Old 10th August 2011, 14:16   #1
Jaskirat's Avatar
Thanked: 175 Times
Default Wheel Alignment Data for MM550XD
Hi Guys,
Would appreciate if someone could upload the wheel alignment data for MM550XD.
Jaskirat
Jaskirat is offline   Reply With Quote
Old 10th August 2011, 15:56   #2
Thanked: 822 Times
Default Re: Wheel Alignment Data for MM550XD
bit confusing , when you use the word data
IMHO & AFAIK there is nothing to adjust other than the ' Toe in & Toe out ' in this vehicle .
or is there anything else to adjust WRT ' wheel alignment ' ? or you need some more on the 'Castor -Camber ' thing to repair a damaged part ? but I think its factory fixed , nothing can be done about it-( if it is standard or non modified on your vehicle )
Sudarshan
Sudarshan is offline   Reply With Quote
Old 10th August 2011, 18:20   #3
ex670c's Avatar
Thanked: 1,799 Times
Default M&M Wheel Alignment Data
Hi Sudarshan JEE,
You seem to have a lot in common with M&M Engineers .
They thought the same with the FC Van/MM550/CJ500D/CJ3B, i.e vehicles with different Wheel Base, COG, GVW, Wheel Disc Off-Set have the same caster camber, toe-in & off-course KPI.
So which will under steer, which will over steer, which has a better steering re-centering?
Arka
ex670c is offline   (5) Thanks Reply With Quote
Old 4th September 2011, 04:24   #4
hamza's Avatar
Thanked: 71 Times
I don't think this is the right thread to be posting this, but I couldn't find a better thread. I have been looking for a mahindra xd3p engine manual but have been unable to find one. It would be really great if someone could help me out, Thanks.
hamza is offline   Reply With Quote
Old 5th September 2011, 10:38   #5
ex670c's Avatar
Default Xd3p
Hi Hamza,
Please download it from this link.
Jeep Thrills India XD3P Service Manual
Arka
ex670c is offline   (4) Thanks Reply With Quote
Wheel Alignment Data - Ford Endeavour 4x4 ssh1979 Tyre & Alloy wheel Section 7 31st August 2011 21:35
Wheel Alignment Data for Ford Fiesta Jaskirat Tyre & Alloy wheel Section 6 2nd April 2009 19:12
Wheel Alignment Data for i10 NFS2024 Tyre & Alloy wheel Section 8 2nd April 2009 17:59
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
