Old 5th April 2013, 08:39   #46
Thanked: 1,215 Times
Default Re: My new Project. A teeny tiny Nissan truck! The 4W73
If parking is a problem, why not convert it into a towing vehicle? This way nobody would ever tow it away, and you could easily help out distressed vehicles during offroading.
honeybee is offline   (2) Thanks Reply With Quote
Old 5th April 2013, 18:36   #47
desertfox's Avatar
Thanked: 527 Times
Honestly, what an Idea SirJee!
desertfox is offline   Reply With Quote
Old 5th April 2013, 18:54   #48
Thanked: 647 Times
Parking is not an issue at all. I have enough parking space and the vehicle is registered as a recovery vehicle anyway!!
jyobeb is offline   (1) Thanks Reply With Quote
Old 17th May 2013, 14:02   #49
Thanked: 647 Times
My engine saw some action.
As I wanted to have on board air I procured an air compressor off a 6BT. I also had to replace the entire 4BT timing case with that of a 6BT. Got that done and fitted the air compressor, only to find the lift pump fouling with the compressor. Procured and fitted a cam mounted lift pump and blocked off the original lift pump.
The Holset hx35 turbo is also mounted and clearances are all good. I am also replacing the 4bt engine mount bracket with that of the 6BT.
jyobeb is offline   (4) Thanks Reply With Quote
Old 17th May 2013, 14:12   #50
Thanked: 647 Times
More pictures of the work done
jyobeb is offline   Reply With Quote
Old 17th May 2013, 15:09   #51
Thanked: 647 Times
Issues with posting from my phone. More pics!
jyobeb is offline   (6) Thanks Reply With Quote
Old 17th May 2013, 16:32   #52
desertfox's Avatar
Thanked: 527 Times
From where are you able to get new parts for this Nissan engine, I understand Nissan P 60 ( Jonga ) and this 1 Tonner truck had the same petrol engine till the last few came with diesel engines, are new parts still available ?
Old 17th May 2013, 19:21   #53
Thanked: 647 Times
Engine parts are still available new from remote parts shops if one looks hard enough. So are gearbox parts. Used parts are fairly easily available however.
Other parts can be procured with the right contacts though I will be upgrading the brakes and steering.
Suspension seems to be pretty much bulletproof and so are the diffs.
I need to add power steering for which I will be needing some help.
Old 10th July 2013, 15:19   #54
swiftboost's Avatar
Thanked: 43 Times
How much did the HX35 cost you brand new. Did u source it through a Holset dealer or through truck parts dealer. Thanks - Joe
swiftboost is offline   Reply With Quote
Old 11th July 2013, 19:46   #55
Thanked: 647 Times
Bought new from Pudupet for Rs16000/-
Old 31st August 2013, 12:06   #56
Grace's Avatar
Thanked: 159 Times
Hi John,
Any new updates. Been watching this space very keenly
Andy
Grace is offline   Reply With Quote
Old 31st August 2013, 12:39   #57
Thanked: 647 Times
Been working on the Willys wagon and hence going slow on this. The engine is all set and ready for transplant.
Old 7th December 2013, 13:16   #58
Thanked: 58 Times
Hi Beboy,
What's the PCD on the wheels for this Nissan beauty?
You might want to take a look at Hutchinson beadlocked wheels, with BFG T/A KO ATs at 40inches?
rgds
lugnut is offline   Reply With Quote
Old 20th February 2014, 15:59   #59
Thanked: 647 Times
I ma looking for 17" wheels for my truck.
I need 5 hole pattern wheels with 203.2 pcd and a bore hole of 146 mm diameter.
Someone please help!!
Old 20th February 2014, 16:48   #60
Blue Thunder's Avatar
Thanked: 330 Times
Lightbulb Re: My new Project. A teeny tiny Nissan truck! The 4W73
That converts to 8" PCD and 5 34 " bore dia, so it is easier to search mentioning inches.
Blue Thunder is offline   Reply With Quote
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
Nissan 4W73 aka 1 ton ex670c 4x4 Vehicles 347 23rd July 2016 15:40
Kamla Nissan (Mumbai) no longer a Nissan dealer. EDIT: Torrent Nissan too Zinda Indian Car Dealerships 19 10th March 2016 17:52
Tara International's Tiny joins Nano race with world's cheapest car akash_m The Indian Car Scene 36 29th November 2013 14:40
My Tiny Requires a New SQ Sub jatinpatel In-Car Entertainment 27 27th February 2011 20:45
