Old 8th November 2011, 23:28   #16
Note from Mod: There are several spelling & grammatical errors in your posts. This negatively affects the board experience for other readers.
Kindly ensure that you proof-read your posts prior to submission. Also, it would be a good idea to use spell-checkers.
bcm44 is offline   Reply With Quote Received Infraction
Old 9th November 2011, 01:05   #17
Hello
I think it did came with p4 perkins. Read this paragraph i copied from janes.com or click on the link.
("The JONGA/Nissan Patrol is entirely conventional in design, however, the JONGA vehicle underwent numerous automotive changes during its production life. It was produced with a 145 hp four-litre petrol engine in place of an earlier 125 hp unit and was also available with a Perkins P4(V) diesel. The final standard engine was a four-litre Hino WO4D diesel developing 108 hp and introduced in 1996.")
http://articles.janes.com/articles/J...cle-India.html
Also what was about hino mechanics you said, did u mean its difficult to repair? Its made in abundance by ashok leyland in india. And please explain me the reverse firing order? Is there any problem ? Regards
shootsingh is offline   Reply With Quote
Old 10th November 2011, 23:58   #18
Hi
There is some disconnect, the Nissan P60 was produced in 1961, was in production till 1999 in various parts of the world. Till 1996 there was no change in engine i.e. 3956 cubic capacity six cylinder in line engine with hitachi carburetor and keihein distributor producing 110 bhp as per company specks the site you mentioned claims 145 bhp. Only Perkins v 8 crossed 100 bhp that and Perkins 6 which was turbocharged, please note the Jabalpur factory produced 110 civilians model with Hino engines with extended chassis but was never produced for army.
The Hino engine one of the best engine most suited for jonga, but lack of spare and poor know how of local mechanics did not make it a success. Most mechanics had not seen the new type of firing order.
Old 10th November 2011, 23:59   #19
Thank you I shall correct myself.
Old 11th November 2011, 13:45   #20
Hi
You are right, my jonga is 97 model so we can expect a change, moreover the army voucher reads the engine number as p4xxxx.
Its india we can never be sure whats going on under the roof . My jonga is army version, there may be a mistake in documents but it worked for me otherwise indian RTO would never allow me to diesalise it.
I am trying to get intouch of someone in mayapuri, what sort of price shall i expect to pay for hino turbo engine.?
Old 11th November 2011, 15:54   #21
R32_GTR's Avatar
Thanked: 173 Times
Default Re: Diesel Engine For Jonga ?
Originally Posted by bcm44 View Post
Hi
Then I swapped it with Toyota rd28 six cylinder very good but the three speed g box not suitable gearing issues
Toyota made RD28 engines??
Hi
Use the "search" function on this subject.. There is heaps of information with regards to the Jonga on the forum.
Which Hino Turbo engine are you referring to?? The ones used by VFJ for the civilian versions were normally aspirated motors..
You can get a Hino diesel engine (NA) and gearbox off a Shaktiman truck for around 10k - 20k.. Will require a good rebuild though.
R32_GTR is offline   Reply With Quote
Old 11th November 2011, 16:25   #22
You can get a Hino diesel engine (NA) and gearbox off a Shaktiman truck for around 10k - 20k.. Will require a good rebuild though.[/quote]
Hi
Its hino W04D with or without turbo, not sure if i should really get the turbo version. Without turbo i heard is much cheaper. I am not too much concerned about top speed. I want too keep jongas 3 gear box, Any help be much appreciated
Nissan Jonga! Can I have some details about this monster truck? jango 4x4 Vehicles 200 5th December 2016 11:58
3 Jonga's Sha 4x4 Vehicles 112 3rd October 2014 19:51
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Jonga's & Shaktiman's ajkail Introduce yourself 2 25th June 2007 16:52
