Sutripta
Old 28th March 2011, 01:11   #28
justwheels's Avatar
Thanked: 201 Times
It can never get better than this.Brilliantly explained "tsk", I am an absolute novice in this field but this article would be in my hit list of "refer-back" topics. Thanks for such an informative and relevant thread. Will be glued to this as more information flows.
justwheels is offline   Reply With Quote
Old 28th March 2011, 11:37   #29
tsk1979's Avatar
Thats not a good idea when offroading. Often on many terrains you would backtrack quite a bit. So imagine you going to that region again, and seeing a maze of tracks, without any idea which was the perfect track to take.
Hi Tsk,
Great thread.
Sutripta
I was thinking of that, but then I refrained. It will make this article lose focus. About technical definitions, and A-GPS details etc., lot of information on google as well in the generic GPS thread in gadgets section. I want this article to be focused on Offroad GPS use.
Thanks justwheels!
Old 28th March 2011, 13:29   #30
classicselva's Avatar
Thanked: 22 Times
Fantastic explanation on Offroad GPS. Tempting to to try!!
classicselva is offline   Reply With Quote
In Dash Navigation vs Navigation Module vs Separate Navigation SirAlec In-Car Entertainment 27 20th January 2014 22:19
Satnav Launches GPS Navigation Software navdeep Modifications & Accessories 119 16th November 2010 15:48
Software Dev. Engineer v/s Software Test Engineer DCEite Shifting gears 50 14th April 2008 13:10
Airtel Announces GPS Navigation navdeep Modifications & Accessories 14 14th July 2007 12:03
