Old 21st May 2013, 12:17   #31
rocky080's Avatar
Thanked: 35 Times
Default Re: Wickedly Radical - Mahindra Bolero Build
Hi Whicked wheels,
Any plans to integrate orange bulbs in one of the fog/parking lamps fabricated to replace the front turn indicators removed?
Nice tyres by the way. The bolero looks meaner with the headlight surrounds blackened out and round headlamps.
How is the light throw after this modification?
Rocky
rocky080 is offline   Reply With Quote
Old 23rd May 2013, 09:42   #32
whicked wheels's Avatar
Thanked: 56 Times
Hi Rocky changing the headlights have really made a vast improvement the light is much brighter and focus has improved. Got some other small mods done, a dead pedal and a hand throttle will post some pics later.
whicked wheels is offline   Reply With Quote
Old 28th May 2013, 14:50   #33
Thanked: 295 Times
Hi Whicked Wheels,
Do you reside in Pradhikaran/Nigdi/Akurdi area, I am pretty sure I saw your Bolero (looks really mean man) at Akurdi Village road, you were at the turn near the Bunty Group site.
Would really want to see the beast in person! And I mean the Bolero
Salil Dalvi
Trojan is offline   Reply With Quote
Old 3rd June 2013, 22:46   #34
Thanked: 56 Times
Yes very much i stay at Akurdi my building is behind shobha sales shop. Come over any time. Ok holidays now over back to some serious work on the bolero will start tomorow. Will keep u guys updated.
Old 5th June 2013, 16:26   #35
Thanked: 56 Times
Work has started on getting the body off.
whicked wheels is offline   (3) Thanks Reply With Quote
Old 5th June 2013, 19:13   #36
Thanked: 295 Times
Ok, so you stay behind Shobha Sales.
Where are you getting the work done, would like to drop in.
Old 8th June 2013, 22:46   #37
Thanked: 56 Times
Got the body off with a lot of difficulty
whicked wheels is offline   (4) Thanks Reply With Quote
Old 10th June 2013, 18:08   #38
Thanked: 56 Times
Started some work on the front suspension, out comes the old
Reverse shackle set up
Now fitted to see the where and how the mounts can be positioned. I want to keep the ride height normal.
Old 10th June 2013, 20:09   #39
ex670c's Avatar
Thanked: 1,821 Times
Started some work on the front suspension, out comes the old Now fitted to see the where and how the mounts can be positioned. I want to keep the ride height normal.
Hi Wicked Wheels,
You can drill a hole in the chassis, sleeve it and reinforce the sides and fit a custom anti-inversion shackle
Arka
Old 10th June 2013, 20:31   #40
Thanked: 56 Times
Hi Arka
I was planning to do the same but the problem is the shackle mount is come just under the engine mount. So yet have to work my way around that problem. The other thing is i am also thinking of going in for longer leaf springs so as to gain more droop (drop) during articulation.
One more question should i go in for SPOA or SUA as this is gonna be my daily drive too. Personally i would keep it SUA. What do u suggest.
Old 10th June 2013, 22:24   #41
prabhuav's Avatar
Thanked: 112 Times
For a daily drive keep it SUA
prabhuav is offline   Reply With Quote
Old 11th June 2013, 10:44   #42
ex670c's Avatar
Hi Arka
Hi Wicked Wheels,
Try and work around the engine mounts.
Longer Leaf Springs may change axle centre and Wheel Base.
KISS -revert to OEM 4x4 Bolero Set up, Its still not too late.
Also(mock up) Fit the steering box first, then weld the leaf spring hangers.
Arka
ex670c is offline   (1) Thanks Reply With Quote
Old 11th June 2013, 10:57   #43
powertrain's Avatar
Thanked: 381 Times
Hello whicked wheels,
What is the purpose to go in for SPOA? If it's better GC & articulation, would "Dog Bone Shackles" be any help for you??
I understand that I'm a completely noob when it comes to 4wd's & offroading, so do take my words at your own risks!!!
Varun
powertrain is offline   Reply With Quote
Old 12th June 2013, 01:50   #44
Thanked: 56 Times
Originally Posted by ex670c View Post
Hi Wicked Wheels,
Arka
Hi Arka
Im just waiting to get the steering box, cant find a power steering box. The rate one guy gave me for a used one was 14k and the new one cost about 19k so did not buy it. On the other hand thinking of going in for the non power steering one. Will that be fine for the bolero.
I want to go for the reverse shackle because its gonna give me a smoother ride. And the longer springs will give me the articulation i want for off roading.
Hi Varun
Dog bone, zigzag , angled or any shape of shackle does not change anything in the geometry of the leaf springs its the distance of the i hole from each other that matters. Check this link you will get a better idea http://www.pirate4x4.com/forum/jeep-...le-basics.html. No hard feeling Varun i too keep on reading all this kind of stuff it helps a lot.
Regards James
Old 12th June 2013, 10:28   #45
ex670c's Avatar
Default Shackle & Reversal
Hi James,
How will Shackle reversal give a smoother ride?
wrt to Longer Leaf Springs, IIRC the Solid Axle is bolted to the Leaf Spring Centre.
So if you use longer leaf springs, with shackle reversal, the wheel base will decrease, since the leaf spring is anchored at one end on the chassis.
If you Longer Leaf Spring with Regular Shackle setup, then the wheel base will increase.
And while you try to do it the right way you will realize, that, the Aprroach angle has changed drastically.
Are you sure that the 4x4 Bolero doesn't have enough front articulation?
Arka
The Frankenbike Build: My Honda CBR 600 F3 Build-Off ap10046 Superbikes & Imports 16 16th July 2013 14:26
Radical new design for London bus kalpeshc The International Automotive Scene 2 9th December 2008 13:15
most radical development in international machines in last 5 years ac 427 The International Automotive Scene 20 2nd December 2005 01:11
Radical SR8 ananthkamath The International Automotive Scene 15 29th October 2005 15:29
