Old 22nd August 2016, 10:44   #1
ex670c's Avatar
Thanked: 1,799 Times
Default Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep
Hi Guys,
Way back in June 2015, The Terra Tigers were approached by AIR90 Automotive to identify a list of Off Road Equipment, which will be welcome in the INDIAN off road scenario.
Additionally Terra Tigers have to prepare installation procedure, kits, identify best practices and Test these products off road, since we have a very active offroad calender.
For this purpose Vijay (petrol_head) and Me were sent to the Profender Factory for a 2 Day training Program in December 2015.
We identified the following
Return To Center Steering Damper
Suspension Upgrades for Toyota Fortuner, Isuzu Dmax and new Ford Endeavour.
Coilover (Strut) conversion kits for Mahindra JEEPs & Maruti Gypsy.
This thread is about the Remote Reservoir Shock Absorber installation and testing.
The Profender 2.0 Remote Reservoir Shock Absorber in 24" Long Fully Extended with a 8" Shaft Travel.
The Shocks are hard mounted on Spherical Bearings with Mis-Alignment Spacers.
The Shocks were mocked up on the axle tube to check for clearance.
This design led to the shock interfering with the front fender, and there wwasn't enough room to place a good shock hoop.
So wwe decided to go with the Original style shock mounts in the front, and a completely different shock orientation in the rear.
For this we identified the Leaf Spring Plate as the starting point and modified them.
The modified leaf spring plates have 2 advantages
1) Protect the Shock Absorber eye
2) Protect the Leaf Spring Plate U-Clamp and act as a mini skid plate.
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-above-axle-front.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-above-axle-front1.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-above-axle-rear.jpg
Arka
Last edited by Rudra Sen : 22nd August 2016 at 11:29. Reason: Merged back to back posts
ex670c is offline   (9) Thanks Reply With Quote
Old 22nd August 2016, 11:10   #2
ex670c's Avatar
Default Front & Rear Shock Orientation
In a Leaf Sprung Vehicle the Shackle allows the suspension to compress and rebound, this cause the axle tube to move along with the shackle in the direction of the shackle.
The idea was to have similar Shock absorber orientation front and back.
In the Rear there are some considerations.
1) The Shock Mount can be installed flush with the chassis as up front, but the rear tub has to be cut and the shocks will sit 4-6" inside the Rear Tub.
2) This will add body work
3) If the Shock Hoops are mounted outside the tub, they will rub with the tyre.
We chose to retain Tub Space, otherwise from Pure offroad perspective it is better to push the shock hoops inside and make two boxes inside the tub to cover the shock hoops.
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-front-measure.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-img20160610wa0012.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-platerear01.jpg
Last edited by Rudra Sen : 22nd August 2016 at 11:37. Reason: Pictures positions corrected
ex670c is offline   (10) Thanks Reply With Quote
Old 22nd August 2016, 13:30   #3
ex670c's Avatar
Default Shock Hoops
The Shock Hoops have the following uses
1) Orient the shock to swivel in direction of shackle movement
2) Transfer the shock absorber action to the chassis
3) Locate the shock absorber between the chassis and suspension
To achieve the above criteria, we did the following
1) The shock hoops are mounted on the chassis and the chassis is boxed in.
2) Outer Reinforcement Plates to distribute the weight
3) the hoops are mounted on tubes which run through the chassis
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-fronthoop01.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-fronthoop02.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-fronthoop03.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-fronthoop04.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-fronthoop05.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-fronthoop06.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-fronthoop07.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-fronthoop08.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-drilling-chassis.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-front-chassis-reinforcement02.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-rear-chassis-reinforcement-02.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-rear-chassis-reinforcement01.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-rear-chassis-reinforcment-03.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-rear-chasssis-outer-plates.jpg
Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep-rear-hoop-welded.jpg
ex670c is offline   (16) Thanks Reply With Quote
Old 22nd August 2016, 16:31   #4
Shubhendra's Avatar
Thanked: 1,178 Times
Default re: Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep
Great to see a meaningful/useful post, these shocks are just wonderful as i had an opportunity to drive this particular jeep with this particular shocks last month in Goa during RFC. I am waiting for another indigenous product which you have developed and which was very relevant as observed in RFC 'Bead locker' the actual one not the one we all typically see in most of the thars.
