Old 3rd December 2012, 02:30   #1
ringoism's Avatar
Thanked: 1,537 Times
Default Damper (shock absorber) recommendation for Jeeps?
Thinking of replacing the front (and maybe rear) shocks on our Marshal 4x4, as the damping is compromised on at least one of them and they've been on there so long the lower eyelets have nearly worn through the metal itself!
We don't do hard-core offroad, so things like extra extension are not probably an issue - but up here near Manali, we do drive on really rough roads every day of the year. The Marshal's CG is pretty high and it tends to rock and roll quite a lot, calling for harder damping to control that - but on the other hand good ride quality would be a plus, indicating softer tuning. Like most other things, a compromise is required. What kind of shocks have forum members used / found to be good under similar (or other) conditions?
Many Thanks,
Eric
ringoism is offline   Reply With Quote
Old 3rd December 2012, 03:13   #2
SPIKE ARRESTOR's Avatar
Thanked: 863 Times
Default re: Damper (shock absorber) recommendation for Jeeps?
I had composed this list sometime back, specifically useful for M&M Jeeps. Might be of some use to you, just check.
http://www.team-bhp.com/forum/4x4-ve...ml#post2221669 (Got Jeep! CJ3B Hurricane.)
Spike
Last edited by GTO : 3rd December 2012 at 10:25. Reason: Adding the linked image to your post
SPIKE ARRESTOR is offline   (9) Thanks Reply With Quote
Old 12th December 2012, 01:06   #3
ringoism's Avatar
Default Re: Damper (shock absorber) recommendation for Jeeps?
Originally Posted by SPIKE ARRESTOR View Post
Spike
I don't even know much about what brands are available. I've seen Gabriel, which I guess has always been a decently designed / constructed shock. What else is out there that's decent and not particularly expensive?
-Erik
Old 12th December 2012, 01:11   #4
Thanked: 863 Times
Erik, all the above are decent (depending on your usage) and not at all expensive. I will be surprised and happy to see better, less expensive ones. I guess others can chip in if they have own experiences.
Spike
SPIKE ARRESTOR is offline   (1) Thanks Reply With Quote
Ford Fiesta Classic: Important damper / shock absorber information to keep in mind XetaGLGRocks Technical Stuff 0 16th December 2014 12:30
Innova Shock Absorber Failure CDM Technical Stuff 8 15th April 2013 15:49
Anything special about the Fiesta S' Rear Shock Absorber? abhipuru16 Technical Stuff 6 26th March 2012 08:17
a shock absorber that generates electricity! greenhorn Shifting gears 8 13th February 2009 22:24
