Old 21st October 2011, 08:03   #1
Frankenstein's Avatar
Thanked: 274 Times
Default Engines : OM616 vs TD2650FTI vs FT2400
I need some details regarding the following engines.
OM616 , i am aware since i am using it.
TD2650 FTI, a bs3 engine now, with a power of 82bhp and 21kgm torque.I have heard the om616 was modded with a new rotary pump,head and some internals . Does it have the same internals as the trax toofan non turbo 2650FT?
What is the weight of this engine, does it have the same om616 mounts?
FT2400, this is a turbo version of the OM616, remember seeing it in a Judo , but didnt bother.
Was the turbo just snapped on the 616 or the internals were beefed up?Does it use an intercooler?
Any experience with these 3 engines and a comparo appreciated.
Frankenstein is offline   Reply With Quote
Old 21st October 2011, 08:35   #2
headers's Avatar
Thanked: 459 Times
Default Re: om616 vs TD2650FTI VS FT2400
^^^: Frankie:
A turbo usually has to have beefed up internals unless you wanna run a mild boost for Emission and FE.
An intercooler again depends on the Turbo used and the engine's requirements.
Do modern common-rails engines last like IDI/DI engines? Gany Technical Stuff 39 21st March 2015 08:53
Do Diesel engines generate more Torque than Petrol engines? ex670c Technical Stuff 224 25th November 2013 12:20
Difference between old engines and new engines (petrol and diesel) srijit Technical Stuff 32 26th January 2011 10:20
VW CRDi engines Vs Toyota CRDi engines ivar1951 The Indian Car Scene 9 20th September 2009 22:24
