Old 23rd October 2014, 18:54   #46
BlackPearl's Avatar
Thanked: 4,713 Times
Default Re: Thar CRDe: Switch to Manual Locking Hubs
Originally Posted by akshay4587 View Post
also the bolero 4WD's come with fixed flanges don't they?
Sent from my iPhone using Team-BHP
My Bolero Di LX 4wd with manual shift came with fixed flanges. I am not sure if the XDP 4wd Boleros with electronic shift also came with fixed flanges or not.
TBHPian himadrimondal has a Thar CRDe with fixed flanges and he has driven extensively without any issues till date.
BlackPearl is offline   Reply With Quote
Old 24th October 2014, 21:33   #47
Thanked: 2,196 Times
Fixed flanges on my 4x4 Boleros/ Armada Grands/ CJs. No real issues.
Sutripta
Old 6th February 2015, 15:18   #48
akshay4587's Avatar
Thanked: 1,639 Times
Time to update the thread.
Ever since i came back from leh on 10th October, the Vibrations due to fixed flanges became too prominent. Recently i took a friend's thar with Auto locking hubs for a 400kms run. On the highway it was really smooth and vibe free as compared to mine. However due to Snow on road we had to switch back and forth between 2H and 4H, and it was a pain to stop and reverse the vehicle to release the hubs else they would start whining.
As for me, i plan to switch to Manual Hubs soon and keep fixed flanges as back up, just in case if i ever need them again.
Old 8th February 2015, 03:36   #49
DirtyDan's Avatar
Thanked: 750 Times
Yup! Same problem for me this year. Also, that accursed CRMV dictate that Mahindra has programmed into their chips, the engine does not kick down in RPM immediately when you take your foot off the accelerator, say in 2nd or 3rd gear. It's definitely an incredibly dangerous little government add on to be aware of particularly on a snowy, icy mountain road. It can put you into a skid if your attention is on something else. Ah well, so much for my rant. "Latin Angels" is on the TV. Time for some intellectual stimulation and thought provoking discourse.
Old 8th February 2015, 11:24   #50
akshay4587's Avatar
Since you are from Dharamshala, and if you do not intend to run your thar in plains for long duration,
i believe fixed flanges might be better for you.
Old 14th February 2015, 18:07   #51
Floating Axle's Avatar
Thanked: 20 Times
Has anyone shifted from Auto Locking Hubs to either (1) Manual Locking Hubs or (2) Fixed Flanges successfully?
In my THAR, I am facing issues with Auto Locking Hubs. And Mahindra ASC knows only to replace.
Really looking for good trouble free solution.
As mentioned by Mr. Dhabhar, can anyone guide me to shift.
Floating Axle is offline   Reply With Quote
Old 15th February 2015, 10:05   #52
akshay4587's Avatar
A bhpian i know has shifted to Manual locking hubs from auto locking after 2 of them failed within 10K kms.
I have one of the thar's that came with fixed flanges. No problems faced apart from little vibes between 80-90km/hr.
Old 17th February 2015, 20:03   #53
Thanked: 20 Times
And how its behaviour with manual hubs in 2WD on highway run?
Old 18th February 2015, 14:55   #54
akshay4587's Avatar
Peformance on Highway in 2H mode should be similar to what it was with Autolocking hubs.
Also the guy has MT tyres so it hardly makes a difference.
Old 18th February 2015, 15:43   #55
Thanked: 20 Times
Ok. Now I decided to go for manual hub. Will update performance. Thanks for help.
Old 21st February 2015, 21:06   #56
Thanked: 20 Times
Today fitted manual hubs on Thar. Can do myself. Yet to test drive. But it appears no nonsense thing.
Lets hope for good performance too.
Floating Axle is offline   (1) Thanks Reply With Quote
Old 21st February 2015, 21:58   #57
akshay4587's Avatar
Brand and price?
Do update on the performance and Engaging and disengaging process.
Btw, you switched from auto locking hubs or fixed flanges?
Old 21st February 2015, 22:11   #58
Thanked: 20 Times
Brand and price?
Lambda, 4200+taxes
I switched over from Auto locking hubs.
Engaging disengaging is easy but you need to step out of vehicle. Performance as I said earlier will update periodically.
Old 26th February 2015, 13:48   #59
akshay4587's Avatar
2 more cases of Auto locking Hubs failing/creating problems in my friend circle.
One thar is like 10 months old and the other not even 10 days old
I am glad i have fixed flanges; living with vibrations is certainly easier than 4WD not engaging in the middle of no where.
Old 26th February 2015, 15:30   #60
Jaggu's Avatar
Thanked: 7,893 Times
Haven't they stopped putting auto lock with Ver 2 Thar onwards? I thought all of them came with fixed assembly?
Remote locking system - Key fobs not working ukamath Technical Stuff 15 21st August 2017 23:15
Query on Manual Central Locking straightdrive Technical Stuff 25 7th April 2015 14:46
AC Switch OFF or Blower Switch OFF Peter Technical Stuff 24 29th June 2011 12:02
Alto Xcite - Upgrade Manual Central Locking to Remote Central locking Laxminarayan Technical Stuff 1 28th December 2009 15:02
Central locking versus remote locking mb_jg Technical Stuff 40 2nd January 2009 20:08
