Old 28th April 2011, 13:41   #1
Default Diff ratio for MDI3200 TC DI engine ?
I am working on modifying a CJ3B for OTR's with the following spec,
MDI 3200 TC DI engine
MM 550 front diffs with disc brakes
MM 550 rear diffs with LSD
4WD NGT 520 or KMT 90 Gearbox - Still not decided.
I would like to know what diff ratio I should use for the front and rear diff if I use a 4WD - NGT 520 or a KMT 90 gearbox.
Is a NGT 520 gear box good or better than KMT 90 for OTR's?.
I intend to alter an armada chassis to fit the above specs to suit my CJ3B body. The reason for using an altered chassis is that the original CJ3B chassis will not get damaged due to abuse in the OTR's.
Is it safe to cut and reduce the length of an armada chassis to suit the CJ3B body spec ?.
joe3tom is offline   Reply With Quote
Old 28th April 2011, 14:54   #2
Red Liner's Avatar
Thanked: 1,474 Times
Default Re: Diff ratio for MDI3200 TC DI engine ?
You mean 550 Axles. How much did these axles cost you?
I think you can stick with the 1:4.xx ratio series which comes standard in the MM540 (arka, please fill - I did not attend your workshop this year and I have forgotten these things). The 5.xx series will be too much for an MDI engine and your on road cruisability will suffer.
KMT90 is far more rugged, can be fixed by anyone. NGT 520 is more expensive, but more smoother. That said, I drove Robi's invader which comes with a factory fit KMT90 and it was as smooth as an NGT.
Why dont you just get another 3B Chassis from somewhere? I think this will be far easier to procure than cutting up an armada chassis.
Red Liner is offline   (1) Thanks Reply With Quote
Old 28th April 2011, 16:17   #3
4x4addict's Avatar
Thanked: 2,668 Times
The diff ratio is generally decided more by max engine RPM rather than the gearbox you will use.
For XD3P or XDP4.9 use 4.88 final drive for MDI3200 TC use 4.3 for better overall usage and 4.88 for off-road bias or 3.73 (OEM) for highway/touring bias. This applies whether you are using NGT or KMT.
From pure off-road perspective KMT90 is a more durable gearbox. However, your comfortable top speed will be restricted to about 80Kmph with KMT90 (XDP4.9) and about 90Kmph with XD3P (Army 2.5).
With NGT and right gearing 100 to 110 Kmph is comfortable.
You can alter the chasis but only at a shop that has experience with this kind of stuff else you will end up with two vehicles during the OTR.
[quote=Red Liner;2330871]
[quote]
No way mate. KMT and NGT are poles apart.
doubht you can find a good 3B Chasis alone. Getting a decent 3B is hard enough. Most of them are abused and in very bad shape.
4x4addict is offline   (1) Thanks Reply With Quote
Old 28th April 2011, 17:57   #4
Hi Red Liner,
I havn't bought the axles yet. Can you suggest some place I can get a good MM 550 set with rear LSD and at what price?.
Thxs
joe3tom.
Hi 4x4addict,
Thanks for the input.Yes, as you rightly said finding a good CJ3B chassis is read hard.
joe3tom
Last edited by Jaggu : 28th April 2011 at 18:13. Reason: Back to back posts, please use Multi Quote (Quite+) instead. Thanks
Old 28th April 2011, 18:47   #5
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
I agree!
Robi's Invader has a KMT90? Which model Invader is it?
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 28th April 2011, 19:40   #6
DirtyDan's Avatar
Thanked: 776 Times
It seems to me that it would be much easier to have your original chassis fortified and reinforced at key stress points. Chassis damage merely from off roading is not that common. Of course, people do find ways to destroy their vehicles.
"Hardening" or reinforcing a chassis also has to be done by someone with experience. While you man is doing that it might be a good time to install skid plates. Do a search in this forum if you are unfamiliar with their function.
DirtyDan is offline   (2) Thanks Reply With Quote
Old 28th April 2011, 22:46   #7
Red Liner's Avatar
Originally Posted by SPIKE ARRESTOR View Post
I agree!
Spike
[quote=4x4addict;2331008]
You drive it first. I drove Sree's 550 which came with the NGT and Robbie's which came with the KMT. I dont know whether its factory fit, but it was so bloody smooth...I drove it partially Bangalore-Pune-Bangalore. My KMT almost feels like a ship's anchorage mechanism.
