Old 18th August 2011, 17:41   #31
ex670c's Avatar
Thanked: 1,799 Times
Default Re: Engine, Gearbox, Diff ratios, axles options for the JEEP
[quote=Frankenstein;2472364
diesel_maniac the older RD 28 is an 8 valve engine and later one is a 12 valve . For the latest truck engine the vaccum venturi is on top of the tappet cover.[/quote]
Hi Franky,
Please check 8 Valves for 6 Cylinder!!!!! Any 6 Cyl will have 12 Valves.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 18th August 2011, 18:32   #32
Frankenstein's Avatar
Thanked: 274 Times
SORRY , its 12 valves for the old engine and 18 valves for the new one. Was little busy while posting earlier hence the error.
Frankenstein is offline   (2) Thanks Reply With Quote
Old 18th August 2011, 21:34   #33
V-16's Avatar
Thanked: 848 Times
Originally Posted by Frankenstein View Post
Sammy in Delhi there are 2006 MM550s being disposed. IT has every thing you want with a 5 speed BA10 gear box. Buy that and change the engine. You will save a lot of cash.
Hi Franky, are these NGCS being sold in Mayapuri as disposals or with a private seller. I am interested. Could you tell me what the price should be? Thanks in anticipation.
V-16 is offline   Reply With Quote
Old 5th September 2011, 11:35   #34
regnex's Avatar
A little odd question from my side.
Has anybody converted the MM650 to a 4 door hard top? is it possible to do so? similar to the Marshal?
thanks
regnex is offline   Reply With Quote
Old 28th September 2011, 16:26   #35
sammyaulakh's Avatar
Thanked: 21 Times
I came across a Nissan 4 cylinder turbo engine known as the CD 20T.It develops
90 bhp @ 4400 rpm and 18.8 kgm of torque @ 2400 rpm which is a little less than
what the RD28 develops but at the same time it is lighter than the rd28. would the
lesser weight compensate for the less power it develops if mated to Isuzu 5 speed
4 wheel drive gear for a mm550 ngcs.
sammyaulakh is offline   Reply With Quote
Old 28th September 2011, 21:54   #36
Thanked: 274 Times
V16 that guy was quoting around 2.8L for the 2006 which ran only 20k kms. No work on the 550 . I ll get you the contact tomorrow
Frankenstein is offline   (1) Thanks Reply With Quote
Old 29th September 2011, 08:44   #37
headers's Avatar
Thanked: 457 Times
Sandeep, post the details here - Your delhi contacts, so all of us have the number for reference.
BTW, does he give a discount if referred by you? Or do we get a LEMON?
Old 29th September 2011, 09:54   #38
Thanked: 274 Times
I cant post any details here as people will start calling and he will jack up the price. Same thing happened with the winch contact. Now no more stock
Dont know about discount. IF he see s a lemon approaching him , he might sell the lemon a lemon.
Frankenstein is offline   Reply With Quote
Old 29th September 2011, 12:03   #39
Thanked: 21 Times
@ sandeep sir
please let me know what do you think of the above mentioned setup.Waiting for your reply.Should i go ahead with it or stick with the RD.
Old 29th September 2011, 18:39   #40
V-16's Avatar
Thanked: 848 Times
Quite right. I agree with you.Thanks
Old 23rd October 2011, 17:41   #41
shekaran's Avatar
Thanked: 63 Times
i have changed the diff ratio in my MM540 from 4.88 (44/9) to 4.27 (47/11). my jeep is running on a completely rebuilt XDP4.90 engine with the usual KMT90/TC combo.
so, after 200 kms of highway running and 50 kms of city driving : (No Offroading)
1. the jeep as usual starts moving in 2nd gear itself, on plain roads - (idle) without any throttle input. lesser engine rpm in each gear seems pretty much feel a smoother engine - illususionary effect. but less NVH is the biggest advantage. MM540 feels/drives now like a CAR.
2. steep inclines now need 1st gear - which was not so earlier. mild inclines can be done in 2nd but with some clutch - slight throttle pedalling. earlier my jeep used to drive up service station ramps in 2nd gear itself, with no additional throttle other than idle speed. 3rd gear is a potent overtaking tool especially in city traffic.
3. top speed is approx. 110kmph, pls note approx. as my speedo was showing only 90kmph at full throttle. speedo error in the range of -20kmph range.
4. i can stay longer in the gears, for eg. in city traffic, earlier i need to keep on juggling between 2nd and 3rd - now, i can stay in 2nd or 3rd, depending on traffic speed conditions. Backlash effects have been minimised, almost non existent now.
5. the 70kmph cruising speeds have become more smoother, with the lesser engine rpm. but if your speeds drop below 35kmph, you need to downshift to 3rd, and after some revs, back to 4th. below 40kmph in 4th gear - i feel like am lugging the engine.
Cheers.
shekaran is offline   (2) Thanks Reply With Quote
Old 25th October 2011, 08:20   #42
headers's Avatar
Thanked: 457 Times
^^ Are you sure? Cos I get 70 effortlessly with 4.88 and am able to use 3 and 4 in city from 15 kph onwards. I have pushed upto 105
with 3 and 4, life is happy and traffic jams bring on 2.
Old 14th November 2011, 11:32   #43
Thanked: 12 Times
hello guys...
I own a Nissan Cedric with the same RD28 engine... I need engine gasket...Please help me in sourcin the part
Vintagegarden is offline   Reply With Quote
Old 18th December 2011, 13:04   #44
What are the petrol options for a 3b, with emphasis on better fe and reliability.
I am planning on an upgrade from my hurricane
docfreak is offline   Reply With Quote
Old 18th December 2011, 16:34   #45
headers's Avatar
Thanked: 457 Times
Isuzu 1.8 MPFi - Contessa Petrol Engine.
Indian Diff-Lock for the Dana44 19 & 30 Spline Axles ex670c 4x4 Technical 32 29th October 2016 12:20
57" OKBJ Axles breaking with powerful engine dhanushs 4x4 Technical 12 8th April 2015 13:01
Mahindra Major 4x4 jeep- A/C & Power Steering, Diff. locks, Snorkel amit kumar 4x4 Technical 5 24th December 2009 10:22
Willys Jeep Engine & Gearbox Swap dinya Modifications & Accessories 5 17th November 2005 10:06
