Old 4th April 2016, 15:27   #76
scorpian's Avatar
Thanked: 221 Times
Default Re: Engine, Gearbox, Diff ratios, axles options for the JEEP
Guys i dont know where to post this, but i am very eager to know what and why has this been done and whether it actually works.
I saw this on olx.
Engine, Gearbox, Diff ratios, axles options for the JEEP-154789235_1_1000x700_sixwheeljeepmodifiedmadgaon_rev003.jpg
scorpian is offline   Reply With Quote
Old 4th April 2016, 15:46   #77
Shubhendra's Avatar
Thanked: 1,180 Times
I saw this on olx.
Nope. Its a regular2x4 or 4x4 where last axle is not live.
All show, no go !
Shubhendra Singh
Shubhendra is offline   Reply With Quote
Old 4th April 2016, 15:52   #78
scorpian's Avatar
Thanked: 221 Times
Thank you sirji.
Just extra weight to chug around i believe.
Old 5th April 2016, 22:20   #79
wanderernomad's Avatar
Thanked: 790 Times
It doesn't even look to be a 4x4. It's all being and that too, to a select few only.
wanderernomad is offline   Reply With Quote
Old 4th September 2016, 12:30   #80
Hi can I fit a baleno old model engine and gearbox in my cj3b?
Coby537 is offline   Reply With Quote
Old 5th September 2016, 13:59   #81
4x4addict's Avatar
Thanked: 2,651 Times
You need to install adapter plate between the engine & gearbox.
4x4addict is offline   Reply With Quote
Old 19th September 2016, 15:22   #82
Someone told me that the engine wouldn't fit, is that the true?
Old 19th September 2016, 16:32   #83
4x4addict's Avatar
The Baleno Engine is transversely mounted power-train. It will not fit directly. You can use the engine and use any longitudely mounted gearbox to mate it to. You cannot use a Baleno gearbox as it is front wheel drive.
Old 19th September 2016, 16:57   #84
dhanushs's Avatar
Thanked: 4,472 Times
If you really want to do it, you can get a Baleno engine, a Gypsy 5 + 1 GB, and TC and fit it. The engine will fit.
Old 19th September 2016, 17:33   #85
That's what I thought initially now its confirmed. Sorry but what did you mean by TC?
Old 19th September 2016, 23:04   #86
Thanked: 790 Times
TC means transfer case.
Old 20th September 2016, 13:19   #87
4x4addict's Avatar
Dhanus, Will the gypsy 5+1 and TC fit inside a SWB CJ3B? Has anyone done it?
Old 20th September 2016, 15:40   #88
dhanushs's Avatar
Have a feeling someone from BODA has done it.
Old 10th November 2016, 11:20   #89
Thanked: 790 Times
I have a Pugeot XD4.9P with KMT 90 Tcase in my cj500dp. If I want to replace the engine but retain the existing 4X4 and the transfer case, what engine options do I have?
Old 10th November 2016, 11:53   #90
cpbopanna's Avatar
Thanked: 798 Times
Please consider the new MDi turbo (non CRD). The engine is economical and will remain trouble-free for long!
cpbopanna is offline   (1) Thanks Reply With Quote
Indian Diff-Lock for the Dana44 19 & 30 Spline Axles ex670c 4x4 Technical 32 29th October 2016 12:20
57" OKBJ Axles breaking with powerful engine dhanushs 4x4 Technical 12 8th April 2015 13:01
Mahindra Major 4x4 jeep- A/C & Power Steering, Diff. locks, Snorkel amit kumar 4x4 Technical 5 24th December 2009 10:22
Willys Jeep Engine & Gearbox Swap dinya Modifications & Accessories 5 17th November 2005 10:06
