Old 21st October 2011, 17:53   #46
sreejeshmp's Avatar
Thanked: 571 Times
Default Re: PICS : Help with identifying this Mahindra engine
Originally Posted by Frankenstein View Post
There are engines lying in HYD scrap yards. Contact someone in HYD,they go for around 15 to 20k and you have to overhaul them. Check properly if its a Nissan SD25 with Diesel Kiki pump. Parts are a problem though.
So That is Nissan SD25
"SD25 generates 15-16Kgm @ 1600-2000rpm for 250+ Kgs
XD3P generate 15-16Kgm @ 1800-2000Rpm for 194Kgs."
One more help Which Compatible Engine gives 20-25Kgm Torque ? I am looking for a Engine with torque (Cost effective) .
sreejeshmp is offline   Reply With Quote
Old 21st October 2011, 18:36   #47
headers's Avatar
Thanked: 459 Times
Go for the OLD SCORPIO 2.6 SZ. Heavy but TORQUE in the region you ask for and is cost effective!!
headers is offline   (1) Thanks Reply With Quote
Old 22nd October 2011, 10:30   #48
Frankenstein's Avatar
Thanked: 274 Times
How do you know the power ratings of both the engines, Have you tested them on a dyno?
Have you weighed them both?
Every year on teambhp the power of xd3p is going up and weight reducing. From 72bhp now its 75, from 13.5kgm its reaching 16 now. Wait for another 3 years and you will have a XD3P beating a 426 Hemi engine
Frankenstein is offline   Reply With Quote
Old 22nd October 2011, 14:23   #49
sreejeshmp's Avatar
Thanked: 571 Times
I got that info from post #39 . I am getting a smell of Engine rebuild within a year so thinking of engine replacement.
Old 22nd October 2011, 16:11   #50
Thanked: 274 Times
Dude pm your number, lets discuss
Old 22nd October 2011, 19:11   #51
headers's Avatar
Thanked: 459 Times
Hi frankie,
Which according to you is the best and ideal engine for a jeep?
I need on road performance and off road performance
Old 22nd October 2011, 20:06   #52
Thanked: 274 Times
Originally Posted by headers View Post
Hi frankie,
Headers i cannot give you technical knowledge, but with my limited experience have driven them on and off i can comment .IF is its good its good .
Ideal engine depends on your budget .Because it really becomes ideal not only with the engine but the transmission too.
Ideal on budget , from what i know ,
SD25,
Om616 with kiki.
Budget around 1L,,
Isuzu G1 with isuzu MSG 5 speed GB.
Toyota 3c turbo with Isuzu msg
Nothing more i can think of, DCM, BD30 are not so ideal tough. Lot of alteration , more NVH and they are not tried and tested for many years like the others.
For your purpose , G1 is the best , i say it again, you can cruise at 120km on road with 4.27 as well as beat a xd3p 550 (4.88) offroad with 4.27. Dont ask me how it is possible, i have seen it. Drive it one day and you tell me how its possible
Frankenstein is offline   (2) Thanks Reply With Quote
Old 22nd October 2011, 20:37   #53
Thanked: 822 Times
Excuse me gentlemen for my ( ) question ; but what is meant by KIKI ( fuel distributor pump ) ??
does it mean all mechanical system ( & non CEDE ) ??
Sudarshan
P.S. I think the Mico nozels will work with some different pressure settings than OE/spec ( Just a thought ).
Sudarshan is offline   Reply With Quote
Old 22nd October 2011, 20:49   #54
sreejeshmp's Avatar
Thanked: 571 Times
The Mitsubishi 4D31
Engine Specifications :- (Goooooogle)
Type: 4D31. water cooled 4 cylinder in line direct injection Diesel Engine.
Bore: 100 mm
Stroke: 105 mm
Capacity” 3298 cc
Compression Ratio: 17.5 : 1
Brake Power: 68 kW at 3500 RPM (91HP)
Torque: 221 Nm at 2200 RPM
What about the size and weight ? Is it possible to fit in a 550 with KMT90 ?
Old 22nd October 2011, 21:02   #55
headers's Avatar
Thanked: 459 Times
The Mitsubishi 4D31
Bore: 100 mm
Stroke: 105 mm
Capacity” 3298 cc
Boss: Apparently this engine is a favorite of mine. The height of the engine could pose problems for installing it in a 540/550!!
Old 22nd October 2011, 21:13   #56
Thanked: 274 Times
Sudarshan
Diesel kiki is a IDI mechanical pump used by some Nissan and Mitsubishi engines.
Sreejesh , i dont know of anyone who plonked a Mitsubishi engine .
Old 22nd October 2011, 21:22   #57
sreejeshmp's Avatar
Thanked: 571 Times
Can you please tell the height of the engine?
Old 22nd October 2011, 21:29   #58
Thanked: 274 Times
Why dont you experiment with the Cummins 4bt , 34 kgm at idling , how does that sound
Old 22nd October 2011, 21:38   #59
headers's Avatar
Thanked: 459 Times
I have not measured it, but one seeing the engine alongwith Toyota 14B, Mazda, and Isuzu engines, this one is TALL..by almost 6 odd inches.
We may be able to mount it etc, but the efficient offroad ability will take a hit.
The best I'm told is the Toyota 14B that comes off a DCM Toyota light truck. Spares are not that much an issue too.
BTW, the ISUZU powerplants are good. Unless you have the isuzu 5 speed 4wd GBs, it does not make sense for that powerplant at all!! Isuzu 4 speed aint good enough to harness the engine!
The isuzu engines are apparently the best in NVH of the above lot as they are SOHC engines.
The 4D31 is a DOHC one though
Old 22nd October 2011, 21:42   #60
sreejeshmp's Avatar
Thanked: 571 Times
As I mentioned I need an engine with 20-25 kgm In a cost effective way
Oil Pump Help : Identifying Issues & Preventive Maintenance? lodhra Technical Stuff 5 20th August 2013 14:45
Identifying Gypsy and Mahindra models? joshguy 4x4 Vehicles 36 21st June 2013 17:46
Please help in identifying decent resorts/hotel around Mussoorie TSEA Route / Travel Queries 1 11th April 2010 04:59
Please help identifying problem in my Swift ... abhaybakshi Technical Stuff 20 3rd February 2009 18:45
Help required with identifying Background score... adit1329 Shifting gears 10 27th March 2006 19:46
