Old 2nd August 2014, 10:37   #1
Thanked: 58 Times
Default Jeep: Problem with glow plugs
For some bizarre reason the engine pre-heat system on my 550 is acting up {stock XD3}.
I've been relying on a 'hacky' way to get the job done - string a wire from the battery +ve directly to one glow plug end, heat, run back, and start....
Have tried to eliminate the obvious as below:
1. Checked each of the 4 glow plugs - each one looks good
2. Checked the glow plug loom - nothing missing there
3. Swapped the heater timer box on the circuit with a new one
Short of the above the only other thing that I can think of, is to have a direct heater button & coil set up (eliminate the timer) - the ol' way - I think the timer cuts off too early before the pre-heat job is done..
Help! not sure what's missing
lugnut is offline   Reply With Quote
Old 2nd August 2014, 11:31   #2
Shwetank's Avatar
Thanked: 237 Times
Default re: Jeep: Problem with glow plugs
From your description, it appears that the vehicle does start with your 'hacky' procedure. You can check the main (+ve) going into the heater relay for breaks. This would be an 8mm wire from the battery.
Shwetank is offline   (1) Thanks Reply With Quote
Old 2nd August 2014, 11:44   #3
Jaggu's Avatar
Thanked: 8,862 Times
Yup seems like the wiring that connects heater control module to power or to the plugs which is the culprit.
Jaggu is offline   (1) Thanks Reply With Quote
Old 4th August 2014, 22:36   #4
Default Re: Jeep: Problem with glow plugs
If the wiring was changed from the original, maybe a fuse was added. Try and check if the fuse is the culprit.
Mudcat is offline   Reply With Quote
Old 5th August 2014, 21:55   #5
DirtyDan's Avatar
Thanked: 785 Times
Are you sure there is a glow plug problem at all? As opposed to, say, a starter motor problem, an air intake problem, a fuel line problem?
DirtyDan is offline   (1) Thanks Reply With Quote
Old 18th August 2014, 21:04   #6
boeuff's Avatar
Thanked: 64 Times
Could be low engine compression
boeuff is online now   Reply With Quote
Punto console indicating "check glow plugs". ironshark Technical Stuff 9 1st July 2018 14:06
Brand new Swift ZDI : Glow plugs indicators not working manjubp Technical Stuff 10 13th January 2012 12:31
Should i replace all four glow plugs ? rajivanoj Technical Stuff 14 26th September 2010 12:18
Pulstar plugs! Are the spark plugs obsolete? Is it a scam? Sankar Technical Stuff 8 4th October 2009 01:58
Glow Plugs for Indica V2 fariborzpz Technical Stuff 4 1st September 2009 13:40
