Old 11th February 2014, 11:42   #1
dhanushs's Avatar
Thanked: 4,126 Times
Default The Unusual Oil Cooler - How Effective?
Hi All,
I'm upgrading my radiator to the huge Bolero XD3P one. However, the radiator is a 2nd hand one, and I need to recondition it. So, while at it, I was thinking of running an oil pipe through the length of the bottom tank - In a zig-zag way.
Unlike those army oil coolers, this one should be much more effective. Also, assuming an oil pipe less than 10mm dia, the loss of tank volume should be around ~10 percent. And, I guess there should not be any interruption in flow. Also, I have a feeling it might need a half a liter or so more oil in the sump?
So, what do you guys think? What could possibly be the short comings?
Image Source: http://cdn2.autopartsnetwork.com/ima...1_20111215.jpg
Old 11th February 2014, 13:23   #2
Blow Horn Ok's Avatar
Thanked: 371 Times
Default Re: The Unusual Oil Cooler - How Effective?
I believe getting the oil pipe through the tank would result to a leaky radiator if the sealing is not done properly, or the surface around the weld corrodes/disintegrates in future.
In my opinion, it would be good to place a separate slim oil cooler just in front of the radiator (if there is adequate space). This one would work along with the radiator and would be cooled by the radiator fan if the vehicle is idle.
If you go either of the route, it would be better to attach a heavy duty rubber pipe (used in hydraulic systems) for inlet and outlet at the mouth of the oil cooler/radiiator and tighten it with good quality clamps on both sides to prevent cracks and breakage due to engine vibration.
Attaching an image for reference of a similar setup of my Leyland generator engine.
Blow Horn Ok is offline   (3) Thanks Reply With Quote
Old 11th February 2014, 14:01   #3
svsantosh's Avatar
Thanked: 1,392 Times
I wont be surprised if you have already completed the mod and teasing us seeing how we would react!!
Copyright - respective owners
If not, try to do ^^ from a bike like pulsar.
PS - Army550 Oil Cooler looks amazingly effective. Design wise, the flow of water is directly from the propeller/impeller (?) of the water pump, ensuring more flow of water... I guess
svsantosh is offline   (2) Thanks Reply With Quote
Old 11th February 2014, 16:06   #4
Thanked: 35 Times
Infractions: 0/1 (5)
Hi All,
There is nothing unusual in it. In fact this method is widely used in bigger trucks as transmission oil cooler
dracul is offline   Reply With Quote
Old 11th February 2014, 17:23   #5
condor's Avatar
Thanked: 4,432 Times
But how will you make the pipe attain & maintain that position inside ?
condor is offline   (2) Thanks Reply With Quote
Old 11th February 2014, 17:45   #6
Shubhendra's Avatar
Thanked: 1,178 Times
Attachment 1207028
Santosh Ji,
above suggested mod is relevant for engines with less CC (cubic capacity), in fact many RE owners have opted for above mod, which is simple cut and paste job.
Do you think, above mentioned oil cooler would suffice the purpose for engine more than 2000 CC of displacement. Why not a oil cooler from Thar?
Shubhendra
Shubhendra is offline   Reply With Quote
Old 12th February 2014, 00:00   #7
dhanushs's Avatar
Hi Parwath, only the inside of the radiator will be metal pipes.Till the inlet and from the outlet will be rubber pipes, so that the whole radiator unit acts as one.
Does Thar have an oil cooler? Which current LMV engines have oil cooler?
Old 12th February 2014, 11:49   #8
Santosh Ji,
Shubhendra
Hi Shubhendra,
Is it possible to fix the Thar's oil cooler on a mm540 dp engine. What will be the pros and cons. I have a ac too.
Roji
roji is offline   Reply With Quote
Old 12th February 2014, 13:21   #9
Shubhendra's Avatar
My bad, i mixed intercooler with oil cooler. I am yet to get used to of new generation technology,still cant get over of F4-134, XDP, DITC, XD3P etc....
