Old 30th August 2011, 12:05   #16
ex670c's Avatar
Thanked: 1,838 Times
Default Nissan Sd25
Originally Posted by jeepster View Post
hmm after the initial talks with Arka & raju bhai, i have decided not to use sd25 in armada.
so looks like sd25 will be used for generator for our FARM.
i have a contact in mumbai market so i am planning to buy a MDI CRDe. (mostly in 2012)
Originally Posted by drjones View Post
Whats Arka's point against SD25? I respect his opinion a lot, quite a genius.
Dr.Jones
Hi Doc. Jones,
I have nothing against the NISSAN SD25, but what advantages does it offer over the XD3P?
i) It is not a straight fit to any M&M 4WD Gear Box
ii) Though its is 2500cc it is 60-80Kgs heavier than the XD3P, just the the MDI3200TC.
iii) an MDI3200TC is a more viable option, keeping the above two in mind.
Arka
ex670c is offline   (2) Thanks Reply With Quote
Old 30th August 2011, 15:24   #17
Thanked: 655 Times
Default Re: PICS : Help with identifying this Mahindra engine
Originally Posted by Frankenstein View Post
Please dont listen to that heavy nonsense. Its slightly heavier to the XD3P but much lighter than the Di .
Seems very different from the sd25! The intake is different, the exhaust is different, the thermostat housing, water pump are different, heck, even the diesel injection pump is rotary compared to the inline SD25!
I don't know about the SD25, but this engine is very heavy and nowhere as light as the XD3P!
jyobeb is offline   Reply With Quote
Old 30th August 2011, 17:36   #18
jeepster's Avatar
Thanked: 1,046 Times
Originally Posted by ex670c View Post
H
no heart transplant till next year.
& it will be a mDI CRDe from xylo. (may change at the time of actual transplant)
so what engine is this??
my mechanic says that this also comes in some mm tractor.
rgds,
Nikhil
jeepster is offline   Reply With Quote
Old 30th August 2011, 17:46   #19
ex670c's Avatar
Attachment 601935
rgds,
Nikhil
Hi Nikhil,
IIRC that is MDI3200TC in a CRDe avatar.
Used in the M&M Genio Pick-Up Truck.
Arka
Old 30th August 2011, 18:03   #20
jeepster's Avatar
Hi Nikhil,
yes, MDI.
there is also a CRDE/I version of XD3p right?
http://www.team-bhp.com/forum/intern...tml#post730945 (The Mahindra Thar (for export only))
i was actually looking for that one.
any ways as i said no swap till next year, in the meantime i will get some information on various options of drive-train & some OTR experience,
so i can decide what i want & what i can get.
Old 30th August 2011, 21:10   #21
Thanked: 66 Times
Arka, AAAAaaahhhh!!! I want a light engine like the XD3P but with much more power, thats all Iam asking. Iam not satisfied with my XD3P's power { Mine is in top condition } cause Iam much used to it and Iam greedy, just that, I want a change. I don't mind a petrol engine too. The MDI 3200 TC, for me is slightly in the heavier side and doesn't rev much, kind of a low RPM high Torque engine. Common, help me out buddy.
Dr.Jones
drjones is offline   (1) Thanks Reply With Quote
Old 30th August 2011, 21:42   #22
headers's Avatar
Thanked: 464 Times
Dr.Jones
Doc - Options available to you AND ME!!
1. Eicher Canter Mitsubishi 4D31 - DOHC - 90HP @ 3200 RPM
2. Toyota 14BT - 90HP @ 3400 RPM
3. Toyota 3CT - 99HP @ 4200 RPM
4. Mahindra NEF 2.49 PUSHROD CRDe - 105 @ 4500 RPM
I'm on the lookout for an engine to which I can add AC without issues. Better NVH and sound levels are important too and I tend to lean towards a DOHC.
What do you guys think of the Tavera DI turbo Engine ? 19Kgm and 80 odd BHP?
Oops - EDIT - did i read Petrol engine ?
1. SKODA 1.8 TSI - 160 BHP
2. HONDA 3.0 V6 - 240 BHP
Old 30th August 2011, 21:59   #23
Thanked: 66 Times
Vikram, can you just mention which vehicle these engines come in, the 14BT and 3CT ? And it would be great if you can mention the weights of these engine if possible. Where the hell will find and mate the skoda and honda with my KMT 90? Its easier for me to mate Nicole Kidman than this ;-)
drjones is offline   (2) Thanks Reply With Quote
Old 31st August 2011, 00:59   #24
AVR
AVR's Avatar
Thanked: 626 Times
Headers - The 14B engine develops 98 bhp (as per some sites) and 114 bhp as per others. The 14B Turbo engine touches around 140 bhp.
