Old 16th February 2014, 20:17   #16
Thanked: 2,404 Times
Default Re: The Unusual Oil Cooler - How Effective?
I have an oil pipe flowing to the turbo from the left of the engine to the right of the engine.
The turbo lube feed line? That is one line I would be wary of fiddling with. Also, I don't think you'll have sufficient flow to make any real difference. Check out flow from drain to confirm or disprove.
If other things work out, why not from the turbo drain. That is when the oil will be hottest, and will benefit most from cooling.
Originally Posted by Grace View Post
The rate at which the oil cools down is slower than that of water / coolant,
Don't get this.
Sutripta
Old 17th February 2014, 16:14   #17
DirtyDan's Avatar
Thanked: 776 Times
Sutripta
If the oil used is not synthetic oil then maybe putting the cooler right before the turbo oil intake would be a better idea. High temperature tends to noticeably alter the chemical make up of natural oil causing it to lose it's lubricity, it's lubricating function. And, turbos can be real cookers. This placement before the turbo would tend to eliminate hot spikes of oil entering the turbo and being further super heated. Of course, if you want to be really snazzy put one before and one after.
DirtyDan is online now   Reply With Quote
Old 11th April 2014, 16:45   #18
svsantosh's Avatar
Thanked: 1,444 Times
Lightbulb Re: The Unusual Oil Cooler - How Effective?
I recently picked up a Maruti800-Automatic (3Spd) 1990 model (from Tbhp Classifieds).
The Auto box cools the transmission oil per the following pics. I had sent this to Dhanush a month earlier, thought it will be of help here for future ref.
svsantosh is offline   (1) Thanks Reply With Quote
Absence of Oil Cooler in New Swift - How important is it? Sankar Technical Stuff 37 9th October 2014 20:40
Civic Oil Sump crack. How effective is Brazing? Speed Pujari Technical Stuff 26 8th November 2013 13:59
Oil cooler for 350 mankamble Motorbikes 9 8th February 2010 13:55
Turbocharged 800 Oil Cooler racerdabba Technical Stuff 36 30th October 2008 17:36
