Old 11th November 2012, 13:20   #1
Default Disaster Tube in a Gypsy
One of the things I enjoy doing is go on long drives or go drive into the forests, estates or through the rough roads.I have found the Gypsy to be an ideal companion for that.I have known and understood the strengths and weaknesses of this wonderful machine.I have known about the Broken axles, bent diff tubes and springs etc...But this one is new to me in a Gypsy.Was in the middle of the forest patch where there were mud roads...Felt the steering control a little bit different..Got down to inspect...Nothing.Continued to drive for another half a km the same way averaging a speed of 5 kms an hour.Decided to turn back and did a U turn...I heard something snap and grate and the left side went down.The next pictures are self explanatory.A 5 km walk back to the civilization and I have a spare diff and a spare Gypsy.Went back swapped the diffs and returned home...Was just lucky that it happened at that speed.Dread to think if it were to happen at fast speeds.Just curious to know if anyone has heard/faced this issue in the Gypsy/Samurai/SJ 413.
bishancm is offline   (5) Thanks Reply With Quote
Old 12th November 2012, 11:41   #2
khan_sultan's Avatar
Thanked: 3,885 Times
Default Re: Disaster Tube in a Gypsy
Doc, this is the first time I have seen a diff tube break in such a fashion. Looks like the someone sawed it into two! Good that this happened at slow speeds -- else this would have resulted in severe loss of control on the vehicle.
After checking, do you see any other damage? Are the birfield joints/axles ok? If yes, then this seems to be a failure of the diff tube only.
Will let others pitch in and see what hey have to say
khan_sultan is offline   (1) Thanks Reply With Quote
Old 12th November 2012, 12:29   #3
Hi Bishancm,
i had similar ( way back in 2009 ) problem on my gypsy MG410W, i was lucky too , just took her to my office basement parking and heard a thud sound and when got down to see, i saw the oil spill and left front wheel detached. The MASS guys had no clue on how this could have happened, ordered for a new part ( for which i struggled for 1 month by receiving wrong part ) and eventually closed it.
Gypsy_roadies is offline   (1) Thanks Reply With Quote
Old 12th December 2012, 12:20   #4
Rajachu's Avatar
i had almost similar incident where the left rear axile came out from the diff tube while on a high way at a speed of 80km+,the axile slipped out from the sleeve and the wheel was out.The same happend once again,this time right side rear and finally i had to welde the sleeve with the axile.i was told this is the only weak link in a gypsy!
Rajachu is offline   (1) Thanks Reply With Quote
Old 12th December 2012, 13:49   #5
yamaniac's Avatar
Thanked: 99 Times
OMG! Thats pretty scarey... Imagine this happening on High speeds, But you are indeed lucky you weren't fast. This would have been a recipe for disaster.
I once faced a very awkward moment too and boy was that scarey. Was driving my jeep on the Ghats when suddenly I heard a THUD and the rear left side of the jeep was on the ground.. I looked too my left and saw my left wheel running ahead of me, and on to the traffic. But luckily the guy coming from the opposite slowed down. All The nuts of that wheel had come loose. I later replaced on the nuts and bolts on the wheels and since then no problem! I do smile about it sometimes.
yamaniac is offline   Reply With Quote
Hyundai's safety issue - disaster waiting to happen rdkarthik Tyre & Alloy wheel Section 27 12th July 2007 14:15
Tennessee drag car show disaster pawan Shifting gears 3 19th June 2007 16:52
Hamann Ferrari F430 Black Miracle-rather black disaster pawan The International Automotive Scene 13 20th May 2007 17:27
Prado in G Noida expressway disaster suman Street Experiences 24 20th February 2006 16:47
