Old 21st February 2014, 17:16   #1
ravi_xx's Avatar
Thanked: 26 Times
Default Feedback on Ironman Suspension?
I drive a 2009 Mitsubishi Montero Automatic 3.2 DiD and I am considering installing Ironman Suspension on it. However, am worried that the ride may become unduly harsh. I am unlikely to use it offroad; my usage will predominantly be in Mumbai (which has relatively crappy roads, to be honest) and on inter-city highways.
If anyone has a full-sized SUV such as a Land Cruiser / Montero / Pajero / Fortuner with Ironman Suspension installed and wouldn't mind giving me a short ride in their vehicle, that would really help. Would really like to experience it before I plonk down the dosh to buy it.
Thank you in advance for your help.
Ravi
ravi_xx is offline   Reply With Quote
Old 21st February 2014, 20:35   #2
Thanked: 647 Times
Just got myself a full set of Iron Man suspension for my Montero. Will let you about the ride and handling after I get it installed on Monday, 25th.
jyobeb is offline   (2) Thanks Reply With Quote
Old 22nd February 2014, 14:51   #3
Thanked: 91,866 Times
Default Re: Feedback on Ironman Suspension?
Would've understood if you were looking at a lift or increasing it's offroad ability. But since you aren't, why Ironman? The Montero's stock suspension setup is superb for Indian driving conditions and I'd personally stick with that only.
@ Jyoyeb: Look forward to your review.
Old 22nd February 2014, 16:59   #4
Thanked: 1,506 Times
Ironman suspension components come in a few options. Notably, their springs can be for Comfort, Performance or Constant Load - each of these have different behaviour. Since your use is primarily in city, you might want to opt for Comfort springs, with Foam Cell Shocks that do a really good job of damping - I use these on the rear of my leaf-sprung LC76 (with Ironman performance leafs), and the change was good enough to make the rear seat usable.
I believe the comfort series makes vehicles more comfortable than stock if paired with the Foam Cells, but I wonder how you find the soft Pajero springs harsh? If its damping you want to improve, don't bother changing the springs just replace the shocks with Ironman FoamCell.
EDIT: Pajero catalogue here: http://www.ironman4x4.com/html/mitsubishi/42.html
Steeroid is offline   (1) Thanks Reply With Quote
Old 23rd February 2014, 10:33   #5
Thanked: 647 Times
I had the older Montero (2007 model) which was an absolute delight. I loved that car and enjoyed 1,25,000 kms of motoring on it. Infact I liked it so much that I decided to replace it with the new Montero 2010 model, which in hindsight, was a crappy decision.
The new Montero automatic, is powerful with 200bhp, has a much more modern dash and more airbags, but the guys just lost it in the ride department.
The car wallows too much when taking curves fast, but still manages to crash into potholes and generally gives a hard ride inside town. How the Mitsubishi guys managed to screw up the low speed ride and the high speed ride at the same time, is a mystery indeed.
I installed a set of TJM heavy duty springs and shocks which I removed in two weeks. The ride, which was far too firm, made the handling great but was terrible on anything less than perfect roads.
Hence now, my trial with the Ironmans. I told Zac that I needed a firm ride which removed the boatlike handling but that I needed a certain level of comfort also.
I will know soon!
Old 23rd February 2014, 17:01   #6
ravi_xx's Avatar
Thanked: 26 Times
@jyobeb - look forward to your feedback. that will frankly determine whether i keep the montero or sell it.
thanks
Ravi
Old 23rd February 2014, 17:19   #7
Thats strange, because the suspension components are exactly the same (at least abroad for the Petrol models) for all the Pajs post 2001. Or so we're told....
Steeroid is offline   Reply With Quote
Old 23rd February 2014, 18:04   #8
DirtyDan's Avatar
Thanked: 747 Times
I am going to tell you something which you may at first think is stupid...considering the author, you may be right...
You might try tinkering a bit with the air pressure in your tyres. Take note of the suggested air pressure. Add 5 lbs to that and test it. 5lbs can make all the difference in the world. Often "wallow" is not a spring/shock problem, it can be a problem of radial tyres sidewalls flexing too much under the centrifugal force. 5lbs can stop the over-flex to a degree that can surprise you.
Also, a set of top quality tyres can make a world of difference....Michelins, Continentals, etc.
DirtyDan is online now   (1) Thanks Reply With Quote
Old 23rd February 2014, 18:41   #9
Thanked: 647 Times
Dan, pretty much tried every trick in the book to no avail.
The issue was pretty much the same on the other similar model Monteros.
The suspension part numbers for the pre-2007 are different from the post-2007 Montero which makes me assume that they did indeed tinker with the suspension parts post 2007.
jyobeb is offline   (1) Thanks Reply With Quote
Old 23rd February 2014, 21:57   #10
Jaggu's Avatar
Thanked: 7,676 Times
Have you tried just replacing the shocks? Sometimes that is the cheaper and gives best of both worlds performance.
Old 23rd February 2014, 22:54   #11
Thanked: 647 Times
Nope! I'm a sucker for punishment! The bilstein dealers wanted 55k only for the shocks, hence decided to try the IronMan! Zac will live upto his promises I think!
I actually tried stock shocks and TJM springs, then TJM shocks and stocks springs, and ended up pissing off my dealer with my shenanigans !!
jyobeb is offline   Reply With Quote
Old 24th February 2014, 10:08   #12
Thanked: 647 Times
I accidently got sent 2 sets of rear springs. Waiting for Zac to send me the front springs. Installation will happen after they arrive.
Old 28th February 2014, 13:37   #13
Thanked: 647 Times
I just drove my Montero back after the IronMan set was fitted.
First impression was that there seems an appreciable lift of almost 2 inches.
The ride on the highway was good with minimal swaying and very good high speed grip.
When I went into potholes, I still felt it was not as good as a Toyota, but it was far better than it was with the stock shocks.
On the whole, I am very happy with the Ironmans. I could have been happier with a softer ride but not if it meant compromising my high speed ride.
In my opinion, a definitely worthwhile upgrade.
Old 28th February 2014, 16:57   #14
Thanked: 131 Times
Hey do keep us informed as to how it works. Have a 2011 montero with the same problems that you are talking about, wallowing at high speed turns. would be interesting to know if the IM's work for this
53BHP is offline   Reply With Quote
Old 25th January 2017, 12:09   #15
RedOne's Avatar
Thanked: 19 Times
I realize this is an old thread but am trying to get a long term evaluation of the Ironman.
I have a 07 Montero (new model with the added weight) and though I find the handling to be acceptable, the low speed ride is not. Handling had improved when I changed from earlier Maxxis Bravo HT to Michelin Cross Contact AT tyres. It crashes through pot holes and is most unsettled on short sharp ruts and ridges. Deeper potholes or undulations are not that much of a problem.
Jyobeb, what is your long term evaluation of the Ironman setup? What springs (comfort/performance) and dampers (Nitro/foam cell) combination did you go for?
Gears,
Red-One.
RedOne is offline   Reply With Quote
1998 Toyota 90 Series SWB 3 Door Land Cruiser Prado. EDIT: Now with 2" Ironman Lift khan_sultan 4x4 Vehicles 94 20th June 2014 16:34
Heard of Ironman tyres? abhijitpal83 Tyre & Alloy wheel Section 8 26th November 2011 07:31
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
Feedback for baleno whizdull The Indian Car Scene 27 28th June 2005 16:59
Requesting feedback on Fiat Dealer in Bangalore Samurai Indian Car Dealerships 23 11th March 2005 18:22
