Old 26th March 2013, 08:29   #61
headers's Avatar
Thanked: 463 Times
Default Re: Engine, Gearbox, Diff ratios, axles options for the JEEP
Originally Posted by Frankenstein View Post
First pic , towards the left is a isuzu 4bd1 engine and towards the right is the dcm toyota 14b .
2nd pic is of a willys hurricane
3rd pic is of a nissan bd30 into the toyota fj 40
4th pic is of a cj2a body bought from phillipinnes. We have one dozen phillipino Jeeps.
@ Sandeep: Just curious, what do you do with the Phillipino jeeps? What is the cost of sourcing the same? Why from Philliphines? What is different?
Old 23rd May 2013, 13:03   #62
MonsterPatrol's Avatar
Thanked: 135 Times
Is it possible to mount a baleno engine on a Willys CJ. if so what might be the gearbox and axle combinations that might work perfectly?
MonsterPatrol is offline   Reply With Quote
Old 15th June 2013, 17:28   #63
Thanked: 135 Times
I will post all the engines , gearboxes, axles and Diff ratios used in JEEPS in India .
ENGINES: BHP/TORQUE
Peugeot Range of engines.
XDP4.9 62bhp/12.3kgm
XD3P 73bhp/15.5kgm
XD2S 80bhp/?
TUD5 58bhp/10kgm
MAHINDRA RANGE OF ENGINES
International B275 38bhp/12kgm
International B475 43bhp/?
International B575 59bhp/15.5kgm
MDI 3000 55bhp/16kgm
MDI3200TC 63bhp/18kgm
M eagle 104bhp/24kgm
2.6 SZ PLUS 109bhp/26kgm
2.6 CRDE 115bhp/28kgm
2.2 Mhawk 140bhp/29kgm
ISUZU RANGE OF ENGINES
4ZBI(petrol) 75bhp/13.3kgm
4FB1 58bhp/10.5kgm
4FC1 65bhp/
4FD1 75bhp/
4FG1 78bhp/15.5kgm
4FG1 TC 86bhp/16.5kgm
4JG2 100bhp/26kgm
4JG2 TC 120bhp/28kgm
TOYOTA RANGE ENGINES
Qualis engine 75bhp/15kgm
1N 54bhp/9kgm
2C 70bhp/13kgm
2C TC ?/?
3C ?/?
3C TC ?/?
G13B ?/?
G14B 100bhp/28kgm
Kirloskar ?/?
PERKINS ENGINE RANGE
P3 ?/?
P4 ?/?
P6 ?/?
SIMPSONS ENGINE RANGE
S3 ?/?
S4.
NISSAN RANGE
BD 25
BD30 100bhp/22kgm
RD 28 ,6 pot 100bhp/18kgm
SUZUKI RANGE OF ENGINES
Gypsy 1L engine 45bhp/?
Gypsy 1.3L engine 80bhp/10.3kgm
Baleno 1.6L engine 93bhp/13.2kgm
TATA RANGE ENGINES
2.0 TCIC 68bhp/12kgm
3.0 (407) 60bhp/16kgm
MATADOR(force) RANGE
305 ?/?
307(om616) 68bhp/13kgm
WILLYS ENGINES
F-HEAD 134 HURRICANE 75bhp/15.5kgm
L-HEAD 134 GO-DEVIL 60bhp/14.2kgm
4WD GEARBOXES USED:
Peugeot BA10-5 SPEED
Mahindra NGT520-5SPEED
Mahindra NGT530R-5 SPEED
KMT-90 -4 SPEED
T-84 -3 SPEED
T-90 -3 SPEED
Low ratio T-90 (FC TRUCK)
Isuzu MUA5 5 SPEED
Isuzu 4 speed
Mitsubushi/Kia 4 speed
Gypsy GB 5 speed
I have driven , seen heard most of the above mentioned engine/GB transplants done in JEEPs in India.
DIFFERENTIAL RATIOS / CROWN PINION.
These are the different differential ratios used for Jeeps in India.
3.73:1 FOR EASY CRUISING
4.27:1 CRUISING
4.88:1 BALANCE BETWEEN CRUISING AND LOW END TORQUE
5.38:1 MORE OF LOW END TORQUE
5.89:1. MAXIMUM CRAWL RATIO FOR ROCK CRAWLING.
Please add if i have missed anything.
Note: low end torque and cruising speed may differ from engine to engine and Transmission to transmission and both together.
Here goes the axles options for Jeeps.
