Old 27th February 2012, 21:31   #1
yamaniac's Avatar
Thanked: 90 Times
Default MM540 2WD to 4WD - Mileage drop after conversion
Hi Guys,
I recently got my 2wd mm540 to a 4wd, although everything is running smoothly, there is a huge drop in mileage and has become a cause for concern. But it is a very capable off-roader, but the mileage stinks!
Before in the 2wd I used to get somewhere around 12-13 Kmpl. But now after the conversion to a 4wd. I don't think its giving me even 8kmpl roughly!
I spoke to my mechanic and he insisted that we get the diesel pump serviced, But even after so, the problem is still the same!
My thoughts are, is there something that has to do with the crown pinion ratio? It has the original 540 diffs and crown pinons.
I am aware that the The Tcase and the front differential will add another 70+ Kilo weight on the jeep.. But I dont think that would make a huge difference though? or does it?
I haven't installed lamda though! will this help?
Any thoughts on this gurus?
yamaniac is offline   Reply With Quote
Old 28th February 2012, 10:25   #2
ex670c's Avatar
Thanked: 1,821 Times
Default Re: MM540 2WD to 4WD - Mileage drop after conversion
Originally Posted by yamaniac View Post
Hi Guys,
Hi Yamaniac,
Please check the following
1) Front & Rear Brakes are binding.
2) Change the Front Axle Flange to Free Wheeling Hub.
3) Check the Front & Rear Differential Ratio
4) Rear Prop Shaft Alignment
Arka
PS - Post a few pics of the front and rear Diff, under the chassis.
ex670c is offline   (4) Thanks Reply With Quote
Old 28th February 2012, 10:50   #3
shankar.balan's Avatar
Thanked: 5,350 Times
With the added 4WD you should experience a drop of about 2Kmpl more or less, on account of the increased weight and the fiddly bits added in.
More than that is strange.
shankar.balan is offline   (1) Thanks Reply With Quote
Old 28th February 2012, 12:22   #4
dhanushs's Avatar
Thanked: 4,504 Times
In my limited knowledge:
Get a free wheeling hub. It frees the front axle and differential, and should get you back the 2WD mileage.
Also, have you retained the left aligned rear differential?. If so, I guess with a T-18 TC, (IIRC, you got that?) The prop shaft will be angled and be far from efficient.
So, please get a right aligned rear differential (If not done).
Other than that, unless the work is shoddily done, I dont see a reason for the drop in mileage.
Yes, please..
dhanushs is offline   (3) Thanks Reply With Quote
Old 28th February 2012, 21:52   #5
Thanked: 2,403 Times
Simple things first. Is the speedo/ odo showing correct readings?
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 28th February 2012, 22:51   #6
Hi yamaniac,
I observed 2 to 3 Kmpl of drop in mileage after 4WD conversion.
I have FWH installed.
HJ13
HJ13 is offline   (1) Thanks Reply With Quote
Old 29th February 2012, 18:22   #7
AVR
AVR's Avatar
Thanked: 531 Times
I did Ahmedabad-Lonavala-EXAMM-Karjat-Ahmedabad in 2010 with my DP-engined 540 and I got an average of 13.5 for the entire trip which included expressways (lol in a jeep!) and offroad (jungle slush trails). And my Jeep is 4wd with FWH!
Freewheeling hubs is the way to go! Fix them up and then see if you still don't see reasonable performance improvement then it can be other things.
Cheers,
Adi
AVR is offline   (1) Thanks Reply With Quote
Old 29th February 2012, 20:02   #8
yamaniac's Avatar
Thanked: 90 Times
Thanks alot for the input guys!
Hi Arka,
I Will post a few pics soon, I am currently in the UK right now on some work, will post it by the end of this week. Thank you so much!
Originally Posted by ex670c View Post
Hi Yamaniac...
...under the chassis.
In my limited knowledge...
...I dont see a reason for the drop in mileage.
Yes, please..
Sutripta
Originally Posted by HJ13 View Post
Hi yamaniac,
HJ13
Originally Posted by AVR View Post
I did Ahmedabad-Lonavala...
...Cheers,
Adi
Last edited by suhaas307 : 29th February 2012 at 23:03. Reason: Please avoid quoting large posts as it may inconvenience small-screen and mobile users. Thanks :)
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
MM540 2WD to MM550 4WD, 5 Speed.Transformed! fazalaliadil 4x4 Vehicles 58 28th March 2014 18:48
Mahindra Armada - 2WD to 4WD conversion possible? powertrain 4x4 Technical 48 15th October 2013 20:10
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
Mahindra Scorpio CRDe - 2WD to 4WD conversion suhasd75 Modifications & Accessories 8 3rd November 2009 18:02
