Old 17th January 2014, 20:16   #16
Thanked: 2,407 Times
Default Re: MM550 XD3P : Timing Chain Failure
Going by the damage to the camshaft sprocket/ key area, would say that timing chain breakage was the result, not cause.
Sutripta
Old 18th January 2014, 06:28   #17
DirtyDan's Avatar
Thanked: 776 Times
Sutripta
It ran well for 25,000K with new timing components installed. To me this is strong evidence that the cam, pulley etc. were installed correctly else there would have been obvious trouble immediately. The statistical "usual suspects" are the tensioner and chain. A broken chain jammed in the timing box at moderate rpm could easily cause massive damage like that.
Sutripta is obviously devoid of all reason, he is under papal influence from Rome and his sister sings off key. Therefore, he is not to be trusted.
DirtyDan is offline   (3) Thanks Reply With Quote
Old 18th January 2014, 18:08   #18
pranavt's Avatar
Thanked: 274 Times
Not well versed with these engines or cars. How likely would it be that the cam seized and took everything else with it? I've seen these issues elsewhere and in quite a few cases, it was lack of oiling to the cam journals. In some of those cases, you'd have the cam split in half. In other cases, the cam would stay intact, taking most of the timing assembly out. Depended on the cam hardness.
pranavt is offline   (3) Thanks Reply With Quote
Old 18th January 2014, 20:38   #19
Hi Dan,
How are you? What do the doctors say?
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 18th January 2014, 21:49   #20
Very high possibility.
However, since a blame game (with financial implications) is very likely to ensure, I for one would hold my thoughts unless certain (guilty beyond reasonable doubt, as the American courtroom TV scenes will say!) Which we really can't be.
Sutripta
PS: Cam breakage is more often than not the result of something else. Not relevant for this thread.
Old 18th January 2014, 22:42   #21
pranavt's Avatar
Thanked: 274 Times
Absolutely. I'm not blaming the cam. I'm blaming oil, or rather, the lack of it. Not much else for me to contribute in this thread. Though I'd love to see more/better carnage pics. Especially to see if any part of the cam is discolored.
pranavt is offline   (2) Thanks Reply With Quote
Old 19th January 2014, 20:06   #22
No, was not talking of cam journal seizure. Was talking of fatigue failure (the cam has cyclical variations of loading, opposite directions). And that is absolutely OT for this thread.
Sutripta
Old 19th January 2014, 20:59   #23
Thanked: 9,025 Times
No, was not talking of cam journal seizure. Was talking of fatigue failure (the cam has cyclical variations of loading, opposite directions). And that is absolutely OT for this thread. Regards Sutripta
Be interesting to see if you can ever determine the root cause. Im not familiar with this type of engine, but of course lack of oil wont do any good on any engine.
Never the less I would take a hard look at the tensioners as well.
Jeroen
Jeroen is offline   Reply With Quote
Old 19th January 2014, 22:04   #24
Not possible (by me at least)
I too am puzzled about the root cause.
However, I would repeat
I remember a case (not this engine!) where a cam bush had seized on the cam journal, and turned around with it. (The engine was running, albeit with strange noises. Was stopped when ultimately there was a sudden drop in oil pressure. Metallic granules were found in the oil pan.)
Even after lots of shouting/ brainstorming one could not choose between the two competing theories:
Lubrication failure (whatever be the cause) leading to the bush welding itself on to the cam journal, and turning with it in the housing.
or
Bad assembly leading to the bush shifting position leading to misalignment of oil ports leading to .....
Root causes can be tricky to find! Best not to pass of speculation as oracular wisdom.
Sutripta
Old 20th January 2014, 10:07   #25
You're probably right, with this much damage, very difficult to come to some sort of conclussion. Are these engines known for similar problems?
Jeroen
Old 20th January 2014, 23:57   #26
Thanked: 247 Times
@ All - Thanks for the valuable advice posted.
We managed to locate a decent condition engine in mayapuri and cam and timing case was taken off from it. Rest all was bought new and engine was put back. Valve action was found ok and thus head was not opened.
