| 4x4 & Off-Roading Jeeps, muck, slush, sand and more. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Feb 2006 Location: Hyderabad
| Hi I need urgent help regarding the wheels on my mm540. I got a great offer on a set of goodyear a/t ( size 205/80/r16) I need to know if these will fit on my stock jeep rims, if not then for how much could i get the rims that could accommodate these tyres ? I need urgent help on this as the person who is selling the tyres is holding them for me only till tomorrow. EDIT: the stock jeep rims are 4.5J R16
__________________ I never thought it was humanly possible, but this both sucks and blows. - Bart Simpson Last edited by cooldude1988765 : 24th October 2008 at 19:50. |
| | #2 (permalink) |
| BHPian Join Date: Jul 2007 Location: Chennai (formerly Madras, even more formerly Chenna Patnam)
| I am not an expert on this, but I think you need atleast 5.5J for the 205 tyres to fit safely.
__________________ to boldly go where no man ( or woman ) has gone before Last edited by Blue Thunder : 24th October 2008 at 20:00. |
| | #3 (permalink) |
| Another query: Will the safari/fj40/jonga stock steel wheels fit the mm540 ?(are they the same PCD ?) @BlueThunder: Thanks for confirming that. EDIT: Can the safari rims be modified to fit the mm540 if they are not a direct fit ?
__________________ I never thought it was humanly possible, but this both sucks and blows. - Bart Simpson Last edited by cooldude1988765 : 24th October 2008 at 20:21. |
| | #5 (permalink) |
| Any idea what rims the matodor(f307) uses ? The goodyear wranglers are tubeless (if that makes any difference)
__________________ I never thought it was humanly possible, but this both sucks and blows. - Bart Simpson |
| | #6 (permalink) |
| BHPian | 1>The radial equivalent of 6x16NDMS are 185/70r16.Although am a little unsure about the profile on it being 70 or 80. 2>If you are fitting 205s then you are 20mm over the limit.I reckon if you can fit 7x16 NDMS on 4.5j rims then you can fit 205s also. 3> Or at least till you find wider rims. 4> However if they are shady imported ones then please stay away. Cheers jammy |
| | #7 (permalink) |
| The tyres are definitely 205/80/r16. They are oe tyres of a tata TL. Is there a way I can get some kind of spacers fabricated to use 160pcd wheels on the jeep ? The wheels in question have a 5 hole pattern. EDIT: The wheels are OE TATA TL/SAFARI steel wheels
__________________ I never thought it was humanly possible, but this both sucks and blows. - Bart Simpson Last edited by cooldude1988765 : 24th October 2008 at 21:23. |
| | #8 (permalink) |
| BHPian Join Date: Nov 2007 Location: Cochin
| I ran 205's on my MM540 on the stock rims before I did a 160 PCD conversion. I think you will be fine. I say go for it. Vinod actually runs 265s on his stock MM540 rims. That maybe pushing it, but he has had no issues. 205s definitely are fine. There is a whole thread on spacers. If you decide to go for it make sure you get quality ones. |
| | #10 (permalink) |
| After an extensive discussion with 4x4addict over pm I have decided to get the tyres and use them on my stock rims. Atleast till i find wider rims. I will update by evening or tomorrow morning. THANKS
| | #11 (permalink) | |
| BHPian | Quote:
They will fit your stock rim 4.5J +/- 1" is the ideal tyre width.
__________________ Give them the Flinches, with cubic inches.. (Dirty_Dan quoting the Rig Veda) | |
| | #12 (permalink) |
| Finalised the deal for the tyres. I am now looking for wider rims that can accommodate the same (in a tight budget) Any ideas would be highly appreciated. @ ex670c : Can i use them as tubeless itself. I doubt the condition of the rims. Will using tubes in tubeless tyres have any adverse effects ?
__________________ I never thought it was humanly possible, but this both sucks and blows. - Bart Simpson Last edited by cooldude1988765 : 25th October 2008 at 11:25. |
| | #13 (permalink) | |
| BHPian | Quote:
__________________ ' A WILL FINDS A WAY ' TENSION LENE KA NAI, TENSION DENE KA!!! | |
| | #14 (permalink) | |
| BHPian | Quote:
But check the following i) If the above tyre has been designed for tubeless application ii) Remove your rims and get them primed and painted. I would not suggest changing the PCD. The JONGA has the same PCD as the JEEP but it is 6 bolt pattern (all Japanese 4WD have the same PCD and bolt pattern). Using Tubes in a Tubless Tyres will have no adverse affect.
__________________ Give them the Flinches, with cubic inches.. (Dirty_Dan quoting the Rig Veda) Last edited by ex670c : 25th October 2008 at 12:42. | |
| | #15 (permalink) |
| I changed the tyres on the 25th itself thanks to everyone for the support and advice. Even the tyre wallah said that the tyres would pose no problems on the existing rims. I am currently running with tubes as i am waiting for the tyre guy to get tubeless nozzles(i dont know what it is called, I am referring to thing you fill air in the tyre) which he dint have in stock, There is a tremendous difference in grip and ride over my previous nylons.
__________________ I never thought it was humanly possible, but this both sucks and blows. - Bart Simpson Last edited by cooldude1988765 : 31st October 2008 at 11:21. |
| Thread Tools | |
Similar Threads | ||||
| Urgent Query Laptop | BUSA | Gadgets, Computers & Software | 19 | 19th December 2007 15:09 |
| Urgent CNG Query... Wierd | yuv | Modifications & Accessories | 7 | 24th September 2007 01:11 |
| Willys Jeep Wheels | dinya | Tyre & Alloy wheel Section | 5 | 29th November 2006 09:55 |
| Urgent Ohc Vtec Query | katalyst | The Indian Car Scene!! | 22 | 26th July 2006 00:14 |
| Query on Alloy wheels | Held | Tyre & Alloy wheel Section | 20 | 18th April 2006 13:42 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489
