Old 9th September 2013, 11:16   #1
Thanked: 18 Times
Default Relocating the Intercooler
Mod Note : There are several spelling & grammatical errors in your posts. This negatively affects the forum experience for other readers.
Kindly ensure that you proof-read your posts prior to submission. Also, it would be a good idea to use spell-checkers.
We have an MM550 NGCS with an Isuzu 4JB1 TC iC engine. It has the intercooler installed on top of the engine. We have fitted a Scorpio scoop on the bonnet for air which it gets only when the vehicle is moving.
Will it be a better idea if I move the intercooler to the front of the radiator where the air flow is more due to the suction by the fan? Please suggest.
Mods: Please move it if a thread already exists.
Thanks,
hps aulakh is offline   Reply With Quote Received Infraction
Old 9th September 2013, 14:20   #2
HillMan's Avatar
Thanked: 401 Times
Default re: Relocating the Intercooler
The best place for an intercooler is right in front of the radiator in the front of the car. There is enough ambient air up front coming through the air dam. The radiator fan on the other hand turns on and off based on engine requirements.
HillMan is offline   Reply With Quote
Old 9th September 2013, 17:25   #3
Thanked: 64 Times
IMHO the current position is also ok as the turbo will be under load only when the vehicle is moving. Revving the engine in neutral won't load the turbo.
vivekjayasheel is offline   Reply With Quote
Old 9th September 2013, 19:42   #4
dhanushs's Avatar
Thanked: 4,116 Times
If I may ask, why do you intend to move the intercooler from its current location?
A few things that might help you decide. A front mounted intercooler has a better cooling efficiency than a top mounted one, however, longer plumbing is needed, which I guess is not a good thing. Additionally, the front mounted intercooler will block a percentage of air to the radiator making the engine run hotter.
Old 10th September 2013, 08:31   #5
Thanked: 822 Times
Default Re: Relocating the Intercooler
In offroad scenes the low gear crawl is just a walking pace with loads one cant imagine. Just think if a vehicle is not moving in normal first gear, it needs twice the effort , now from where the passing air quantity (compared to load & RPM of engine) will come from, at that " walking Pace " ??
BTW anyone thought of putting a fan on the engine top cooler ? Will save the relocating process . IMHO
Sudarshan
Sudarshan is offline   (1) Thanks Reply With Quote
Old 10th September 2013, 09:28   #6
HillMan's Avatar
Thanked: 401 Times
Totally agree with you on this. The natural air under the hood wont be much for the intercooler which will be running through most of the drive. Specially in a hill climb and bumper to bumper slow traffic when RPM keeps going up and down. And sometimes when wind in not in your direction, the hood wont scoop any air for cooling.
To avoid plumbing guess a flat fan like this can be slipped under the heat sink. I believe these can be found in shops that sell Inverter/UPS components. They can continuously run for hours in hot environment.
HillMan is offline   (1) Thanks Reply With Quote
Intercooler placement question tsk1979 Technical Stuff 52 19th October 2008 22:53
Is My 99 Safari Turbocharged With Intercooler?? shahmotors Technical Stuff 14 15th May 2007 01:54
Turbo Intercooler Or A Wide Body Kit ?? ollie Modifications & Accessories 37 25th July 2006 23:08
New Tata Indigo TDI: With InterCooler Turbo Digital Vampire The Indian Car Scene 21 31st March 2005 21:37
The best place for an intercooler GTO Shifting gears 2 3rd September 2004 04:35
