Old 24th November 2011, 13:57   #61
sammyaulakh's Avatar
Thanked: 21 Times
Default Re: Difference in the track width of the mm 550 ngcs .
@ 4x4 addict
Sir my jeep is equipped with a Isuzu 5spd 4wd gearbox ,so i was looking for
a center aligned differential.With the maxi truck diff. both my concerns
have been addressed .
sammyaulakh is offline   Reply With Quote
Old 25th November 2011, 22:02   #62
jeepster's Avatar
Thanked: 984 Times
Originally Posted by sammyaulakh View Post
Finally found a solution to the above problem.The mahindra maxi truck's
rear differential is the same length as the front OKBJ 57".I will be installing the
rear diff on Tuesday or Wednesday ,will post the pics then for future references.
can you measure the length of the axle for reference?
is it from mm maxx pickup single cab?
is it FFRA or SFRA?
i also need one for my ARMADA.
jeepster is offline   Reply With Quote
Old 26th November 2011, 00:31   #63
Thanked: 21 Times
I will only be able to to tell you the axle length once the differential arrives on Monday.
It is from the maxx and is a FFRA.You will be able able to source it from any of the auto scrap markets.But these diff's are hard to come by as hardly any maxx's are scrapped,i got lucky as a brand new maxx met with an accident and was scrapped.
Old 4th December 2011, 23:13   #64
Thanked: 21 Times
the differential arrived today.But was disappointed since the things didn't pan out as it
was supposed too.The maxx differential is about 2 inches wider than the NGCS front differential.So going in for plan B that is adding 1 inch spacers to both sides of a Bolero
differential and using it.
sammyaulakh is offline   (1) Thanks Reply With Quote
The elusive MM540 / 550. EDIT: New Search for ex-Army 550 on page 9 IronWolf 4x4 Vehicles 146 13th February 2015 23:02
Does Rim Width Affect Handling ? speedsatya Tyre & Alloy wheel Section 21 23rd May 2010 17:29
the difference in track width- front v/s rear playlife Technical Stuff 5 2nd October 2006 10:28
Stability: A height to width issue Ram Technical Stuff 38 3rd August 2006 11:50
Width of Santro Zip Plus psynaps3 Hatchbacks 4 15th April 2006 23:14
