| 4x4 & Off-Roading Jeeps, muck, slush, sand and more. |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Feb 2008 Location: Coimbatore
| hi , I am planning to fit 9.00 x 16" NDMS tires on a SWB Jeep. If you are wondering what tire this is, it is the one fitted on JCBs front wheels. Wondering what kind of issues/performance I can expect. I could think of the following issues : 1. Need wider rims ( 6 to 6.5" width instead of the present 4.5")to fit the tires. 2. Need to increase clearance height to compensate for the bigger tires. 3. Better fuel efficiency due to large diameter of tire ? 4. Poor fuel efficiency due to heavier tires/rims ? 5. Poor braking due to bigger tires - Need to go for disc brakes. 6. Poor Pickup... Will the vehicle atleast move normally? I am not in a position to fit the tires and then check out the performance. It would be better to at least in theory analyse it and then go for it...( if it makes sense...) BTW it would have a Peugeot DI diesel engine, 5 speed gear box, 4x4, Free wheeling hubs, etc. Regards Anand |
| | #2 (permalink) | |
| BHPian Join Date: Jul 2007 Location: Chennai (formerly Madras, even more formerly Chenna Patnam)
| Quote:
6. I guess the good low-end torque of diesels will negate this effect. OT : have you got the tyre prices? and which brand? | |
| | #4 (permalink) |
| BHPian | Your tyre choice would depend a great deal on what kind of driving you would do. Overall I would recommend radials, as they are lighter and provide superior traction. Be it on road or off, this matters. You also get better mileage. Secondly the tread pattern choice should depend on how often you go offroad. You have highway treads, all terrain, and serious offroad treads. If your vehicle use is a combination the all terrain tyres are great. On deciding the size, while broader the better, there are limitations as you end up loading the steering, increased weight affects handling, and your wheel well restricts size useable(affects turning radious too). For a Jeep suggest you cut off at 235/70's as anything bigger would feel cumbersome PS: The OE nylons off my Tata 207 felt like lead compared to the All Terrain Landcruiser radials I fit. The ride improved dramatically and so did the steering feel and grip.
__________________ In changing yourself, you change your life Last edited by DKG : 16th April 2008 at 17:40. |
| | #5 (permalink) |
| Senior - BHPian | Also be wary about the speed rating of the JCB front tires. Some tires are not designed to go fast. JCB tire, based on it's application, i'm sure is not meant for highway speeds.
__________________ "Auto racing, bull fighting, and mountain climbing are the only real sports... all others are games." Ernest Hemingway |
| | #6 (permalink) |
| Super-Admin | I got 225's for my Jeep and wouldn't recommend anything wider than that. In fact, this size itself may be a little overkill for the kind of power (or lack of) that the diesels make.
__________________ GTO Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
| | #8 (permalink) |
| Distinguished - BHPian ![]() | 9.00x16 translates to a 230/100 R16 tyre in our terms. For a Jeep this is going to be too wide, too tall & certainly not appropriate unless you have an engine putting out some serious power. As for your questions, my answers are below: 1. Yes, minimum 6J, 6.5J recommended. 2. Yes, big time increase in wheel arch clearance required. 3. Nope, poorer fuel efficiency due to much wider contact patch & a lot more unsprung weight. 4. Yes, explained above. 5. Could be but this is a debatable issue. Also depends on the quality & construction of the tyre. 6. No it will not. It will move slowly & the figures on the stock gauges will be all skewed due to the bigger tyres. Plus the wider contact patch of the tyres coupled with the increased of the bigger tyres & rims will mean that the accelaration will be hurt big time. I would suggest drop this idea since being off a JCB these tyres won't be suited for road use either. Get some nice 215/75 R15 radial, they'll be much better for your usage & more appropriate given the kind of power your vehicle has. Also, under normal circumstances they'll be much cheaper than the JCB's tyres.
__________________ There is a very fine line between "Hobby" and "Mental Illness". |
| | #9 (permalink) | ||
| BHPian Join Date: Nov 2007 Location: Cochin
| Quote:
Anand, You haven't mentioned what kind of jeep you have. If it is the older CJs or pre 2004 MM540s the only rims that fit the same PCD are: 1. Gypsy 15 inch rims (5.5 inches) 2. Army MM540 (not sure how wide) 3. The OEM rims (4.5 inches wide). I am figuring out what to do as I want to go to wider tires but don't want to drop to a 15 inch rim so the gypsy rim is ruled out. I am a bit concerned about putting wide tires on the standard 4.5 inch wide 16inch rims. Army rims are hard to find. In my case, I am also upgrading the brakes on my MM540 to disk brakes so as part of the upgrade, I have to buy new front hubs so I decided to buy the scorpio hubs with the 160 PCD rims which will give me much more choices with rims. All newer Mahindra and Tata vehicles have 160 PCD rims. Last edited by Rehaan : 18th April 2008 at 00:38. Reason: Merged. Please read about "quoting multiple posts" in the team-bhp FAQs. | ||
| | #10 (permalink) |
| BHPian Join Date: Feb 2008 Location: Turin-Italy
| Hi, the only possible chance to have some good results, apart from modify the jeep to hold that size, body lift etc, to increase the resistance of all steering parts etc etc, is to reduce the ring and pinion ratios in yours differentials. With those tires, much bigger than original, to start the jeep your clutch will burn in few times, your speedo will never match the real speed and FE will be worse... Go for Mud or All terrain, safer and better... BTW, what is the precise size of what you have now? Ciao Ignazio |
| | #12 (permalink) |
| Tire Prices Apollo - Rs.5500/tire Ceat - Rs.6000/tire MRF also makes these tires. Yet to get the price. Disc cost - Rs.4500/disc (new); Rs.3000/disc(used) My friend is planning on this. His farm is next to inaccessible during the rains. We need bigger tires. We have experienced CL500/500s with 15 inch radials, getting into a spin too soon. That is why we feel we need 7.00 x 16 or bigger. Here in Coimbatore we cannot get the 7.0x16 or 7.00 x 16 NDMS tires. |
| | #14 (permalink) | |
| BHPian | Quote:
My MM540 has 265/70 R16 on standard jeep rim. I have done close to 90 kmph on it, cornered well and had good ride quality too. Also did Keelambakkam quary route on these which is very unforgiving terrain. These were good on sand during my beach off roading However i wouldnt recommend it to go for such large tyre. The following are the reasons- 1. Steering is very tight on city roads 2. During exterme articulation the tyres are rubbing inside the wheel wells Infact iam planning to either go for 7.50 x16 MRF sand grips or use 7.00X16 standard tyre. May think of a radial with A/t pattern not exceeding 235 size.
__________________ Go anywhere do anything! | |
| | #15 (permalink) | |
| Senior - BHPian | Quote:
And if u want them, we can help you source those tyres from Chennai. ![]()
__________________ Maruti - Everyone comes home with rattles! | |
| Thread Tools | |
Similar Threads | ||||
| Query : Tubeless tires / Normal Tires | nicejits | Tyre & Alloy wheel Section | 8 | 15th January 2008 01:56 |
| DICOR Cat Removal effects | overdose14 | Modifications & Accessories | 0 | 7th December 2007 00:15 |
| Effects of warranty on selling the car. | amohit | The Indian Car Scene!! | 14 | 21st September 2007 13:04 |
| UNSPRUNG WEIGHT - and its effects | kb100 | Tyre & Alloy wheel Section | 12 | 26th March 2007 15:52 |
| after effects of attending a drag | normally_crazy | Street Experiences | 6 | 12th May 2004 01:00 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
