Old 29th September 2011, 19:51   #31
jeepster's Avatar
Thanked: 1,036 Times
Default Re: 58"ffra
Originally Posted by ex670c View Post
IIRC the FC is 58"and the MAXX Pickup is 59" .
hmm,,,
So what are the Differential Off-Set Available with the above two FFRA's?
center diff for the 4x2 version & right offset for T18.
Get your Axles ready and I will surely tell you what little I know.
so be ready for the questions.
rgds,
Nikhil
jeepster is offline   Reply With Quote
Old 29th September 2011, 19:58   #32
ex670c's Avatar
Thanked: 1,821 Times
Default 58"ffra
Originally Posted by jeepster View Post
hmm,,,
Hi Nikhil,
Are you sure? and then what Type of Axle?
Arka
Old 29th September 2011, 20:14   #33
jeepster's Avatar
Default Re: 58"ffra
yes.
will search for one piece FFRA as i have BW TC. (looks like little left offset in pic )
there were some 2~3 sets (F+R) of FC 4x4 & 4x2 axles available here but didnt had money then.
rgds,
Nikhil
Old 30th September 2011, 10:40   #34
ex670c's Avatar
Default Re: 58"ffra
yes.
will search for one piece FFRA as i have BW TC. (looks like little left offset in pic)
Hi Nikhil,
The 1 Piece FFRA are you sure its has a Left Off-Set, the picture is at an angle.
wrt the second pic, is the Axle marked by the red Arrow a 1 piece FFRA?
Arka
Old 30th September 2011, 12:12   #35
jeepster's Avatar
Default Re: 58"ffra
yes , after seeing pic i am not sure if it was one piece FFRA or with some left offset two piece FFRA.
but its used on 4x2 FC.
no, the arrowed one has right offset for the 4x4 FC.
one at the bottom has left offset so it must be for the 4x2 FC.
rgds,
Nikhil
Old 30th September 2011, 14:52   #36
ex670c's Avatar
Default Re: 58"ffra
Hi Nikhil,
Are you sure the one marked by arrow is Right off-Set for a 4x4 FC.
From the rear it may look like a left off-set for a 4x2 FC.
Arka
Old 30th September 2011, 14:59   #37
jeepster's Avatar
Default Re: 58"ffra
Hi Nikhil,
yes,
if we rotate the arrowed axle to front in the same position, it becomes right offset used for 4x4 FC. (when we see it from the back)
Old 30th September 2011, 16:57   #38
ex670c's Avatar
Default 58"ffra
yes,
Hi Nikhil,
If we rotate the Axle along axis of the Axle Tube then the Spring Saddle will get repositioned for SUA.
And the Differential will get flipped, hence unusable.
Please observe the position of the Spring Saddle and Brake Lines.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 30th September 2011, 19:27   #39
jeepster's Avatar
Default Re: 58"ffra
right.
so even 4x4 FC use a left offset axle??
how come??
the t18 has a out put to right & connection it to left offset axle will be not be a good idea.
rgds,
Nikhil
Old 30th September 2011, 21:09   #40
Frankenstein's Avatar
Thanked: 300 Times
Default Re: Difference in the track width of the mm 550 ngcs .
Arka the spring saddle can be re welded to the new location. If the axle is flipped and the diff becomes ulta, will it be not usable, i would like to learn on this subject.
Frankenstein is offline   Reply With Quote
Old 1st October 2011, 10:09   #41
Thanked: 825 Times
IMHO & AFAIK it has some thing to do with the lubrication part ( will not be good for the pinion bearing lubrication )
also need to check if & how the direction of rotation of crown pinion affects performance ( or not )
I am not sure abt both the things , its just a thought -- you guys can think on it .
BTW something but about using the FC axles in moded ( upgraded engined ) Jeeps ---
I have observed that the longer axle in a off set diff setup always tends to break early ( compared to the shorter ) , now if the FC axles are used , is there any chance they will break easily because of the longer length ?? ( assuming they are of same material & treatment like the standard Jeep ) -just a thought again not sure abt it , May be experts can guide us further
Sudarshan
Sudarshan is offline   Reply With Quote
Old 1st October 2011, 10:21   #42
ex670c's Avatar
Default Flip the Diff
Sudarshan
Hi Sandep,
When the diff is flipped, there are two Problems
1) As Sudarshan JEE mentioned there is insufficient lubrication for the Pinion Gear.
2) AFAIK The Direction of Rotation of the Differential Changes, so instead of going forward the vehicle will go reverse
Arka
PS - So diffs do the 4WD FC Vans use?
Old 4th October 2011, 19:26   #43
jeepster's Avatar
Default Re: Flip the Diff
so what is the offset of 4x2 & 4x4 FC?
only left offset?
what about Prop-shaft angle?
Old 5th October 2011, 10:24   #44
ex670c's Avatar
only left offset?
Hi Nikhil,
What diffs do the 4x2 FC Vans use?
Arka
Old 5th October 2011, 10:26   #45
jeepster's Avatar
i asked the Question first.
The elusive MM540 / 550. EDIT: New Search for ex-Army 550 on page 9 IronWolf 4x4 Vehicles 146 13th February 2015 23:02
Does Rim Width Affect Handling ? speedsatya Tyre & Alloy wheel Section 21 23rd May 2010 17:29
the difference in track width- front v/s rear playlife Technical Stuff 5 2nd October 2006 10:28
Stability: A height to width issue Ram Technical Stuff 38 3rd August 2006 11:50
Width of Santro Zip Plus psynaps3 Hatchbacks 4 15th April 2006 23:14
