Old 5th October 2011, 10:42   #46
ex670c's Avatar
Thanked: 1,799 Times
Default Re: Difference in the track width of the mm 550 ngcs .
Originally Posted by jeepster View Post
i asked the Question first.
Hi Nikhil,
You can ask anything anytime, but the answer will only be revealed to you, when you are ready.
And in your case your, when you are more observant and logical.
Arka
PS - I don't believe in spoon-feeding the answer.
Old 5th October 2011, 10:45   #47
Blue Thunder's Avatar
Thanked: 330 Times
4X2 FC van --> center diff or left offset or right offset ???
Blue Thunder is offline   (1) Thanks Reply With Quote
Old 5th October 2011, 10:56   #48
ex670c's Avatar
Default Off-Set
Hi Senthil,
You have given the answer!!!!!
Two options are correct for 4X2 and Two options are correct for 4X4
Arka
Old 5th October 2011, 11:18   #49
jeepster's Avatar
Thanked: 984 Times
in the pic i posted earlier, there is no right offset axle.
but only left offset (as you pointed out) even though at least 1 FC out of 4 was 4x4. (which were scraped)
not even a center diff to be seen in pic .
i still think there must be a right offset axle for 4x4 FC as AFAIK there was no option of BW TC in FC to use center diff axle as my armada has.
or
is it left offset for 4x2 & center diff for 4x4 FC??
jeepster is offline   Reply With Quote
Old 5th October 2011, 12:15   #50
ex670c's Avatar
Default Fc
or
Hi Nikhil,
Pre 1995c the FC Van Had left 58" Off-Set for 4x2 and 58" Right Off-Set from 4x4 with 2 piece FFRA
After that till 1998c the FC Vans used the Centre Diff for 4x2 & 4x4 with 1 piece FFRA.
Arka
ex670c is offline   (3) Thanks Reply With Quote
Old 13th October 2011, 09:37   #51
jeepster's Avatar
Thanked: 984 Times
Default Re: Track Width
Originally Posted by ex670c View Post
Please explain why a vehicle will be unsteady dues to a track difference of 4" .
What is the width of the logs? in the above videos
What is the width of the tyres in the above videos?
this is what i was referring.
http://www.team-bhp.com/forum/4x4-ex...ml#post2542438 (4 Guna 4)
rgds,
Nikhil
Old 13th October 2011, 10:18   #52
ex670c's Avatar
rgds,
Nikhil
Hi Nikhil,
So what will happen to a vehicle with a 2" Track Difference?
Are the Planks Just 2" wide?
Please post appropriate pictures to prove your point not speculations.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 13th October 2011, 11:37   #53
condor's Avatar
Thanked: 4,416 Times
@Arka, looks like @Jeepster drives on such narrow tolerance tracks 90% of the time, and is hence the difference in front & rear track is causing him frustrating problems.
As for me, the 50mm track difference on my Ikon has not caused any problems when & where I drive.
Old 9th November 2011, 09:16   #54
sreejeshmp's Avatar
Thanked: 571 Times
Arka
Can you please tell the Front and rear track width of MM550XD ?
sreejeshmp is offline   Reply With Quote
Old 9th November 2011, 10:06   #55
ex670c's Avatar
Hi Sreejesh,
What do you think is the Front & Rear Track of a MM550XD?
48.5"/48.5" or 51"/51" or 57"/53"?
Arka
Old 9th November 2011, 10:16   #56
sreejeshmp's Avatar
Thanked: 571 Times
Hi Sreejesh,
Arka
I don't know But I think It is 51"/51". I am planning to change the Gearbox In to a BW so I need to change the rear Diff. So I am learning How to do The conversion and what are the available Diff options for the conversion. I think Mahindra pic-up 2wd/4wd rear Diff (53" right ?) can be used but don't know about whether I can retain the LSD.
- Sreejesh
sreejeshmp is offline   (1) Thanks Reply With Quote
Old 9th November 2011, 10:26   #57
ex670c's Avatar
Hi Sreejesh,
If you search through the Vehicles & Technical sub-forums, I'm sure most of your queries will be answered.
Arka
Old 9th November 2011, 11:04   #58
sreejeshmp's Avatar
Thanked: 571 Times
Thanks for your valuable input
Old 23rd November 2011, 14:13   #59
sammyaulakh's Avatar
Thanked: 21 Times
Finally found a solution to the above problem.The mahindra maxi truck's
rear differential is the same length as the front OKBJ 57".I will be installing the
rear diff on Tuesday or Wednesday ,will post the pics then for future references.
sammyaulakh is offline   (2) Thanks Reply With Quote
Old 24th November 2011, 12:41   #60
4x4addict's Avatar
Thanked: 2,513 Times
@sammy:
All Maxi Trucks 2WD/4WD have center differential. With BW T-case it is okay. With T-18 it will not work.
4x4addict is offline   (1) Thanks Reply With Quote
The elusive MM540 / 550. EDIT: New Search for ex-Army 550 on page 9 IronWolf 4x4 Vehicles 146 13th February 2015 23:02
Does Rim Width Affect Handling ? speedsatya Tyre & Alloy wheel Section 21 23rd May 2010 17:29
the difference in track width- front v/s rear playlife Technical Stuff 5 2nd October 2006 10:28
Stability: A height to width issue Ram Technical Stuff 38 3rd August 2006 11:50
Width of Santro Zip Plus psynaps3 Hatchbacks 4 15th April 2006 23:14