By the way i drove a CJ3B fitted with 4FG1 with 5+1 qith 4WD on sand dunes for a week and just loved the smoothness and peppy performance on sand !
Shubhendra
Old 12th February 2014, 19:19   #10
svsantosh's Avatar
Dhanush, i think you need to look beyond automobiles and into industrial stuff. Want to scourge bamboo bazaar industrial scrap in Bangalore? Let me know and we can hook up there on a WK day.
svsantosh is offline   Reply With Quote
Old 12th February 2014, 20:03   #11
vikram_d's Avatar
Thanked: 937 Times
This simple yet super effective oil cooler is from a Mondeo. Can get one made on J.C.Road.
vikram_d is offline   (3) Thanks Reply With Quote
Old 12th February 2014, 20:04   #12
Grace's Avatar
Thanked: 159 Times
Tell me something,
The rate at which the oil cools down is slower than that of water / coolant, so now would not that actually beat the purpose? Or is my understanding not thourough? I am assuming that oil WILL not flow in coolant duct of the the engine and back to the radiator, it is just a supplementary pipeline outer casing trying to absorb heat from the radiator water / coolant.
Would some one clarify please
Andy
Grace is offline   Reply With Quote
Old 12th February 2014, 20:25   #13
Thanked: 2,133 Times
The oil pipe will be under pressure. Needs to be sturdy. Needs to be properly supported so that it does not vibrate inside the tank and develop cracks. External pipe routing might be easier if the the internal pipe is looped back and both inlet and outlet are at the same side.
Inlet and outlet from adapter at filter?
My suggestion:
First instrument your vehicle to see what oil and radiator bottom tank temperatures you are running. Then mimic those conditions outside to see whether you are getting the benefits you want. Then go ahead with your mods.
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 14th February 2014, 22:02   #14
Thanked: 171 Times
Dear Dhanush
Like others have suggested- A dedicated oil cooler is better.
No one would like to have the oil and coolant mixed. In case the joint at the oil hose and radiator bottom develops crack and start to leak, it would prove to be a disaster.
Few suggestions-
1. If you need air-water cooled oil cooler then go for the radiator of cars with automatic transmission. They have a provision for cooling the transmission oil. The lower part of the radiator has a separate oil cooling passage and connection.
2. In almost every diesel car now in the market, there is an in-built water-cooled oil cooler assembly just behind the oil filter.
Ex: TUD-5, Indica/indigo 475idi, Multijet, TDCI etc all of them have an oil cooler just behind the oil filter assembly.
Universal aftermarket bolt on solutions are available, just search on ebay.
interc00led is online now   Reply With Quote
Old 16th February 2014, 11:09   #15
dhanushs's Avatar
Hi Sutripta,
I'm planning a metal oil pipe inside the bottom tank, the zig-zag design was chosen, so that, I can spot weld on the top and bottom.
Also, regarding pressure, wont the pressure on the pipe be lesser (minus the radiator water pressure) inside the radiator? Will that change cause any issues?
I have an oil pipe flowing to the turbo from the left of the engine to the right of the engine.
Was planning to route this through the radiator? Or does it need a dedicated line? With oil back to the sump in pressure?
Yes, thank you. Will do.
Hi, Sorry, I got your question wrong the first time. I will be dismantling the radiator bottom tank and fixing the pipe.
As long as there is temperature difference, the hotter liquid will lose heat.
The oil will come from an outlet from the engine, flow through the radiator, lose heat, and the cold (comparatively) oil will return back to the oil sump.
Absence of Oil Cooler in New Swift - How important is it? Sankar Technical Stuff 37 9th October 2014 20:40
Civic Oil Sump crack. How effective is Brazing? Speed Pujari Technical Stuff 26 8th November 2013 13:59
Oil cooler for 350 mankamble Motorbikes 9 8th February 2010 13:55
Turbocharged 800 Oil Cooler racerdabba Technical Stuff 36 30th October 2008 17:36
