Old 11th April 2014, 18:31   #16
arjuunz's Avatar
Thanked: 27 Times
Default Re: Land Rover reveals "Transparent Bonnet" concept
Nice concept! Although I doubt how many will actually make use of such a feature. You'll have to a serious offroader.
By the way, I didn't get the idea of what they are projecting! Is that an actual video of the road, or an animated view? If its augmented reality, then it should be an actual video of the terrain and a pair of tyres augmented graphically into it. Thats what I understood from it. How did they manage to get such a clear video of the terrain ? Shouldn't it be very dark under the car ?
arjuunz is offline   Reply With Quote
Old 11th April 2014, 22:28   #17
Thanked: 9,307 Times
Quite cool, yes. But the fact is that it only works absolutely perfectly from ONE point of view, and decently well from one line of view, but certainly doesn't work seamlessly from other viewpoints.
cya
R
Thanks, I see what you mean.
I don't think its a big thing in this particular case.
The angle variations from the drivers eye due to movement of the head are very shallow/small and its very easy to slightly blur out the image at the edges of the bonnet.
Will be interesting to see in real life.
Jeroen
Jeroen is online now   Reply With Quote
Old 12th April 2014, 22:49   #18
Rehaan's Avatar
Thanked: 25,080 Times
Yeah, I'll agree with you here.
Part of me is also venting frustration at the earlier concepts seen of "augmented reality projections on the windscreen" (like a HUD). In that case, small movements of the driver's head will make a much larger difference, due to the different distances between the eye, augmented layer & final objects.
cya
R
Old 14th April 2014, 17:20   #19
Thanked: 758 Times
Just a thought, this Idea could well be extrapolated to see below our rear wheels & terrain around the rear wheels
While engaging reverse gear or by engaged by a switch, a head-up display kind of thing could display the same.
Wanderers is offline   Reply With Quote
From"Aadab & Bagunnava" Land to Land of "Khammaghani"(Hyd to Rajasthan by M800) ranjitp1 Travelogues 104 2nd August 2016 15:17
Pics: Silver Land Rover Range Rover SE Gordon Super-Cars & Imports in India 38 4th May 2011 17:06
Land Rover Unveil 2010 Range Rover Sport with all-new 510hp V8 Engine hanmust The International Automotive Scene 2 8th April 2009 20:53
Land Rover unveil the LRX - to be badged Range Rover Tstag The International Automotive Scene 26 14th March 2009 16:17
