Old 31st December 2010, 11:44   #16
ex670c's Avatar
Thanked: 1,820 Times
Default Re: Diff Lock for the Mahindra Classic
Originally Posted by Scion View Post
Arka, You had mentioned "front axle is difficult" what exactly did you mean? I hope you didn't mean the retrofit of locker into Front differential is difficult .
Interestingly, Eaton India is manufacturing the domestic version of Detroit Locker known as Mlocker.
Any idea on M Locker price?
Detroit Lockers in US are priced at ~ $630.00 EA.
Attachment 474722
Hi SD,
Fitting a Locker on the Front Axle of an IFS is very difficult, as you have to dismantle the entire front assy to access the Differential, as it it bolted to the Chassis.
Are you sure the INDIAN M-Locker is the legendary Detroit Locker, I think it is the unsuccessful Eaton GOV-LOCK (G-80 Locker)
Randy's Ring & Pinion.
Arka
Old 31st December 2010, 12:36   #17
Scion's Avatar
How about the MM540's front? would it be the same hardship retrofit effort as compared to IFS type?
You are right. MLockers are Eaton G80's. My Bad .
Scion is offline   Reply With Quote
Old 31st December 2010, 12:54   #18
ex670c's Avatar
How about the MM540's front? would it be the same hardship retrofit effort as compared to IFS type?.
Hi SD,
It is pretty simple in case of a Solid Axle.
For the Front Diff, is a Little more complicated than the Rear Diff (FFRA).
This is due to the Steering Knuckle. It takes a bit longer, to pull out and put back the Front Axles.
Arka
Old 28th January 2011, 14:06   #19
Wild_Card's Avatar
Is there anybody out there that has fitted a front locker to the IFS?
Wild_Card is offline   Reply With Quote
Old 1st February 2011, 11:48   #20
fiat_tarun's Avatar
Thanked: 640 Times
Eaton G80's are the Mlockers that are sold in GM vehicles. GM just brands the lockers G80.
All MLockers are basically the same technology wise, and they are modified to suit different axles and gear ratios
fiat_tarun is online now   (1) Thanks Reply With Quote
Old 25th December 2015, 11:58   #21
binu balan's Avatar
Thanked: 11 Times
Arka Sir, et all,
After reading this discussion, I've decided to import Lock-Right Dana 44, 19 Splines.
http://eastcoastgearsupply.com/i-289...line-open.html
What would be a good hub lock to import for my Classic (Stock) ? Any CJ3B compatible would do?
binu balan is offline   Reply With Quote
Old 25th December 2015, 12:40   #22
genesis's Avatar
Thanked: 309 Times
Originally Posted by binu balan View Post
Arka Sir, et all,
I have the same lockers in my CJ bought a few years ago from east coast gear supply. They work well.
Why do u want to import a hub lock? Lamda is decent.
genesis is offline   Reply With Quote
Old 25th December 2015, 19:51   #23
binu balan's Avatar
Thanked: 11 Times
Thanks. I was thinking of getting Warn hub locks. Not sure which one will fit in.
Old 8th January 2016, 21:01   #24
dhanushs's Avatar
Thanked: 4,504 Times
Arka Sir, et all,
http://eastcoastgearsupply.com/i-2894855-dana-44-powertrax-lock-right-2413-lr-19-spline-open.html
These do work well. However, you dont get the option to unlock the diffs when you require. They are automatic. With slightly more money (~10k) you can get Lambda Cable Operated Manual Diff Locks, which IMO are better.
Again Lamba makes hub locks for classic. You dont need to import it. Cost is ~4.5 k.
Mahindra: Difference between a Classic and CJ340 bhoise 4x4 Technical 81 25th September 2017 19:44
Indian Diff-Lock for the Dana44 19 & 30 Spline Axles ex670c 4x4 Technical 32 29th October 2016 12:20
Which Steering lock and Gear lock to buy? willy Modifications & Accessories 73 3rd September 2015 12:17
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Diff. Lock for the Safari Dicor... ranjit Technical Stuff 16 8th November 2006 02:02