Many vehicles had their tyres popping out during RFC and Mahindra Club Challenge which could have been avoided if they would have been using bead lockers.
Another innovation which I am expecting from you Arka is PTO/God Winch, I am ready to be your Guinea Pig for trails for this
Shubhendra Singh
Shubhendra is offline   (3) Thanks Reply With Quote
Old 22nd August 2016, 21:30   #5
Twinn's Avatar
Thanked: 278 Times
Informative post Arka, I remembered we speaking about this. Tell me one thing .. Will this shock be effective for a leaf spring suspension? Since the length of travel is governed by the shackles, would the shock reach its optimum travel..
Twinn is offline   (2) Thanks Reply With Quote
Old 22nd August 2016, 21:45   #6
DirtyDan's Avatar
Thanked: 746 Times
Originally Posted by Twinn View Post
.. Tell me one thing .. Will this shock be effective for a leaf spring suspension? Since the length of travel is governed by the shackles, would the shock reach its optimum travel..
Arka, could you tell us a little more about what variables are involved with mounting the shock and at what angle? I don't know what you mean by #1 above but I would like to know.
DirtyDan is offline   (2) Thanks Reply With Quote
Old 23rd August 2016, 10:53   #7
ex670c's Avatar
Default Leaf Spring & Shock Absorbers - Simplified
Hi Amrith and DD,
The Length of Suspension Travel in a leaf Spring vehicle is dictated by the length of the leaf spring and it arch.
The Shackle locates the leaf spring and axles to the chassis and allows for the leaf spring to elongate (compression/up travel) shorten (rebound/down travel)
Up Travel/Down Travel/Ride Height
In up travel/compression the shock absorber mustn't top out, this is prevented by the axle snubbers/bump stop on the chassis
In Down Travel the shock absorber mustn't droop out when the suspension is fully extended.
Ride Height this is when the vehicle is static, 40-60% of shaft travel length must be available for Up Travel.
The simplest way to install remote reservoir shocks is to
i) set the suspension to full droop,
ii) the shock fully extended,
iii) mount the lower eye on the leaf spring/axle tube and
iv) measure the height at the chassis
Remote Reservoir Shock Absorbers and Leaf Spring
The Leaf Spring carries the Vehicle Weight and Suspends the Wheels
The RRSA, dampen the leaf spring action in Up Travel and Down Travel
i) When the Leaf Spring fully compresses,
ii) the axle tube moves forward/Backwards along the shackle about 1/2 to Full shackle length (25mm to 70mm)
iii) the RRSA should IDEALLY be 90 Degrees to the Leaf Spring Plate when viewed from the side.
Arka
ex670c is offline   (8) Thanks Reply With Quote
Old 23rd August 2016, 19:54   #8
DirtyDan's Avatar
Thanked: 746 Times
Default Re: Installing Remote Reservoir Shock Absorbers in a Mahindra Jeep
Nice short articulate answer. The two film clips are worth 2000 words. Let's see, that averages out to...better than 10 words per clip total savings! It looks like you have reinforced both the frame and the hoops with steel plates. That is meticulous and brilliant, as is the protection for the shock bottom eye and shackle. Wow! That's some nice forethought.
DirtyDan is offline   (1) Thanks Reply With Quote
Shock Absorbers Leakage vebmetal Technical Stuff 13 22nd March 2010 17:24
gas filled shock absorbers Ironmarine Technical Stuff 1 24th July 2006 13:38
Shock absorbers n suspensions gbpscars Modifications & Accessories 1 10th May 2006 14:22
Hyundai Santro Shock Absorbers aquavelva Modifications & Accessories 3 3rd May 2006 15:21
Gas Shock Absorbers for Swift aseem Technical Stuff 26 26th August 2005 09:47
