Old 18th April 2012, 00:57   #16
n.devdath's Avatar
Thanked: 2,154 Times
Default Re: Fitment of ARB Diff Lockers for Scorpio CRDe
Hi devdath, you might be knowing it, but still, I wanted to remind/let you know that, in a 4WD, not only the four wheels are driven, but its the low ratio gearbox, that helps a LOT in tough situations.
Hi Dhanush, I know this fact and have driven quite a few 4wd vehicles over varied terrain. Thanks for the input though.
The update is that I have received my MLD from M&M and will fit it sometime next month.
Old 4th July 2015, 09:57   #17
Is the new Scorpio 2015 differential different than the Dana 44 design on the older one?
skler is offline   Reply With Quote
Old 3rd August 2015, 10:38   #18
n.devdath's Avatar
It is the same differential with the same RAR ratios.
Old 3rd August 2015, 10:53   #19
How do you fit the Eaton MLD in the new scorpio as I understand the differential housing is different
Gypsy on Steroids: Lockers installed and tested now khan_sultan 4x4 Technical 192 26th June 2014 23:34
Dependable 57" axles, diffs and lockers DirtyDan 4x4 Technical 7 13th January 2013 08:58
Whiteline ARB Bomi Modifications & Accessories 0 2nd September 2010 16:43
A Pure Off-Road Spec Gypsy Build | SPoA, Lockers, Bumpers etc etc. swastikviji 4x4 Vehicles 81 16th July 2010 16:54
Scorpio SLX CRDE or Wait for Scorpio Eagle or Used Elantra or Wait for Skoda Fabia ? dharmu99 Hatchbacks 9 25th October 2007 12:22
