Old 9th March 2012, 23:44   #1
Invicta's Avatar
Default Mitsubishi J26 Jeep KM141 gearbox question
It is getting difficult to change down into 2nd when the box has warmed up. So I am thinking of changing the 4 speed Km141 box or getting it re engineered.
I would appreciate any tips or suggestions people might have.
the engine is the original 2.4 4 cylinder 4G53 ASTRON.
Invicta is offline   Reply With Quote
Old 10th March 2012, 13:26   #2
ex670c's Avatar
Thanked: 1,799 Times
Default Re: Mitsubishi J26 Jeep KM141 gearbox question
Hi Invicta,
This problem is usually attributed to a worn out Synchroniser Cone/Ring, also this problem can be compounded by worn out Gear Box Bearings.
Looks like your JEEP A Gearhead in Need GEARBOX MAGAZINE
As the the oil warms up and thins out, the clearance between the Synchro and Main Gear Shaft increases, worst case the Synchro may jump out (just a little bit)and the gearbox will get stuck in that gear.
You can try using a GL5 85W140 Gear Oil, and see if there is any improvement.
After that you can decide on rebuilding the gearbox or changing it.
Arka
PS - Please post some pics of your JEEP.
Engine, Gearbox, Diff ratios, axles options for the JEEP Frankenstein 4x4 Technical 104 5th December 2017 22:19
Maruti Suzuki Alto LXi - Gearbox Question rajeshsundaram Technical Stuff 14 28th November 2015 14:10
Hyderabad - Jeep Thrills Mitsubishi Monsoon Challenge 31/08/2008 shams 4x4 Excursions 59 26th August 2009 16:06
Willys Jeep Engine & Gearbox Swap dinya Modifications & Accessories 5 17th November 2005 10:06