Both of you should try it too. Free rides in Munnar this week-end, last I heard
Red Liner is offline   Reply With Quote
Old 29th April 2011, 00:13   #8
jeepster's Avatar
Thanked: 1,035 Times
here is my list.
  • MDI 3200 TC DI engine
  • army MM 550 front axle with disc brakes & FFRA with LSD
  • NGT 520
  • BW manual shift
  • 4.88 Differential ratio
  • RCBT steering
but due to small wheelbase of cj3b you will have serious issues with rear prop shaft alignment & with its length. (so not recommended)
this drive train will be better in cj 500 or 550. (MWB)
BTW what type of armada chassis you have?
is it box section or C section?
box section chassis is not easy to cut & weld.
rgds,
Nikhil
jeepster is offline   (2) Thanks Reply With Quote
Old 29th April 2011, 08:28   #9
Thanked: 809 Times
Venky, Sree's 550 does not come with NGT AFAIK (unless he has done something very recently), IIRC both Viji and Sree had MM5x0 XDB model with them. Can anyone confirm this?
Spike
PS- What's wrong with your post? I'm not able to edit it.
Old 29th April 2011, 09:19   #10
Originally Posted by jeepster View Post
here is my list.
  • NGT 520
  • BW manual shift
  • RCBT steering
rgds,
Nikhil
Hi Jeepster,
I have a 'C' section chassis. I also have commander chassis, which is also a 'C' section. Do you think a commander chassis is also ok for the alteration. I belive its only a little longer than the MM540 or MM Major chassis which I understand is best suited for this modification.
Joe3tom.
Old 29th April 2011, 10:24   #11
ex670c's Avatar
Thanked: 1,821 Times
Hi Joe,
If you are keen on using a CJ3B, it is easier to use a XD3P+KMT90 with MM550 Front & Rear Axles.
The MDI3200TC is quite heavy compared to the XD3P (80Kgs Heavier).
Also the MDI3200TC has a very pronounced Crank Case, when fitted in an MM540, these disadvantage can be overcome to an great extent because it is easier to
i) Wider Track
ii) Taller Tyres (to compensate for Diff-Ratio)
The MM550XD uses a 4.88:1 Diff-Ratio, which can be used with a KMT90, but you need 31-32" Tall Tyres to get a speed of 60kmph.
The NGT520 will be a very tight fit in a CJ3B, 81" WB.
I would suggest you mod an MM540 to the above specs or if you want the CJ3B Looks, take a Mahindra MAJOR, and widen the Track and Lower Diff-Ratio with taller Tyres.
Arka
ex670c is offline   (2) Thanks Reply With Quote
Old 29th April 2011, 11:07   #12
Red Liner's Avatar
Spike
It always was with the NGT 5 speed - right from the time he got it. And so was Viji's green 550 jeep. So what if they are XDB? Wanna bet? Lets see now...what does Mahindra & Mahindra have that I will want...
No, I dont want the THAR
Old 29th April 2011, 12:05   #13
4x4addict's Avatar
@Sree's & Viji's jeep has the BA10 5 - Speed
Robbie's Invader has the Non Turbo MDI3200 with KMT90.
4x4addict is offline   Reply With Quote
Old 29th April 2011, 12:39   #14
Thanked: 809 Times
Hehehe, see below post-
Tini, you are right, I know this, now it is confirmed.
@Venky, if you still don't agree, you can call Viji / Sree and confirm, I can forward their contact numbers if required, they are located in Bangalore.
Spike
Old 29th April 2011, 15:04   #15
Red Liner's Avatar
I stand corrected. Like I said, I did not attend Arka's workshop this year - hence I got my facts wrong.
:P
Engine, Gearbox, Diff ratios, axles options for the JEEP Frankenstein 4x4 Technical 112 7th June 2018 23:17
Mahindra MDI3200 Engines Ashley Nair 4x4 Technical 15 26th November 2013 16:48
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
Changing Compression Ratio & Gear Ratio adheesh Technical Stuff 7 3rd October 2007 09:54
Variable compression ratio engine! amitoj Technical Stuff 8 20th December 2005 21:01
