Old 2nd September 2013, 12:01   #1
Thanked: 64 Times
Default Jeeps: Improve fuel-efficiency of the Hurricane & Go-Devil Engines?
This was the other idea I had for a sticky post. Since I see a revival of a lot of petrol-engines for jeeps, for some strange reason, I thought a post like this would go a long way in helping existing and potential owners make it atleast halfway financially worthwhile to own one of these legends.
vivekjayasheel is offline   Reply With Quote
Old 2nd September 2013, 14:15   #2
Thanked: 64 Times
Default re: Jeeps: Improve fuel-efficiency of the Hurricane & Go-Devil Engines?
One idea I had was to advance the timing a bit. In those days, lead was used as a softener instead of higher octane. So fuel would be at best 87 octane. Now it is 91 octane and advancing the ignition timing might help compensate for that. Skimming the heads and reducing the bowl volume may have the same effect but would need much more care to ensure that the piston crown does not foul with the valves. I am not even sure if Jeep engines need valve-train hardening or lead additives to make them run smoothly and for many thousands of kilometers, or not.
Another idea would be to use the correct spark-plug range. A plug chart for NGK, ND, Bosch, and other equivalent plugs will go a long way in ensuring that owners of petrol jeeps use the correct spark-plugs. Note that NGK denotes a warmer plug with a smaller number (so an NGK 7 is a hotter plug than an NGK 9) and Bosch with a higher number (so a W5 is a colder plug than a W7).
vivekjayasheel is offline   (1) Thanks Reply With Quote
Old 2nd September 2013, 14:49   #3
Thanked: 91,881 Times
Default Re: Jeeps: Improve fuel-efficiency of the Hurricane & Go-Devil Engines?
Not specific to the Hurricanes, but this advice article has a load of fundamentals that might help
GTO is offline   (1) Thanks Reply With Quote
Old 2nd September 2013, 21:08   #4
Thanked: 822 Times
Cool Re: Jeeps: Improve fuel-efficiency of the Hurricane & Go-Devil Engines?
@ vivekjayasheel
Check the following for your purpose if possible
## Exhaust back pressure arrangements & or combinations.
## Fresh Air bypass valve based on engine temperature
## Transistor based ignition , yet still retaining the points ( old trick people did when point ignition was common )
## Dual ventury carbs , the second opens at loads ( high throttle only )
## Return fuel lines from carbs. ( if they dont exist)
Sudarshan
Sudarshan is offline   (1) Thanks Reply With Quote
Toyota introduces 1.0 & 1.3 engines with improved fuel efficiency sarathlal The International Automotive Scene 2 16th April 2014 09:37
Mumbai Suburban Trains : Cyclic timetable claimed to improve safety and efficiency mayuresh Shifting gears 0 21st February 2013 19:22
Hurricane is "Gone" ... Long Live the Hurricane RAINMAKER 4x4 Vehicles 11 21st April 2010 09:28
Engines of the Devil ak916 Shifting gears 11 14th October 2008 12:17
Does Fuel Efficiency Improve over time and mileage covered? architect Technical Stuff 1 8th May 2008 17:41
