Old 21st September 2014, 11:13   #1
dhanushs's Avatar
Thanked: 4,504 Times
Default Electric Water Pump for Off-Road Vehicles
I was looking towards getting hold of an Electric Water Pump. The advantages, I'm looking for by installing one of these are:
1. Can fix the radiator to a different/higher/safer location, with longer custom plumbing, and the circulation isnt affected.
2. Increased Water Circulation inside the engine for better heat dissipation in extreme climates + high rpm's combination. Especially when you push a diesel engine towards ~5k rpm consistently in Palar like climate.
3. Electric water pump will keep the water flow running on a hot engine, even after shut down. Shutting off a hot engine after a spirited high rpm run isnt advisable, and this makes it possible?
4. Better Circulation during idling/low rpm load carrying situations.
5. Lastly, I will not be dependent on any belts. I can drive home safely (yes, without the alternator & the battery will decide the range) even if the belts fails.
I've also heard it saves bhp, but not sure how much.
  • Anyone done it here?
  • Any points to add to the above?
  • What are the pros and cons?
  • What is the availability?
  • What is the cost?
Old 21st September 2014, 13:04   #2
ex670c's Avatar
Thanked: 1,820 Times
http://www.daviescraig.com.au/Electr...umps-list.aspx
http://www.emp-corp.com/products/adv...ic-water-pump/
http://www.lsxtv.com/tech-stories/fu...c-water-pumps/
ex670c is offline   (8) Thanks Reply With Quote
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 722 14th July 2018 19:34
OTR & Paragliding: Palakkad Off-Road Adventure's "Off-Road Extreme 2013" JeepCaptain 4x4 Excursions 7 2nd March 2013 12:45
Mercedes-Benz "Road to the Future" - From BlueTEC diesel to electric vehicles: Modula hanmust The International Automotive Scene 2 14th June 2008 21:27
Wanted: 2nd hand Fuel Pump / Fuel Pump Body ramie2400 Shifting gears 2 6th October 2007 11:16
palio 1.2 nv 'pressure sensor error and water pump issue' kapilsharma80 Technical Stuff 5 17th September 2007 17:58
