Old 30th March 2012, 22:34   #1
karthik123's Avatar
Thanked: 35 Times
Default Thar turbo inter-cooler query
Hello,
Is it possible to change thar's intercooler to a pajero's or mhawk's? ( to a intercooler thats mounted on top of the engine).Will it make any difference to the performance ? Any other engine mods that can be done to increase power? the thar already runs on petes
Didn't find any threads that answered the query directly. Thank you
karthik123 is offline   Reply With Quote
Old 30th March 2012, 22:58   #2
Thanked: 361 Times
Default Re: Thar turbo inter-cooler query
In theory it should be possible to change the intercooler. The catch of course is that the other intercoolers will most likely not fit stock onto the Thar engine which means you will need to find a good mechanic who will need to make the necessary modifications and mount the intercooler accordingly.
Only go down this route if you have a good mechanic who knows exactly what he is doing.
If not you are better off doing other types of mods.
A better and more efficient intercooler will lead to more power though you will need to change the settings a bit to take advantage of it.
Unless the present intercooler is really bad, the difference will not be huge though.
pganapathy is offline   Reply With Quote
Old 30th March 2012, 23:09   #3
nozzlering's Avatar
Thanked: 29 Times
Hello Karthik
M&M have matched the intercooler with the existing engine and turbocharger. It is designed to give optimum performance. If your intercooler passages are clear, and heat transfer is good, I don't think, changing it will improve the engine's performance.
nozzlering is offline   (2) Thanks Reply With Quote
Old 31st March 2012, 00:56   #4
dhanushs's Avatar
Thanked: 4,117 Times
IMO, the inter-cooler upfront, as in the current set up, is the most efficient, much better than the top mounted ones.
Also, in my opinion, a Thar with Petes, should have enough power for 99% of the mud ploughing and highway drives. More power, and you will need to seriously alter the suspension/steering/handling of Thar, to positively experience it.
Old 31st March 2012, 06:16   #5
Endeavour333's Avatar
Thanked: 358 Times
A K&N air filter + snorkel will let the engine take in cooler air from outside the engine bay and also a larger volume due to the air filter. Apart from this the turbo waste gate can be adjusted to increase the boost pressure.
Endeavour333 is offline   Reply With Quote
Old 31st March 2012, 06:41   #6
headers's Avatar
Thanked: 457 Times
Originally Posted by karthik123 View Post
Hello,
Doubt you would get better performance [read power] by intercooler swap. Best is to get a Remap - Contact the ever friendly M&M guys
Do you think the THAR has the chassis / suspension to handle the power?
What if the Turbo has no WasteGate?
Old 31st March 2012, 10:34   #7
madnish30's Avatar
Thanked: 103 Times
DB sir would be the best person to answer this, and he'll be happy to tell you the pros and cons - PM him I suggest.
madnish30 is offline   Reply With Quote
Old 1st April 2012, 00:02   #8
karthik123's Avatar
Thanked: 35 Times
So changing the intercooler will not give any advantage over the stock one? Basically changing this will clear up some space for the AC condenser too. Just an idea wanted to know what will it be like.
Old 7th April 2012, 13:54   #9
Thanked: 4,673 Times
Is it possible to change thar's intercooler to a pajero's or mhawk's? (to a intercooler thats mounted on top of the engine).Will it make any difference to the performance ? Any other engine mods that can be done to increase power? the thar already runs on petes. Didn't find any threads that answered the query directly. Thank you
Dear Karthik123 - my friend, now you are trying to enter uncharted territory. . Take my sincere advice, DON'T!
If the only reason is condenser mounting, then it is not a reason as the factory fitted AC vehicle also has the front mounted intercooler. If you want to increase power, there is a correct way to do it. The end result is that your vehicle will become like MH01V521. Many have asked, I have given umpteen hints on how to do it but nobody has actually done it, so best of luck to you, may you be the first one to match 521, I'll be very happy if it happens. And for God's sake, don't mess around with that air cleaner. The engine air induction system in Thar CRDe is on critical design path.
Dear madnish30 - thanks. I appreciate.
Dear pganapathy - changing an intercooler is not a "mechanic's job". Just for your information.
Dear Vikram - Thar "as a platform" has the "chassis and suspension set-ups" to handle much more power than what it puts down now. 521 may be the real Thar but it is still not the ultimate Thar. That "monster" is still in my mind, let's see. .
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (1) Thanks Reply With Quote
Old 7th April 2012, 18:30   #10
headers's Avatar
Thanked: 457 Times
Dear DB Sir,
I never disputed the THAR cannot handle much more power than what it puts down. Also IMO power is not the solution to a great off road vehicle, and neither is ON ROAD SPEED.
HOW it puts down the power in a situation is what matters. Also, the feedback from the vehicle [steering, chassis, suspension etc] to the driver is very important - This is a compromise in the THAR!!
BTW, having said that, You have achieved phenomenal rear suspension setup for the THAR CRDe I only hope the same can be said about the the vehicle as such.
PS: To all others : The THAR is a great vehicle for first time buyers - No nonsense and extremely peppy to drive - Please do not take the above post in negative
Please suggest good Air Cooler Max Gadgets, Computers & Software 97 25th April 2017 14:28
can you add Glove box cooler in car mrkanitkar Modifications & Accessories 12 22nd July 2010 00:28
Turbocharged 800 Oil Cooler racerdabba Technical Stuff 36 30th October 2008 17:36
Inter Cooler For Suzuki Swift narry Technical Stuff 7 17th April 2008 14:35
