Old 22nd November 2014, 18:50   #1
Default Mitsubishi Pajero - Free wheeling hub malfunction
Can someone help me out with wiring and routing of the SFX diff lock vacuum lines? The front diff has stopped locking nowadays. The plunger next to the differential does not lock /move anymore.
Will appreciate inputs from members. I try and do most of the repairs to the Pajero myself. Its a 2007 model.
Abid
aresq is offline   Reply With Quote
Old 23rd November 2014, 20:53   #2
Thanked: 2,448 Times
Default re: Mitsubishi Pajero - Free wheeling hub malfunction
Get the shop manual, and parts catalogue. Should be solenoid valve operated. What happens if you manually operate it?
Amongst the RD, the RX and the Enfield, which is getting the workout now?
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 25th November 2014, 11:21   #3
ex670c's Avatar
Thanked: 1,840 Times
Hi Abid,
I think you are talking about the Front Axle Disconnect mechanism.
http://4wd.blogeasy.com/article.view...ticleID=318776.
Arka
ex670c is offline   (5) Thanks Reply With Quote
Lamda Free Wheeling Front Hubs for Jeeps 4x4addict 4x4 Technical 201 6th November 2016 21:45
DIY: Service & Maintenance of Lambda Free-Wheeling-Hubs dhanushs 4x4 Technical 12 3rd September 2015 19:35
Exclusive Test : Mitsubishi Pajero 2.8 CRZ Euro III...! veyron1 Test-Drives & Initial Ownership Reports 31 26th November 2007 12:38
Is Mitsubishi Pajero worth it's tag? satish_appasani The Indian Car Scene 5 7th October 2004 00:23
Mitsubishi Pajero Stratos Shifting gears 1 26th May 2004 02:41
