Old 22nd May 2012, 22:15   #1
dhanushs's Avatar
Thanked: 1,660 Times
Default How does your mechanic remove the Tie-Rod End from the Spindle Casing?
Dear bhp'ns, recently, I got stuck in a forest as my Spindle Casing cracked which resulted the front left wheel non-steerable and free to move in it own accord. ie, one cannot steer the Jeep.
Whats the damage? :
How does your mechanic remove the Tie-Rod End from the Spindle Casing?-spindle.jpg
How does your mechanic remove the Tie-Rod End from the Spindle Casing?-spindle-1.jpg
I was trying to maneuver the Jeep within a narrow track, with immovable rocks on both sides. Usually, we pass through this area without much fuss, but this time, I just couldn't steer, and on inspection, found that the Spindle Casing cracked and the Tie-Rod End was hanging freely on the left side.
Well, this part usually does not fail, but why did it fail now? On probing for reasons, I came to know that, most mechanics, take out the Tie-Rod by hammering it out of the casing. Such hammering, if not properly done, will slowly, but steadily develop cracks in the Spindle Casing, which will eventually fail whist some heavy duty steering. Mostly, while maneuvering through rocks. Most mechanics don't mind this much, as small cracks don't fail ON-ROAD, and also as they have no idea about the shear stresses involved OFF-ROAD.
So, please ask your mechanic to take care the next time.
Also, I have never taken my Jeep to an A.S.S, so, I'd like to know how this is done in Mahindra A.S.S (Without hammering??..)
dhanushs is offline   (6) Thanks Reply With Quote
Old 22nd May 2012, 22:40   #2
Thanked: 520 Times
Default Re: How does your mechanic remove the Tie-Rod End from the Spindle Casing?
You get tie rod pullers. Never seen anyone use one. Hammering (judicious) works just fine. Its a forged component.
Sutripta
Sutripta is offline   (3) Thanks Reply With Quote
Old 23rd May 2012, 04:06   #3
motocamp's Avatar
Thanked: 75 Times
judging by the picture,it seems the mech has probably heated the casting up with a welding torch(the paint is all burned off)This and the hammering probably weakened the tie rod end.
motocamp is offline   Reply With Quote
Old 23rd May 2012, 08:06   #4
Sudarshan's Avatar
Thanked: 492 Times
Here it is , along with a Nut cracker , I am trying to find these locally but still haven't found any . May be I will fabricate it some day at least #2
1 The rod end separator
How does your mechanic remove the Tie-Rod End from the Spindle Casing?-separators.jpg
2 Nut Cracker
Name:  nut cracker.jpg
Yes you are right Dada , I have done it numerous times , sometimes used two legged pullers where it could fit & sometimes I use a piece of pipe to support the knuckle eye before tapping on bolt ( bolt hammering only when the piece is to be thrown/ replaced )
Also I use some thin grease on the taper mating surfaces ,so they dont rust & dismantle easily next time
My observations
1) pure metal fatiuge
2) Non standard knuckle ( replaced by previous owner )
3) Wrong hammering (including in previous repairs )
4) Too much tightening of the tie rod end bolt ( its base is tapered shape )
Thinking on more reasons , but good food for thought , at your cost ( Unfortunately ) & a lesson to learn .
Sudarshan
Note : Source of the pics : I had posted it on bhp before -- so all credit to
Sudarshan is online now   (4) Thanks Reply With Quote
Old 23rd May 2012, 09:08   #5
svsantosh's Avatar
Thanked: 529 Times
Lol, I didnt check FB, so I was right. My mech uses brute force (read - 2-3 inch hammer with a foot long handle) for removing bolero, sumo, scorpio etc suspension parts. I strictly warn him not to do such crazy things on my vehicles. In case of TRE he uses a large (30's) size spanner instead of a hammer and knocks it out using its 1 end. Pity, he doesnt have proper tools for the job!
svsantosh is offline   Reply With Quote
Old 23rd May 2012, 13:01   #6
SPIKE ARRESTOR's Avatar
Thanked: 467 Times
Was not your LHS having problems with KPI ? I hope you remember me telling that your knuckles must have been damaged / faulty.
They are NOT supposed to fail like this. This is brutal.
Spike
EDIT- I feel it is your ex-steering which did this trick.
SPIKE ARRESTOR is offline   Reply With Quote
Old 23rd May 2012, 23:54   #7
dhanushs's Avatar
Thanks for the confirmation Spike.
Yes, I guess my knuckles were damaged well before, and hence the KPI problems. As I mentioned before, my KPI on left was 22.4 degrees and right was 10.5 and I was having steering feedback/returnability issues.
Left knuckle is broken and right is 'off' by 3 degrees from OE. So, I'm changing both spindle casings. Right now, I've only managed to source OE ones on the left, and the steering feedback/effort/returnability has increased tons! Lets hope after replacing both, I'll get the 'real' MRCBT advantage! .
More on it later!
Old 24th May 2012, 10:50   #8
Thanked: 103 Times
Tie rod end are removed by hammering the knuckle. I have never seen it being done any other way. This is true even at A.S.S
carbookie is offline   Reply With Quote
Indica tie rod and related query Thomas T Technical Stuff 10 15th November 2010 12:24
Small Accident due to suspected suspension rod-end failure jalsa777 Street and Travel Experiences 17 12th March 2009 13:17
Johnny Joint, Theim joint, Rose Joint (rod end bearings). khan_sultan Technical Stuff 4 23rd February 2009 10:25
HDD External Casing adityamunshi Gadgets, Computers & Software 22 3rd February 2008 20:15
OHC 1.3Exi Tie-Rod/Ball joint replacement at 52k! Advice pls. zenx Technical Stuff 13 30th November 2007 10:01
