Old 3rd July 2011, 10:25   #1
Default Peugeot XDP oil change interval
What is the interval for changing oil for Peugeot XDP engines ? I changed the engine oil recently and the engine has clocked 1.5K km since then. Oil seems to be saturated and even the amount of oil has decreased. I suspect rings, but bad rings, but need to check that. There is also oil leaking from the engine. I should get the crank case packing also checked. Anything else you guys suspect ?
satish.rpr is offline   Reply With Quote
Old 3rd July 2011, 17:40   #2
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Default Re: Peugeot XDP oil change interval
Please tell about - Smoke, how much oil is being consumed, change in noise, vibration etc. That will help to diagnose / comment with a better understanding. Is the whole oil being lost into open (leaks) or it is disappearing within the engine?
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 3rd July 2011, 20:15   #3
Thanked: 822 Times
I would also like to add / ask one question about this engine --
What is the normal oil consumption figure -per 1000 Km. for this engine ?
AFAIK -the 2112 cc Peugeot has a recommended ( Max ) figure of 1.5 lit / 1000 Km . does this fall near to this engine also ?
Sudarshan
Sudarshan is offline   Reply With Quote
Old 3rd July 2011, 20:18   #4
V-16's Avatar
Thanked: 848 Times
Kindly also mention if there is back pressure. Please check for all the above points as they are indicators of how unhealthy the engine is.
V-16 is offline   Reply With Quote
Old 4th July 2011, 11:03   #5
Spike
Smoke, noise and vibration seems to be normal. I got the oil changed when the engine had previously clocked around 3.5K km. After this oil change the engine has clocked only around 1.5K. There were leaks earlier and I got the crank case packing changed. There still seems to be some leaks.
There seems to be no back pressure. I removed the dip stick and started the engine. No oil was thrown out.
Old 4th July 2011, 17:03   #6
Thanked: 92,055 Times
My new 2.5L Bolero engine hardly drinks any oil at all. And the older 2.1L never required 1.5L / 1000 kms for the first 100,000 kms of its life. Sure, consumption went up with age, yet I never remember it being to the tune of 1.5L / 1000 kms (that's rather high IMHO). I think it was more like 500 ml / 1000 kms.
Old 4th July 2011, 18:19   #7
Thanked: 822 Times
== And the older 2.1L never required 1.5L / 1000 kms for the first 100,000 kms of its life. Sure, consumption went up with age, yet I never remember it being to the tune of 1.5L / 1000 kms (that's rather high IMHO). I think it was more like 500 ml / 1000 kms.
Explanation ; this is what I wanted to say , ( from the MM operators manual that came along with our new Jeep ) have a look
Possibly we can find answer for the XDP-- in a Similar book ( If anyone has )
Sudarshan
P. S. -- My memory & library are still intact
Old 4th July 2011, 20:51   #8
akshay4587's Avatar
Thanked: 1,629 Times
We sold our bolero with 1.75L Kms on Odo,and it was the one with XD3P engine,and it never consumed any oil,and 1.75L was done without any kind of repairs to engine block\piston and all.
We used to change oil every 5-6K kms.
What oil change interval do you adhere to? GTO Technical Stuff 113 8th September 2017 23:27
Peugeot ditches Gujarat Factory plans. GM unwilling to let Peugeot use its plants GTO The Indian Car Scene 47 7th October 2016 12:57
Can you change the time interval set for intermittent wipers? girlieonwheels Technical Stuff 14 27th August 2011 11:43
Mahindra Peugeot XDP diesel engine rattles suddenly satish.rpr 4x4 Technical 2 5th March 2011 16:39
Oil change interval - why the difference for a hatch and sedan ? supremeBaleno Technical Stuff 38 12th August 2008 18:14
