| 4x4 & Off-Roading Jeeps, muck, slush, sand and more. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jul 2007 Location: Dharamsala
| I am way up here at the front range of the Himalayas. There are no good trustworthy mechanic shops nearby capable of doing extensive restoration or repair of vehicles. Body work they can do but little deep mechanical stuff. Similarly, there are no shops closer than 6 hours away capable of doing extensive modifications. Here anything you buy, anything you mod, had better be stone cold reliable and/or so common that knowledgeable auto mechanic shops can get the spare parts and make the changes. Up here the K.I.S.S. method is the wisdom of the day, KISS = Keep It Simple, Stupid. A local government is about to sell off an old Mahindra Commander four wheel drive unit for 60,000 rupees. See pictures. I am the only one interested so it is mine if I want it. I guess the Commander is the forerunner of the Marshall, at least they look similar. This is an early 1990’s vintage vehicle (Maybe, or late 1980s) and has the Peugeot 2100cc motor in it. The body is unique in that it has a hand crafted paint job, that is, the paint was put on by hand with a paint brush. The paint, a nice shade of varicose blue, is all that holds the rust together, I think. Body work and electrical stuff can be done here as can the interior. The interior? Well, it's not great but there are no animals subletting inside and the thing runs pretty good. I would like to keep the 2100cc Peugeot but I want to tweak it and get 70-90 horses out of it. What do you guys think? Can this Peugeot be cranked up a few notches? One concession I might make is to pull it and take it to Chandagarh and get it tweaked if I could find somebody there who is expert. Nobody here can even begin to swap in a Scorpio 2.6L or a Simpson S4. Any ideas? Any SIMPLE ideas? Please remember, it has to be reliable and maintainable.
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi |
| | #2 (permalink) |
| Senior - BHPian Join Date: Jul 2007 Location: Delhi
| O Dan, Why must you? Why not an old MM540? This doesnt seem the 4WD version either.
__________________ My dream: An india where even a CD100 runs HID to teach insensitive full-HID dudes that HIDs are a zero sum game. |
| | #3 (permalink) | |
| Quote:
I see it coming out a little like this 1950 Willys Overland only blue.
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi | |
| | #4 (permalink) |
| BHPian | Hi Dan, The commanders are tough vehicles. Engines 1) MDI3200TC + 4speed 4WD or 5 speed 4WD 280Kgs 2) MDI3200 + 4Speed 4WD 270Kgs 3) SZ2600 is too complicated to fit and very expensive 320Kgs 4) S4 can be easily fitted you need to change the bell-housing and the engine mounts. 320Kgs The S4 to KMT90 bell housing is used in the FJ470DS433 Mahindra Vans. Regards, Arka
__________________ May the FOURs be with you. |
| | #5 (permalink) |
| Senior - BHPian | Great to know you're about to start off with your project,Dan. I have a similar commander 750DP albeit a soft top with no doors. About the Peugeot motor, at most i would suggest changing the air filter type from the 'oil bath' one to the paper element 'bolero type'. Nothing else u can mod to keep it reliable. Its pretty reliable and agricultural as well. If u need smoothness and more power, u could swap it straight away with the bolero XD3P motor. Smooth,powerful and reliable. Do let me know if I could help you with sourcing anything from here? Id be more than glad!
__________________ hindu.com/mp/2008/08/25/stories/2008082522220200.htm |
| | #7 (permalink) | |
| BHPian | Quote:
Any idea about the prices of these engines ? Thanks Sunny
__________________ 2006 Tata Safari 3.0 L 2005 Enfield Bullet Electra 350 2004 Maruti Zen | |
| | #8 (permalink) | |
| BHPian Join Date: Nov 2007 Location: Cochin
| Quote:
IMO, I think you should go in for the Turbo DI engine (MDI3200TC). I was initally was going to put in the XD3P until I found I couldn't get a bell housing to mate with the NGT20 5-Speed gearbox that I am installing. I would have to fabricate an adapter plate. I prefer the orignial set up so choose not to go the adapter plate way. Secondly, similar to you, I do considerable driving in the hills in Niligiris and Kumily in Kerala since we have estates there and for driving in the Hills, I found that Torque is more important than high bhp at high rps. The Torque ratings of the Turbo DI engine are very good and it makes most of it at below 2000 RPM so very usable in hilly ranges. Also the Turbo DI engines are very reliable and give good FE numbers too. Besides you pretty much get the same performance as the S4 in a much lighter package and spares availability could be better for the DI engine as opposed to the S4. Regarding getting more power out of the Peugot 2.1 mill, I sincerely doubt you can do much. You are better off selling it and buying a Turbo DI unit. The four-speed gearboxes are a pain if you do any long distance driving so I would recommend getting a NGT20/BA10 5-speed or atleast getting the warn overdrive unit that RedMM340 has installed in his vehicle. Last edited by 4x4addict : 21st May 2008 at 12:50. | |
| | #9 (permalink) |
| BHPian Join Date: Feb 2008 Location: Turin-Italy
