Old 26th February 2015, 15:52   #61
akshay4587's Avatar
Thanked: 1,548 Times
Default Re: Thar CRDe: Switch to Manual Locking Hubs
Originally Posted by Jaggu View Post
Haven't they stopped putting auto lock with Ver 2 Thar onwards? I thought all of them came with fixed assembly?
They Switched to fixed flanges on thar's manufactured between August and December 2013; but again went back to Auto locking hubs in Jan 2014.
akshay4587 is offline   (1) Thanks Reply With Quote
Old 6th March 2015, 15:50   #62
Floating Axle's Avatar
Thanked: 20 Times
Manual hubs are working well.
I would like to mention here that I visited Autolock Hub manufacturer and happen to see autolock hub in detail - its mechanism and components. I am convinced that these autolock hubs are very good. But literacy of Mahindra ASC may end up in declaring good auto lock hub as DAMAGED. I just saved INR 40000
And this credit goes to one gentlemen called Gajanan Chitale.
So now I have redundancy for locking hubs.
Floating Axle is offline   Reply With Quote
Old 19th March 2015, 21:38   #63
Thanked: 20 Times
Manual hubs are working well. Faced some heating issue on day 1 of fitting, but later vanished.
I would like to note that Lamda service is excellent. The service guy Mr. Azeez took pain to visit local Mahindra service centre to answer my questions.
Floating Axle is offline   (1) Thanks Reply With Quote
Old 12th July 2017, 23:26   #64
Jaggu's Avatar
Thanked: 7,397 Times
Old thread but I picked up an Oct 13 made Thar with fixed flange and it used to make vibration and noise at over 80-90kms. A friend offered me used Lambda in exchange and I installed it about 2 years ago. Best decision, yes one needs to manually lock the hub when you go Offroad, but that 1 minute job is worth it. Working flawless the Lambda manual hub locks. No noise or unpredictable slips.
I understand the auto lock hub needs servicing every 10k kms or so and the amount of grease is critical. Too less or too much they just start giving you headaches.
Jaggu is offline   (2) Thanks Reply With Quote
Remote locking system - Key fobs not working ukamath Technical Stuff 15 21st August 2017 23:15
Query on Manual Central Locking straightdrive Technical Stuff 25 7th April 2015 14:46
AC Switch OFF or Blower Switch OFF Peter Technical Stuff 24 29th June 2011 12:02
Alto Xcite - Upgrade Manual Central Locking to Remote Central locking Laxminarayan Technical Stuff 1 28th December 2009 15:02
Central locking versus remote locking mb_jg Technical Stuff 40 2nd January 2009 20:08