CKKP (Closed Knuckle King Pin)
48.5" Front Track 10 Spline & 19 Spline (CJ3A/CJ3B/CJ340/CL340/Cdr650)
51" Front Track 19 Spline (MM540/MM550XD/Cdr750)
58" Front Track 19 Spline (FC Van)
Rear Axle
51" Front Track 19 Spline & 30 Spline MM550XD (MM540/MM550XD/Cdr750)
OKBJ (Open Knuckle Ball-Joint)
51" Track M&M Major/Cdr 750 (NGCS) 19 Spline
57" Track Bolero/Pikup MM550XD (NGCS) 19 Spline
Rear 1 Piece FFRA (53" Track)
1) MM550XD/Bolero/Pickup Series (19 Spline)
Rear 1 piece SFRA (53" Track)
Scorpio/Bolero Invader/Pickup Series.
All the Above a DANA44 (19 Spline or 30 Spline with 2 Carrier Breaks)
I am not able to recollect some other options, Please add if i have missed out something.
Hi guys, I was looking for a similar thread for quite some time and finally found it. I own a 57 willys CJ2A and Im currently looking for the best possible and a hassle free option for an engine gearbox swap. I am currently running a peugeot engine on it with the original 3 speed gearbox with 4x4. Im planning to install 31 inch MTs on it so i dont think the peugeot engine's performance will be enough to move the bigger tires, atleast not in offroad conditions. A mechanic once told me contessa petrol engine is a good option for it but i forgot which 4x4 gearbox he mentioned would be mated best to it. I am looking for a petrol engine setup with a good 4x4 gearbox. I do alot of highway driving as well as offroad so a balanced setup would be good. My preference is a petrol engine with good low end torque.Can the experts help me with some best possible combinations?
MonsterPatrol is offline   (1) Thanks Reply With Quote
Old 20th November 2013, 14:18   #64
Frankenstein's Avatar
Thanked: 300 Times
Hi monster patrol, if you want to retain the existing setup , just change the 3 speed gb to kmt 90 and that will give enough power to use 31" tires on a swb jeep.
2nd option is to use the existing3 speed gb with the diesel engine and change the top and counter gear to fc truck gears, this will aslo give the the required power.
IF petrol only the use the isuzu 4zb1 petrol engine common in the ambys and conti with a isuzu 4 speed gearbox and 4.27 diff ratio.
Frankenstein is offline   Reply With Quote
Old 24th April 2014, 02:08   #65
Default Re: All T-BHP 4x4 JEEP Pics!!
Hi Guys,bought 1974 cj4A and got work started.Need some advise from you Jeep lovers regarding the best D/Engine for this jeep.Right now it has a petrol engine in it but need to change it.PLEASE Advise
P.SINGH is offline   Reply With Quote
Old 24th April 2014, 10:31   #66
Shubhendra's Avatar
Thanked: 1,180 Times
Dear Mr. P. Singh,
If you want to retain current gearbox and transfer case then i would suggest you to go for Mahindra Di (without turbo) engine. it mates well with said gearbox and work beautifully. However, if your monthly running is less you can consider using petrol engine, now days there is hardly difference of 20 rs between petrol and diesel and cost/effort/time you incur for conversion would not offset until your running is high.
Shubhendra Singh
Shubhendra is offline   Reply With Quote
Old 24th April 2014, 10:33   #67
cpbopanna's Avatar
Thanked: 798 Times
In my opinion, you should avoid an International Harvester based engine (MD/MDI) which is heavy and will spoil the driving dynamics of a CJ-4A.
The much lighter Peugeot (XDP 4.90) mated to a KMT 90 gearbox is a better choice!
Of course, the fuel efficiency of an XDP is relatively lower, but take it from me, in the long run, this combination is reliable, trouble-free and cheap to maintain!
cpbopanna is offline   Reply With Quote
Old 25th April 2014, 12:13   #68
Shubhendra's Avatar
Dear Mr Bopanna,
Are you sure that XDP4.9 is trouble free in long term compared to Di engine?
think about exterme summer days in north (when this engine may overheat) and chilling winter (when this engine has to be in perfect condition to start early morning). Though i am using XDP4.9 for years but i still feel if its not for speed then Di is any day better.
BTW how much is the weight difference between XDP4.9 and MDI engine ?
Shubhendra
Old 1st May 2014, 02:43   #69
Finally its just waiting for a transplant of engine n gearbox . Thank you for your tips but how about a Scorpio engine n g/box.
Old 1st May 2014, 23:14   #70
cpbopanna's Avatar
Thanked: 798 Times
Originally Posted by Shubhendra View Post
Dear Mr Bopanna,
Shubhendra
Shubhendra
I have used both XDP 4.90 and MD 2350 engines for more than 25 years.