Fitting an AC into the engine bay will be a tight squeeze but its possible. The vibrations are much lesser on the 14B compared to the XDP4.90. Noise is pretty high but my jeep has done only 200 kms since the transplant so should settle down once the fine tuning is done (tappets et al)
Also, I drove a 550 with a Tavera engine and gearbox recently. It was extremely smooth and works well. Only issue was that it was a 2wd and am not sure if 4wd is possible.
Cheers,
Adi
AVR is offline   Reply With Quote
Old 31st August 2011, 07:06   #25
headers's Avatar
Thanked: 464 Times
The 14B & 14BT comes in the DCM Toyota Dyna.. Toyota 3CT..no clue buddy!!
Agreed Adi, just posted the lowest figures I came across in the internet!!
Cheers,
Adi
Yeah, I was just thinking on similar lines - Even the 14B is not quiet
Old 31st August 2011, 10:27   #26
ex670c's Avatar
Default Engines
Arka, AAAAaaahhhh!!! I want a light engine like the XD3P but with much more power, thats all Iam asking. Iam not satisfied with my XD3P's power { Mine is in top condition } cause I am much used to it and I am greedy, just that, I want a change. I don't mind a petrol engine too. The MDI 3200 TC, for me is slightly in the heavier side and doesn't rev much, kind of a low RPM high Torque engine. Common, help me out buddy.
Dr.Jones
Hi Doc.Jones,
In the Light weight and rev-friendly dept not many can beat the XD3P.
i) Some options, do a Soft-Turbo to the XD3P.
ii) Isn't it easier to change your driving style
iii) Lockers/Shockers/Improve Steering to harness the maximum out of the XD3P!!!!
Petrol Engines Inline 4/6 RWD
1) Scorpio Petrol (1.9L)
2) Safari Petrol (2.1L)
3) Isuzu Petrol Engine & Gearbox.
3) Some BMW/Mercedes Petrol I6 engines are available in Chennai, but mating then to the KMT-90?????
Even if you go in for a Divorced T-Case there isn't enough room in a SWB.
AFAIK the Tavera Engine weighs close to 300Kgs.
@ Vikram, please tell the weight of the respective engines.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 31st August 2011, 10:35   #27
sreejeshmp's Avatar
Thanked: 576 Times
Default Re: Engines
Arka
Arka,
Can you please explain on this ? How and which Vehicle components can we use for this ? Is it help to improve the torque of the engine ? Or how can I improve the torque of XD3P Engine ?
- Sreejesh
sreejeshmp is offline   Reply With Quote
Old 31st August 2011, 10:44   #28
Thanked: 66 Times
Yes..Yes..how to get a soft turbo done on the XD3P?
drjones is offline   Reply With Quote
Old 31st August 2011, 11:06   #29
AVR
AVR's Avatar
Thanked: 626 Times
There was a blue 550 that came for EXAMM/AKC from Hyderabad which was running a turbo setup on the XD3P. IIRC, it was the scorpio turbo and intercooler. Still I'd believe this may not contribute much to low-end torque. But the owner was very happy with it and so he should be able to tell more. I think it was a Mr. Khan, Fazal bhai would know better.
Old 2nd September 2011, 00:49   #30
Frankenstein's Avatar
Thanked: 301 Times
Blue 550 with turbo is owned by Nawab Salik Khan of our team. It has a bolero turbo , low end is not changed from the stock engine but topend power is very good. I guess its time people realize the over rated XD3P is just an average engine .
Frankenstein is offline   Reply With Quote
Oil Pump Help : Identifying Issues & Preventive Maintenance? lodhra Technical Stuff 5 20th August 2013 14:45
Identifying Gypsy and Mahindra models? joshguy 4x4 Vehicles 36 21st June 2013 17:46
Please help in identifying decent resorts/hotel around Mussoorie TSEA Route / Travel Queries 1 11th April 2010 04:59
Please help identifying problem in my Swift ... abhaybakshi Technical Stuff 20 3rd February 2009 18:45
Help required with identifying Background score... adit1329 Shifting gears 10 27th March 2006 19:46