| Hi, that is a bargain! Keeping in mind that as to be a KISS filosofy, if i'll be in you, i'll not think of swap engine immediately. Depending also the final destination use of the car. Are you planning to use it as a daily runner or just offroader time to time? Restore it, get rid of all the the useless heavy parts and replace it with alloy what possible, essentially I'll try to get the highest power/weight ratio I could. I'll rebuild electric, proper tires, proper suspensions, install power steering and power brakes (if it does not have it already). Stainless steel FFE wich is lighter than regular steel and better longevity and so on... Is the Peugeot engine equipped with a linear or rotary pump? Last but not least, are you going to do something on your own or do you have to rely on external garages? Nice good challenge, keep us informed! Ciao Ignazio |
| | #10 (permalink) |
| BHPian Join Date: Mar 2006 Location: goa
| Hey great, Jeep to work on, the 2.1 liter engine can take a turbo to get around 80 BHP or go in for a 2.5 Liter engine [72 bhp], or get a good turbo DI for the bolero. Scropio engines are had to find and also very difficult to set up with all the electronics involved. Earlier engine with mechanical injection can be installed if you can find one. What is the vehicle going to be used for, daily drive[street or offroad] ? or off roading [casual] ? accordingly you can do up the vehicle., if it's going to be daily drive an on streets/highways than I would suggest getting a 5 speeder in it [through experience ] I had commander soft top. It great off roader, not as good as the short wheel based jeeps. |
| | #11 (permalink) |
| BHPian Join Date: Jul 2006 Location: Bangalore
| From where you are tweaking the motor to make 70-90 bhp would be difficult - lack of garages. The conversion if done would not be reliable. My suggestion is check the engine, change whatever is required. Get all the components working as they would in a new vehicle. Reduce weight as much as possible. Take care of the rust and get a good paint job. KISS. The vehicle is good enough with that engine, easily repaired and maintained. |
| | #12 (permalink) |
| Thanks all, especially ex670c and 4x4addict for their detailed technical answers. I still have not bought it. Partly I am waiting to see what you BHPers have to say. It is to be used for excursions into the deep Himalayas. I need to climb hills and get thru the "bad roads" and the "no roads" that the big hills can throw at you. For the price, 60,000 rupees, it may make sense to buy it for the transfer case and front axle alone.
| | #13 (permalink) |
| BHPian Join Date: Apr 2006 Location: bangalore
| Hi Dan, I am trying to get hold of some vendor from Australia to see if they can send some off road equipment - winch, traction mats, extraction cables for my Pajero. I will keep you and the other guys posted on the cost etc if any of you would also be interested. Rgds |
| | #14 (permalink) |
| Super-Admin | I may be going against the tide here, but will insist that the 2.1 liter is an awesome engine. Mine served me well for 1.4x lac kilometers....its a darn robust unit that has more than enough pep for urban cruising and off-roading. The FE is respectable too! DirtyDan : Don't swap it nor modify it. How many kms has it covered? Is a rebuild required? P.S: Look around for a 540. P.P.S: Phenomenal amount of Jeep projects in the air of late, eh? Team-BHP seems to found a new love in Jeeps ![]()
__________________ GTO Change the way you think, and watch the world change around you.
| | #15 (permalink) | ||
| Quote:
I agree that it is a robust engine but it has one major drawback. Because Mahindra only offered it with the 4 speed tranny, the engine is always running at the upper band of it's rpm at speeds over 80Kms. This results in the rings wearing out prematurely. M ost people I know have had to do a minor engine job, i.e (top end only) between 80K and 90K kilometers. If I recall, you did change your final drive ratio to gain better top speed. That or the fact that your vehicle may have been spend most of its' life as an urban cruiser may explain the 1.4 lakh life of the engine. To be honest you'r is the first 2.1 liter engine that I know that has gone 1.4 lakh km without the top end engine job. Also remember that this Marshal is probably atleast 500 kgs heavier than the classic or MM540. DirtyDan, The classic symptoms of the 2.1 needing a ring job: 1. Oil consumption..which you won't probably know. 2. Look on the inner side of the bonnet you will see oil stains of small droplets. 3. You will need the heater to start all the time, i.e even after the engine has warmed up to about 60 degrees. 4. You will see thick smoke under heavy accelleration. Quote:
Current List: DI Turbo Engine NGT20 5-Speed Gearbox Power Disc Brake Kit Full floating rear diff. 160 PCD Scropio Hubs with Scorpio wheels and 235/70/16 Yokohama ATS AC/ICE/Front Buckets and Rear Front facing seats (similar to RedMM340s). Next Set of Upgrades: Inter Cooler for the Turbo Limited Slip Diffs or Diff Lockers (still deciding) Bilstien or Rancho shocks Removabe Hard Top Last edited by 4x4addict : 21st May 2008 at 19:23. | ||
| Thread Tools | |
Similar Threads | ||||
| Mahindra Commander Engine exhaust | rranjith_kum | Technical Stuff | 15 | 28th February 2008 18:16 |
| Power commander for cars? Why not? | Rtech | Technical Stuff | 8 | 5th September 2007 16:39 |
| pioneer HU deh-p7750 rotary commander knob required urgently. | clipto333 | Product Discussions | 14 | 24th April 2007 12:16 |
| project help | pawan | Shifting gears | 3 | 19th March 2007 00:08 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
