Old 3rd May 2013, 21:02   #16
Thanked: 2,133 Times
Default Re: DIY: Battery Jump Leads for Jeeps & Offroaders
Originally Posted by headers View Post
How did you crimp the cable sir?
If I'm not mistaken, (acid) soldered.
Sutripta
Old 3rd May 2013, 21:28   #17
Thanked: 822 Times
Wrong question, remove the Sir
Ok, I did this using hammer, chisel & bit of bench vice.
These lugs have a seam. If you want to hand crimp them at home, without the use of the crimping tool, try this. (assuming you have selected a proper size of lug for the wire gauge)
# Remove insulation, approx 1.5 times of the lug round portion length.
# Insert the bare cable into the Lug.
# Start poking the chisel on the seam of the Lug.
# It will first take some impact & then the seam will open
# As soon as it opens, press one side fully with hammer on the cable & then take this to the vice & compress, so that another side slides over the bent one. remove from vice & perfect the job with bit of hammering .
This way a little space is left in the lug which holds the cable more tightly & then ready for solder. Although where no soldering is available, with little practice, you can give a taper (funnel) shape to the rounding . So that the cable does not pull out of the hand crimped lug.
Attaching the image, it works something like this.
DIY: Battery Jump Leads for Jeeps & Offroaders-crimp.png
Sudarshan
Sudarshan is offline   (1) Thanks Reply With Quote
Old 4th May 2013, 13:46   #18
headers's Avatar
Thanked: 460 Times
Thanks I do know how to use a crimping tool!!
Though i agree to your method, i would prefer a crimping tool to ensure the bite into the cable is perfect.
Old 6th May 2013, 00:57   #19
byomjeet's Avatar
Thanked: 59 Times
Originally Posted by Sudarshan View Post
There are tables available on net to calculate cable size .
Sudarshan
Good job done. Thanks for posting with the pictures. Can you please send me the links from where I can get the type of cables and the size to be used?
byomjeet is offline   Reply With Quote
Old 30th May 2013, 09:32   #20
Thanked: 822 Times
Smile Re: DIY: Battery Jump Leads for Jeeps & Offroaders
However I will strongly suggest to solder them also.
Search as cable size calculator on Google, & also read the complete thread carefully (all posts). For Jeeps & equivalent engines with a 70/90 Amp/hr battery at hand, a 50 sq mm copper cable up to 2 mtrs length is OK, IMHO.
No need for further research, dont make it too complicated
Sudarshan
Sudarshan is offline   Reply With Quote
Car battery life - How long did your battery last? shuvc Technical Stuff 880 3rd January 2018 15:39
Free Jump starts & Battery help - Exide Batmobile, Mumbai (and other cities) GTO Mumbai 36 28th April 2016 23:50
DIY - Simple Hand brake for Jeeps - Ball Valve as a Line Lock svsantosh 4x4 Technical 22 16th June 2014 06:57
Offroaders - Choose your 4x4 battery carefully GTO 4x4 Technical 99 13th August 2012 00:41
What makes Jeeps such serious offroaders? mayuresh 4x4 Technical 19 19th November 2011 15:03
