Old 1st May 2011, 07:51   #16
Default Re: Diff ratio for MDI3200 TC DI engine ?
Thanks Arka for the input.
Can you suggest a better engine other than a XD3P with a lot of torque best suited for OTR's to be fitted on a CJ3B.
Joe3tom
joe3tom is offline   Reply With Quote
Old 2nd May 2011, 10:38   #17
ex670c's Avatar
Thanked: 1,799 Times
Joe3tom
Hi Joe,
Instead of the XD3P, you can go for the XD3P-2A.
On a more serious note, the XD3P is a straight fit with the KMT90 and not very heavy at 198Kgs, we prefer lowering the Diff-Ratio and putting taller tyres to get more torque at the wheels, and a better crawl speed.
The Taller Tyres compensate the Road Speed.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 3rd May 2011, 14:43   #18
Jeepfreak's Avatar
I would not suggest this on a 3b, i started off this project last year on a 3b with Di turbo engine and NGT520 GB. ran into a lot of issues. Keeping that in mind i picked up a cj500 chasis to accomodate ngt520 and later had to settle for kmt90 due to financial reasons, first of all finding a ngt520 in second hand market is like finding a needle in a hay, secondly even if you find one they will ask you for a hand and leg, unless you have planned to pick up a brand new GB from an authorised dealer. Will post pics soon along with AC setup
Fahad
Jeepfreak is offline   Reply With Quote
Old 4th May 2011, 20:19   #19
Thanks Fahad for the info.
I have more or less decided to go for a XD3P engine with a KMT90 GB. Just for information sake, How much does a new NGT GB cost ?.
Can you post some pictures of you Jeep with the MDI3200 DI TC engine and GB.
Joe3tom.
Engine, Gearbox, Diff ratios, axles options for the JEEP Frankenstein 4x4 Technical 104 5th December 2017 22:19
Mahindra MDI3200 Engines Ashley Nair 4x4 Technical 15 26th November 2013 16:48
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
Changing Compression Ratio & Gear Ratio adheesh Technical Stuff 7 3rd October 2007 09:54
Variable compression ratio engine! amitoj Technical Stuff 8 20th December 2005 21:01
