| 4x4 & Off-Roading Jeeps, muck, slush, sand and more. |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Moderator ![]() | Tata safari specifications say that it has a limited slip differential. However, it stops shy of any further details. For example what is the tolerance. Is it speed sensitive. What sort of clutch is used. Is it front back or side only. For example if in 4x4 more both front wheels are in air, or both wheels of one side are in air, or diagonally opposite wheels are in air. In case of 4x4, is the rear differential limited slip? Since its a limited slip differential, and not a locking differential, I presume it can be used on tarmac(twisty conditions). Any more information about the specifications of the same would be good.
__________________ Reclaiming.....! |
| | #2 (permalink) |
| Newbie Join Date: Oct 2007 Location: dehradun
| I suggest that you visit the following URL. it might solve your query. Limited slip differential - Wikipedia, the free encyclopedia |
| | #3 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
That link does not have any information about the specific Limited Slip Diff used in the safari
__________________ Reclaiming.....! | |
| | #4 (permalink) | |
| Senior - BHPian | Quote:
IINM, the lsd is in the context of 4x4 only? I presume your question is in the context of 4H/4L? Well, it is NOT recommended to drive for prolonged stretches with 4H engaged as it causes wear & tear to the drivetrain & what is also called "bending"
__________________ Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4 Last edited by suman : 12th December 2007 at 10:06. | |
| | #5 (permalink) |
| Team-BHP Moderator ![]() | I too have a question about the Safari. In the television ad, they show the Safari leaping off. While in mid air, the front wheels are stationary while the rears are still spinning. Even if it was a 2wd version, wouldn't the front wheels continue to turn due to momentum?
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ |
| | #6 (permalink) | |
Robin, there was a thread on this mate - it was all about LSD, IIRC
__________________ Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4 | |
| | #8 (permalink) | |
| BHPian | Quote:
so, put it in 2wd, take a run up and leap off... and then cutttt... ![]()
__________________ Taken the plunge! www. virtu. in __________________ 2002 Lancer | 2006 Palio | 2008 Trek 4300D | |
| | #9 (permalink) |
| BHPian Join Date: Sep 2005 Location: Chennai
| | #13 (permalink) | |
| BHPian | Quote:
Again anybody in the know about what type of rear wheel LSD is there in TATA Safari 4wd And Whether a retrofit can be done in a Tata Safari 2wd, i.e., converting the 2wd open differential to a 2wd LSD.
__________________ Safari LX 2.2 VTT -TMT [The Magnificient Tourer]"Celebration Countdown -->> 1-year Ownership" Last edited by adc : 15th February 2008 at 17:21. | |
| | #14 (permalink) |
| Distinguished - BHPian ![]() | From the static wheels in the ad, it appears that the LSD is in the front only. It is to help clawing up, in case even engaging the front axle does not provide enough grip. But 4x4 experts may help. Would suggest moving this to the 4X4 section to maybe have this attract their attention.
__________________ ________________________ Every Ferrari is always a Fiat |
| | #15 (permalink) | ||
| BHPian Join Date: Feb 2008 Location: Turin-Italy
| Hi all lets see if I can clarify a bit the Safari drivetrain... The Safari SUV 4x4 is a part time 4wd, thus there is a switch that control the traction through a transfer case. In 2H torque is transfered only to the rear axle. In 4H torque is transfered to front and rear axles in equal mode, as there is no a differential, 50% front 50% rear, the ratio is the same as per gear box. In 4L torque is transfered to front and rear axles in equal mode, as there is no a differential, 50% front 50% rear, the ratio is lower as the transfer case reduce the ratio, hence 4wd low. The only limited slip differential is in the rear, is just set to a rate of 30-40% and it works through a set of clutches and a special oil. When the difference of rotation between the two axle semi shaft is fery high (e.g. one wheel on good grip position the other in very poor grip or lifted from ground) the oil start heating, density is reduced and the clutch discs, between planetary, sticks toghether. Is not a solid stick, but enough to give some torque to the wheel in good grip position and then moving the vehicle. Some off road situations now: _Twist - one wheel per axle in the air in opposite direction - the Safari will have one front wheel spinning in the air and not transferring any torque to the other; one rear wheel in the air but because LSD (not the drug ![]() is transfering some torque to the wheel with grip, the car will probably been moved forward. _2 wheels same side up in the air - see above. _front wheels free in the air - basically same situation of the twist, no traction from the front axle, then rear will push. _rear wheels free in the air or both slipping - car will go only if a certain amount of grip is provided by both wheels of the front axle. If any of the 2 loose traction, well, you are stucked! Quote:
It works on wheel speed difference, it is embedded, you can not disengage the clutches. A different story is drive in 4wd on good grip road. NEVER TO BE DONE WITH SAFARI!!! The reason is very simple: when the car is moving and negotiating a turn, the 4 wheels are spinning at 4 different speeds. The difference between inner and outer wheels are compensated by the differential, either front or rear axle. But we do not have a central differential in the transfer case, so we do not have compensation in speed difference between the front and the rear axles. If the "road" is low grip, the compensation is done by a certain amount of wheel spinning and everything is fine; if you are on asphalt, the compensation is not doable by the wheel, then all the drivetrain is undergoing to an extra torsion, thus breakedown (u joints, ring, pinion, shaft... the looser break...) Quote:
I hope haven't been too boring with this long reply... Feel freee to correct me if I'm wrong somewhere. Ciao ciao Ignazio | ||
| Thread Tools | |
Similar Threads | ||||
| Top Slip (near Pollachi) | vasantevangelin | Route / Travel Queries | 26 | 1st June 2008 16:55 |
| What to choose safari petrol or Safari diesel 2.2L | 007 Bond | SUVs, MUVs & 4x4s | 22 | 31st August 2007 21:56 |
| Safari VX Accessories Question | SumitB | The Indian Car Scene!! | 19 | 19th February 2007 09:20 |
| New first ever limited Edition Rx-8 for UK | devarshi84 | The International Automotive Scene | 10 | 14th February 2006 04:59 |
| Question on Clutch Slip!!! | Shan2nu | Technical Stuff | 27 | 19th March 2005 07:26 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
