Old 23rd July 2014, 15:08   #31
alpha1's Avatar
Thanked: 1,047 Times
Default re: Gearbox failure in a 10-day old Mahindra Thar
Doesn't the snapping looks exactly like what happens when you test a metal piece for Young's modulus/Yield-Ultimate strength in the universal testing machine.
The material is subjected to linear elongation which exceeded the elastic limit stress and the material flowed like plastic before ultimately breaking.
alpha1 is offline   (1) Thanks Reply With Quote
Old 24th July 2014, 11:40   #32
Thanked: 201 Times
Default Re: My li'l Red Mahindra Thar with some practical modifications
Dear Mooza - this is not the reason for failure. If it was, it would not have lasted for 120 kms also.
Best regards,
Behram Dhabhar
Sir, please enlighten us on the root cause. I can see, it is twisted before breaking. That means the part is soft there.... It broke when the vehicle started, under normal load. That means the failure must be gradual. Defect in the alloy composition ?
Ravindra M is offline   Reply With Quote
Old 24th July 2014, 19:50   #33
Thanked: 48 Times
Default Re: Gearbox failure in a 10-day old Mahindra Thar
Mooza your observation is correct. This is a classical overload failure of a torsional shaft. Twisted splines and a clean cut is an indication. I suspect a goof up in the through hardening process( Ref the end view and the discoloration in the shaft middle- looks soft). Looks like this shaft may have around 20Rc (soft)against the typical requirement of around 40Rc and would have caused the failure.
Alpha1. This shaft do not see a tensile load( as in a UTM), It is a torque transmission shaft and hence the type of failure is also different.
Suresh
Suresh Stephen is offline   (7) Thanks Reply With Quote
Old 4th September 2014, 21:58   #34
narendra.vw's Avatar
Thanked: 402 Times
My thoughts,
The failure is not due to Heat treatment process. If it was,then within few km run the spline of the shaft would have rounded of. I suspect a blow hole in the shaft .
narendra.vw is offline   Reply With Quote
Old 31st October 2017, 14:43   #35
maheep007's Avatar
Thanked: 28 Times
Could it be a case of transmission wind up, when a part time 4x4 vehicle is driven on hard surface and the tires don't get to slip. In which case there is immense stress on transmission and other parts, and can snap. I'm not an expert, but thought maybe this could have been a reason.
Best regards
maheep007 is offline   (1) Thanks Reply With Quote
Ertiga, Dzire & Swift: Gearbox Synchronizer Failure susudi Technical Stuff 103 23rd February 2018 17:59
1 day old Mahindra Thar catches fire! Damages 3rd-party property too GTO 4x4 Vehicles 79 16th July 2014 20:32
Taking the Thar to the 'Thar'. 2000 kms, 3 childhood friends & an epic roadtrip Vroom barabar! Travelogues 30 25th March 2013 18:42
Mahindra Thar Gets a Deserving 1st B'Day, Offroading in Wayanad!! dhanushs 4x4 Excursions 18 20th January 2012 11:35
