Old 23rd June 2011, 14:24   #1
Tejas@perioimpl's Avatar
Thanked: 5,058 Times
Thumbs up Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestions
Haven't you wondered many times while offroading, "i wish i had that feature" or "i need to add this in my jeep"
This thread doesn't talk about mods like engines swaps, snorkels, dif locks and stuff like that which has been discussed in other threads very well.
What i want to share here is non essential but practical modifications.
1. Windshield washers
A run through muck will plaster your windscreen with mud and frankly the two nozzles provided are just not enough. Get atleast four twin nozzles with a good pressure pump installed and directed towards the entire of the windscreen.
If you get a mist type sprayer, much better.
2. Clean ORVMs
This is one thing i'm trying to figure out how to make it work. Again the ORVMs get dirty after offroading and ideally if i could spray that with water, it'll be great. But running water pipes through the doors won't be practical. Next best thing, get the small rubber windshield cleaners that the attendants at petrol pumps use to clean your glass. Wet the mirror with water and clean.
3. Day/night IRVM
Nearly every car nowadays comes with day/night internal rear view mirrors. Get a bracket made and install those. Useful for people who drive old jeeps and cannot run away from the trucks that are behind you with their headlights on full blast.
4. Cubby holes
Make a lot of cubby holes for odds and ends in your dash. Older jeeps have a metal dash and it's easy to make these and 4x4s with plastic dash should have the pocket type mobile holders. These come very handy to put your mobile, cig packets, toll receipts etc.
Have a dedicated bigger cubby hole with perforations to put in rags and pieces of cloths to clean the car.
5. Hooks
A few hooks on the dash or the roll cage are really helpful. Can be used for night otrs to hang your torch, bags to discard waste, etc.
Make sure the hooks are blunt and don't have pointed tips or you may hurt yourself
6. Lockable compartments
It's not rocket science to reposition the hand brake. Shift it to the driver's left side and use the center space to make a big console. You can get tons of ideas for that on the web. Make sure it's water resistant as well. This can be used to store a lot of stuff and should be made to a height such that it can double up as a center armrest.
You can also incorporate your music system into it.
7. Grab Handles
Many times you need to hang on (like during ruts) and you land up using the door frames (which is not recommended). If you are making a roll cage, you can incorporate the grab handles. Or else you get plastic handles from vehicle like tata ace, etc which can be screwed onto the a pillar / side of the windscreen.
8. Charging points
Have a couple of charging points atleast. One to charge your mobiles / GPS and the other can be used to power a light during night OTRs. Try to source charging sockets which have a lid so they keep water out when not in use. You can buy them off ebay for cheap. Search for motorcycle/marine charging points
9. Wide Mud flaps
These can prevent a lot of muck from flying around and onto yourself. You can make these from rubber mats.
10. Front Mud Flaps
Mud flaps in front of your front tyre (hanging from the bumper) can prevent the water splash from hitting your windscreen when you enter puddles at higher speeds.
Please share more suggestions
Tejas@perioimpl is offline   (5) Thanks Reply With Quote
Old 23rd June 2011, 14:41   #2
Thanked: 647 Times
Default Re: Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestion
Good tips! I specially liked the one about the front flaps.
Let me see if I come up with more ideas.
jyobeb is offline   Reply With Quote
Old 23rd June 2011, 15:07   #3
Some points i missed out:
11. Limb Risers / Branch deflectors
These are basically two wires that run from the front (sides) of your bonnet to the top (sides) of the windscreen. They deflect branches upwards towards the top of the vehicle and prevent scratches to the vehicle and save you from a face full of branches which can whiplash into your face (especially for doorless vehicles).
12. Trunk in the back
You can bolt on a heavy trunk to the back and weld a front facing seat on top of it (like i had done in my classic). So you get lots of safe storage without compromising on seating.
Tejas@perioimpl is offline   Reply With Quote
Old 25th June 2011, 11:24   #4
satan's Avatar
Thanked: 803 Times
13. Water sprayer for the radiator to keep temperatures low on the trail
Add an extra sprayer pipe from the windscreen washer reservoir that sprays water onto the front of the radiator (or condensor in case of vehicles with AC)
satan is offline   (1) Thanks Reply With Quote
Old 25th June 2011, 11:34   #5
Thanked: 113 Times
Can you post a pic? What deflectors can we install to prevent the branches from scratching the paint on the door sides? Will these work for branches jutting on the lower sides but not over?
--Ragul
Ragul is offline   Reply With Quote
Old 25th June 2011, 12:05   #6
Thanked: 595 Times
--Ragul
here is Raj Kapoor's jeep with branch deflectors.
Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestions-11042009580.jpg
Parm is offline   Reply With Quote
Old 26th June 2011, 09:07   #7
Thanked: 822 Times
Exclamation Re: Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestion
Caution : IMHO & AFAIK >> ' DONT DO THIS '
REASON ; Very HOT RADIATOR + COLD WATER ( Sudden ) = CRACKS ???
Sudarshan
P.S. one can use extra fan for this
Sudarshan is offline   Reply With Quote
Old 26th June 2011, 12:26   #8
satan's Avatar
Thanked: 803 Times
What happens when you are driving through intermittent but heavy rains sir
satan is offline   Reply With Quote
Old 26th June 2011, 12:49   #9
Thanked: 822 Times
Frankly I Cant say --- havent got it so much over heated just before heavy rains . But I wont recomend that --
I have heard few wiser people saying this , so I say
Anyways you can try & tell but who is going to test it ?
Now for this thread ---
1) hooks for the Jeep
Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestions-2hook.jpg
Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestions-3hookop.jpg
2) Cargo hold net
Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestions-5cargonet.jpg
3) Reflective tapes ( sample ) & Marker rod
Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestions-4relfctmark.jpg
4) Reverse Lamp
Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestions-1revl.jpg
5) Some more reflective tape
Modding/refurbishing your 4x4? Here are some non-mechanical but useful suggestions-6reflective.jpg
Sudarshan
P. S. To BHP Support -If these pics dosent fit in the thread please delete it .
Old 26th June 2011, 13:34   #10
greenhorn's Avatar
Thanked: 1,421 Times
Its not that outlandish. tons of hatches out there (including mine) have rear wash & wipes. The water comes via a pipe and goes through the hatch door before being sprayed from the base of the rear windows
greenhorn is offline   (1) Thanks Reply With Quote
Old 27th June 2011, 10:16   #11
Cool thanks. I didn't think of that. Maybe a separate pump can be installed for the mirrors. Let me try it out and see how i can do it.
REPORT with PICS: Refurbishing my OHC Vtec. And some mild performance mods! GTO Modifications & Accessories 195 2nd November 2017 07:58
Mechanical engg. Final year project. Suggestions needed. Nikhilb2008 Shifting gears 18 10th April 2011 23:40
Mechanical Gadgets / devices and non-electronic stuff!!! kkr2k2 Gadgets, Computers & Software 14 11th January 2010 10:24
Non-Mechanical Air Conditioners (Roof Top) kamalakannan Modifications & Accessories 5 7th July 2008 18:20