After setting the tappet clearance, the engine fired just fine.
A big relief
pic of reassembled engine all ready to be fired
MM550 XD3P : Timing Chain Failure-wp_000568.jpg
After installing the engine back I got the whole vehicle serviced as well (changed all filters - oil, fuel, air), brakes overhauled (leather of brake shoes and disk pads changed). The mounting bush of front grill had broken and whole front of jeep was nosediving. Got that welded as well.
Drove the jeep back and while it ran well, something felt too tight. There was absolutely no torque. Stopped after 10kms and on checking found the oil a bit low. I had poured 5lts earlier but I guess since sump was emptied it required more. Poured in a lt. more and drove on. Immediately felt a huge difference. In the next 20kms the engine became much more responsive, I guess the new timing chain and cam must be bedding in.
Came back home and parked it. Noticed the amp meter showing a low charging - less that 12V. Sure enough it dint crank the next morning
Have put the battery on charging now. Looks like some loose connection while assembling back the engine.
Originally Posted by Timson View Post
It would be advisable to dismantle the entire engine clean it and reassemble. At least inspect the condition of values, piston crown and check for traces of metal fragments in the sump.
I have gone against the popular advice here and not opened the head. No tell tale signs from outside and high cost of head gasket kept me from doing it. The sump was opened and cleaned.
Originally Posted by DirtyDan View Post
Chains break with age for sure. Contributing factors might be badly set tension making the chain too tight or too loose. Either will make a chain wear faster. Just speculating here. Scuff marks are coming from chain?
I too think it wasnt set right during the engine rebuild. Yes scuff marks were from chain on the inside of timing case. That too pretty deep ones. So it was running loose for sure for some time.
Would you be inclined to go the DiTurbo way? Anyways you are looking at nearly a full 50k xd3p rebuild, might as well look at bigger or later engines?
50K!! god forbid, please dont scare me. Thankfully I got away with a tad over 1/10th of that number.
I have been trying to talk myself into a DiTurbo but I just cannot see the value preposition.
Spending 80K on an engine which is of older generation, much noisier, cruder and less revvable. Add to that the vehicle will not be road legal anymore. Only advantage is marginally higher torque and low maintenance. This much hassle and money on a weekend ride doesnot maked sense to me. Even if I had to rebuild the engine I would have gone ahead and spent 50K on Xd3P rebuild or maybe spent a lakh for a scorpio non crde engine. There is a thread running on tbhp that I am religiously following.
Originally Posted by ex670c View Post
The please pick up the part yourself and be there when the installation is being done.
The Brand New camshaft cost 4-5K.
Is there any chance the Lower Pulley hit the differential while off-roading?
Also could be a case of improper assembly.
My Guess is one of the Gears inside the Timing Case Broke, stripping the Timing Chain and breaking other gear in the process.
Or the Chain Tensioner broke, binding everything inside and stripping the Timing Chain.
Any pictures of the timing case and internal parts before they were removed.
Thanks for replying Arka. I couldnt accompany my mechanic to pick up the shaft from mayapuri as it is closed on sunday and that is the only day I can spare. Not that I have any knowledge of identifying a good camshaft. Had I know the cost of new one earlier I might have gone for it. I assumed it to be close to 10K.
Can lower pulley hit differential?
My front leafs are a bit flat but bump stops are in place.
It was the lower pulley which had jammed against the timing case when my jeep broke down. The top side of pulley was touching the case and lower away from it.
I had just pulled out of an off road section taken on the fly.
You see running late to office in a jeep tempts you to take nonsensical shortcuts to make up time you loose on straights. Its a different matter that I never managed to reach office that day
Originally Posted by motocamp View Post
It will make sense to remove the head and have a look at your valves, guides and tops of your pistons
Also check the pushrods, you might find a few bent ones too.
Make sure your mechanic disassembles the head while you are at it, it will be well worth it in the long run.
