Old 1st June 2011, 23:05   #1
Default Leaf Springs for Mahindra CL500/550
I would like to know what is the standard number of leaf springs that comes standard with CL500/CL550 Mahindra jeeps. The reason being, in the second hand Jeep I purchased the number of leaf springs seems to be not even between front and rear and also between the rear left and right.
renjithv is offline   Reply With Quote
Old 2nd June 2011, 19:08   #2
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Default Re: Leaf Springs for Mahindra CL500/550
Renjith, the number of leaves between any two pairs either front or back must be same. The no. of leaves at front and back as a whole can differ. If you are saying the Left and Right side leaf count at Rear is different, then it is ABSOLUTELY INCORRECT, please get it corrected ASAP. I am giving you the part nos. of leaf springs used in CL550 (latest gen).
Front Spring assy- 0075601 (Complete set)
Rear Spring assy- 0402AA0530N (Complete set)
If you need any other info, let me know.
Spike
PS- I am sorry for this late reply as I somehow missed it, thanking GTO for routing me to this query. Cheers!
SPIKE ARRESTOR is offline   Reply With Quote
Old 3rd June 2011, 10:36   #3
ex670c's Avatar
Thanked: 1,799 Times
Default Leaf Spring
Hi Renjith,
The CJ3B/CJ340/CJ500D/MM540/MM550XD.
Have the same length Leaf Springs Front & Rear.
The Front is interchangeable amongst all other front Sets.
The Rear Leaf Spring is interchangeable amongst all other Rear Sets.
Also the no. of leaves in Front Left and Front Right are same
The
no. of leaves in Rear Left and Rear Right are same.
The Length of the corresponding leaf springs in the pack must be same. No use having same no. of leaves and the sequence and length are different when fitted in the pack.
CJ3B Military Front 10 Rear 11
Classic Front 7 Rear 8
MM540 Front 8 Rear 9
MM550XD Front 10 Rear 12
You can customise the no. of leaves in your spring pack depending on what you what, in terms of ride, roll, articulation.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Composite Fibre Leaf Springs: Can they be used for off-roading? khan_sultan 4x4 Technical 357 27th November 2016 07:41
Buying a Mahindra CL500 MDI? antonjeeper 4x4 Vehicles 22 29th July 2016 14:23
The elusive MM540 / 550. EDIT: New Search for ex-Army 550 on page 9 IronWolf 4x4 Vehicles 146 13th February 2015 23:02
OME Leaf Springs for the Gypsy satan 4x4 Technical 16 2nd June 2011 10:00
Torsion bar or leaf/coil springs. Which is better ? taurian2804 Technical Stuff 4 9th November 2009 11:07