As long as the thermostat of the XDP is removed (the thermostats are known to fail causing overheating and a rupture of the head gasket) and the road speed does not exceed 80 kmph, I have not seen overheating - of course I use stock reduction of 4.88:1.
During the Coorg chills (probably not as cold as in northern India), preheating twice or thrice results in the engine starting at first crank.
If the XDP is well looked after (I used only Castrol Deusol Super earlier and Castrol CRB plus later), it is trouble free and when required, re-building the engine is very economical compared to an XD 3P.
I replaced the piston rings and sleeves after 15 years, that was the only major repair EVER carried out on my XDP engined MM 540!
Before the DI engines were introduced, both the XDP 4.90 and MD 2350 engines were equally (non) silent. The MDI 3200 is obviously noisier than the MD 2350 because of the intrinsic nature of DI engines (no pre-chamber combustion which deadens the sound to some extent)
Insofar as the engine weights are concerned, an XDP 4.90 is 184 Kg whereas a MDI 3200 is 260 Kg!
Cheers!
cpbopanna is offline   (1) Thanks Reply With Quote
Old 19th February 2016, 19:21   #71
wrongturn's Avatar
Thanked: 466 Times
Hi guys & gurus, I would really love to get your inputs on a project I am thinking about.
I have a Verito at my disposal and I intend to use its every part in building up a Jeep. Engine is working, and well power steering and other parts might be of use too.
Now 1.5 TDCI is a gem of an engine and this one has less than 25k KMs on it. This car is mine and was just 1 year old when it met with an accident, since it was lying in a yard waiting for the legal proceedings to get over.
There are people here who are saying they can transplant this engine to a jeep bay.
Now, I have asked a lot of guys around and have received mixed views about it, majorly:
1. Scrap the verito and buy a jeep.
2. get verito repaired and then sell it to buy Jeep
3. Renault's 1.5L engine would not be sufficient for a Jeep and will be under powered.
4. It may fit but will have reliability issues.
I already have a Xylo, Dzire, City and M800 automatic. I need a jeep. Please advice.
Engine, Gearbox, Diff ratios, axles options for the JEEP-screenshot_20160219190100.png
Engine, Gearbox, Diff ratios, axles options for the JEEP-screenshot_20160219190138.png
Engine, Gearbox, Diff ratios, axles options for the JEEP-img20160219wa00291.jpg
wrongturn is online now   Reply With Quote
Old 29th February 2016, 21:45   #72
dhanushs's Avatar
Thanked: 4,437 Times
My sincere advise is to scrap the Verito and buy a Jeep.
1. The engine transplant, even if done will definitely have reliability issues, and you will need to run a lot of kilometers to sort it out. Not worth the time and money, if its not for a specific purpose, IMO.
2. The engine even if transplanted makes the Jeep unworthy of an RC Book. You will get into big trouble if it gets involved in an accident.
3. For the amount of time and money you need to spend to put that Verito engine into the Jeep, you might as well buy a 2nd hand Jeep. A running condition 2WD 540 can be got for as low as 65-75k. For 1lac you can easily get an OK or even good condition one.
I understand that you are trying to find use for that Verito somehow for your Jeep, but, trust me, its not worth it.
dhanushs is offline   (3) Thanks Reply With Quote
Old 5th March 2016, 20:36   #73
Thanked: 58 Times
Could any one help identifying which vehicles in India come with the Dana 60 axle?
thanks -
lugnut is offline   Reply With Quote
Old 7th March 2016, 12:27   #74
ex670c's Avatar
Thanked: 1,816 Times
thanks -
Hi Lugnut,
The Mahindra Tourister comes with a REAR Dana 60.
papaboost and prabhuav will be able to give more details.
Arka
Old 11th March 2016, 11:16   #75
wrongturn's Avatar
Thanked: 466 Times
Thanks a lot, I will be doing that. Would sell Verito and invest that money in building a proper jeep and hey am going to need a lot of help and advice from you. You have built yourself a BEAST of a jeep and it's one of the motivating factor why I want to build myself one of those. Thank you.
Indian Diff-Lock for the Dana44 19 & 30 Spline Axles ex670c 4x4 Technical 32 29th October 2016 12:20
57" OKBJ Axles breaking with powerful engine dhanushs 4x4 Technical 12 8th April 2015 13:01
Mahindra Major 4x4 jeep- A/C & Power Steering, Diff. locks, Snorkel amit kumar 4x4 Technical 5 24th December 2009 10:22
Willys Jeep Engine & Gearbox Swap dinya Modifications & Accessories 5 17th November 2005 10:06
