Old 18th May 2011, 05:52   #46
madhkris's Avatar
Thanked: 70 Times
Default Re: Basic 4X4 Terms
Jeepster,
Thanks a lot for those fine pictures and explanation on GC of 540.
madhkris is offline   Reply With Quote
Old 5th June 2011, 23:13   #47
jeepster's Avatar
Thanked: 1,046 Times
wheel offset
the offset of the rim/alloy is the amount of distance from center of rim/alloy.
in other words how much the rim/alloy goes in or out of the body.
see the picture below.
a + offset rim will reduce the standard track length of the jeep gypsy. (mostly sock rims are + offset ones in almost all vehicles)
& a - offset rim will increase the track length.
but the increased track can also result in the suspension (in IFS) & bearings (in rigid & IFS) issues.
some times the increased track limits the articulation too.
example. armada/bolero rear wheel arch. (even thar )
in stock form the tyre goes in the body tub under heavy articulation (pic 1, 2) , but when the track increases the tyre directly touches the wheel arch thus limiting articulation (pic 3).
source: http://www.team-bhp.com/forum/4x4-te...ml#post2378871 (Off Road Steel Drums)
jeepster is offline   (1) Thanks Reply With Quote
Weird & Wacky terms used in Indian automotive sector SAHIR.KITTUR Technical Stuff 132 3rd June 2015 20:10
How is Mahavir skoda (hyderabad) in terms of A.S.S.? cooldude1988765 Indian Car Dealerships 10 25th July 2012 11:09
terms and conditions streetlife Technical Stuff 1 6th October 2005 09:57