Ensure valve timing is done in respect to cylinder 1 ( the closest to the radiator) at TDC and all the marks align.
Shortcuts now and repent at leisure
Thanks motocamp but against yours and others advice, I have taken a shortcut here. It looks OK so far, but what do I know then. Lets wait and see how the story unfolds.
Your advice of timing is over my head. I will call my mechanic and grill him on how he did it.
Read my comments on marks of timing chain slapping inside the case. How do you propose now?
It ran well for 25,000K with new timing components installed. To me this is strong evidence that the cam, pulley etc. were installed correctly else there would have been obvious trouble immediately. The statistical "usual suspects" are the tensioner and chain. A broken chain jammed in the timing box at moderate rpm could easily cause massive damage like that..
+1, a slightly misaligned pulleys would have also increased the wear on chain. I am pretty sure it was elongated beyond permissible tolerance
Cam looked absolutely fine with no burn / scuff mark other than stripped head towards timing chain side
Oil level and viscosity was fine. Once something broke inside the timing case it made mince meat of everthing else inside. So I guess this shall remain mystery.
Nope I have never heard of timing chain failing. My mechanic says he is also seen it for the first time
cheers
Vishwas
vishwaschettri is offline   (2) Thanks Reply With Quote
Old 21st January 2014, 20:20   #27
No. IMO quite robust as long as you keep it from overheating. The off roading community dont like these though.
Sutripta
Old 24th January 2014, 09:45   #28
Thanked: 247 Times
My jeeps bad luck phase just refuses to end.
Charged the battery at home and installed it today morning to take it to office.
It did not crank at all. Just a khut sound, looks like starter is stuck. Will try and push start it to release stuck starter tomorrow.
Any other advice on this? its not easy to get people to push this heap of scrap metal.
I am thinking of applying the highly scientific method of limbu mirchi to ward off any future troubles
cheers
Vishwas
vishwaschettri is offline   Reply With Quote
Old 24th January 2014, 11:52   #29
cheers
Vishwas
When it rains it pours!
Maybe a silly / obvious question, but did the battery really charge? Put on the headlights and see if they're bright. Cehck the battery voltage. Check the battery connections for corrosion. If it is the starter and or starter relay sometimes a simple whack on the starter will help. If not, you have another job at hand I'm afraid.
Good luck!
Jeroen
Jeroen is offline   (1) Thanks Reply With Quote
Old 27th January 2014, 10:54   #30
Thanked: 247 Times
You bet. I followed your advice to the T, I had earlier charged the battery by connecting it in parallel to my home inverter.
Got hold of a battery charger and charged the battery again overnight. Borrowed a multimeter and hydro meter and it came all aces.
But still same khut sound on cranking. Gave the starter a few taps and rocked the jeep in gear but no avail.
Finally got under the jeep and found the positive connection on starter loose.
My mechanic must have left it loose when he removed the engine.
AArrggghhh..... I am gonna kill him. A few turns of spanner in a very hard to reach, poorly designed workspace by mahindra and the Jeep gods finally smiled and it roared to life.
Charging voltage shows 13.7V on the multimeter. I would have liked it to be above 14V but will do.
Dash voltage meter was still showing below 10V. A few taps with finger and it is also now beaming at 13.5V.
While I was giving it a final inspection before pulling down the hood, saw a few drops of water below the water body pulley.
Now I have a new agenda for next week.
I guess the jeeps gods were giving me a wicked smile afterall.
cheers
Vishwas
Harjeev's RANGER - MM550 XD3P 4x4 (Latest Pics Updated Pg-41) harjeev 4x4 Vehicles 611 4th April 2013 12:09
MM550 chain timing Help! motocamp 4x4 Technical 6 21st April 2010 12:57
520 Chain (Karizma Chain) Query DeepakMenon Motorbikes 11 10th December 2009 12:29
Timing (cam) belt vs chain sbasak Technical Stuff 33 10th November 2009 16:00
ford ikon 1.6 timing chain noise? silver_shadow Technical Stuff 7 29th November 2008 19:50
