Old 23rd May 2011, 07:06   #1
Thanked: 822 Times
Question 160 PCD Hub on full floating axle?
I want to know from Bhpians
Can a new type of wheel Hub (M&M) having larger PCD of 160 ( typically found on Army NGCS 550, Utility, savari etc ) be fitted on the old type full floating axles ( like 540 front , commander front & rear etc )
For this do I need to change the
1) spindle ( locally called as ' Chillim ' ) or stub etc
2) brake drums & liner plate etc
Want to shift to 160 PCD of my old 540 ( converted to FFRA ) to go for 7.50 X 16 sets of tyres & discs which will be common for my Landy ( 160 PCD ) & Jeep . ( Now 140 )
Any help Appreciated
Sudarshan
P. S. I think many will be interested in this as larger hubs are stronger ones for 4x4 terrain operations
Sudarshan is offline   Reply With Quote
Old 23rd May 2011, 09:25   #2
jeepster's Avatar
Thanked: 984 Times
Default Re: Jeep Hubs
yes its possible to change the hubs with new 160 PCD.
the new parts are direct fit. (MARSHAL/ARMADA/army550 as these had CKKP axles up front)
but i dont know the exact parts & procedure of the swap.
jeepster is offline   Reply With Quote
Old 23rd May 2011, 10:38   #3
ex670c's Avatar
Thanked: 1,799 Times
Sudarshan
Hi Sudarshan JEEP,
If you change the PCD to I60, then you will have to change the front Knuckle to Armada 98 or Armada Grand.
The Back spacing for M&M 160 PCD wheel disc is more than their 140 PCD Wheel Discs, and there will be fouling with the Track Link in lock to lock situations .
Older model brake Liners can be used.
The Newer Spindle is heavier/stouter/stronger (IIRC)
Also the Larger Hubs have a different PCD for the Axle Flange (8bolt vs 6bolt)
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 24th May 2011, 09:04   #4
Thanked: 822 Times
Are you 100% sure on this ? Anyone has done this before ? Please ask your mech about this ( the old & new parts comparison ) .
Also if he has any old/scrap parts of the 160 ( new type ) hub or anything please bring it for me to be used as samples .
Dont worry , its a matter of time .
Explain more , didnt understand / dont know much on this .
What about the Tata discs ? especially the 207 version ? they look much better ( for this job )
Also I have another set of Landy Discs which I think dont go 'Inside' Much
what about the brake plate ( Liner plate ) mounting hole PCD is same as old ?
will be better then
Think this can be managed
All & all I think this conversion will give lesser problems in terms of setting of hub bearings frequently ( when heavy/larger tyres are used )
Sudarshan
Can 112 PCD alloys fit into 114.3mm Hub? iTNerd Tyre & Alloy wheel Section 8 7th August 2012 10:58
Axles: Live/Dead, Semi/Full Floating etc.. khan_sultan 4x4 Technical 52 28th December 2010 00:38
Honda Jazz - Floating in my little glass bubble cpyder Test-Drives & Initial Ownership Reports 71 15th October 2009 23:15
Are loan interests going down ? Floating rate is worth of? neo_trace Indian Car Loans & Insurance 10 8th October 2007 15:38
Toyota Qualis, what's its PCD? riffst3r Technical Stuff 1 22nd February 2005 20:50
